<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Developer Documentation]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Just wanted to let you know we have updated our developers documentation.  We have separated it into 2 parts, Angular for the UI and Java for the backend.  As of Mango 3.7 there is a new 'development' mode that can save time developing.  Check them out here:</p>
<p dir="auto"><a href="https://help.infiniteautomation.com/ui-development-process" rel="nofollow ugc">UI Development Process</a></p>
<p dir="auto"><a href="https://help.infiniteautomation.com/setting-up-eclipse-for-the-first-time" rel="nofollow ugc">Eclipse for Java</a></p>
]]></description><link>https://forum.mango-os.com/topic/4718/new-developer-documentation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:01:03 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4718.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Feb 2020 14:09:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Developer Documentation on Wed, 01 Jun 2022 19:53:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hazel" aria-label="Profile: hazel">@<bdi>hazel</bdi></a> there are no plans to update that documentation, your best bet is to review the code for our modules here:</p>
<p dir="auto"><a href="https://github.com/MangoAutomation/ma-modules-public" rel="nofollow ugc">https://github.com/MangoAutomation/ma-modules-public</a></p>
<p dir="auto">If you can be specific about what you are trying to accomplish I might be able to point you in the direction of some code that will help your specific use-case.</p>
]]></description><link>https://forum.mango-os.com/post/27381</link><guid isPermaLink="true">https://forum.mango-os.com/post/27381</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Wed, 01 Jun 2022 19:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to New Developer Documentation on Wed, 01 Jun 2022 14:46:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a></p>
<p dir="auto">Hi Terry,<br />
When will you update your developer documentation? I encountered a different configuration than the current version in Create Java Modules for Mango &gt; Custom Module Configuration. How do I build the module in version 4.3.5.<br />
Thanks in advance,</p>
<p dir="auto"><img src="https://camo.nodebb.org/6be15bfa422bf3dbc5a168401f729e1da3c44787?url=https%3A%2F%2Fi.imgur.com%2FE8gX2L0.png" alt="258154e5-4be6-4fc7-8c0d-ace48bdceb3b-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/27380</link><guid isPermaLink="true">https://forum.mango-os.com/post/27380</guid><dc:creator><![CDATA[hazel]]></dc:creator><pubDate>Wed, 01 Jun 2022 14:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to New Developer Documentation on Wed, 13 Jan 2021 18:28:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi Terry,<br />
We will install development environment for Mango v4.0.0.beta5 to our test servers.</p>
<p dir="auto">We are following the steps on this link <a href="http://docs-v4.mango-os.com/mango-java-developer-ide-setup-and-usage" rel="nofollow ugc">http://docs-v4.mango-os.com/mango-java-developer-ide-setup-and-usage</a> .</p>
<p dir="auto">We completed the steps until the “Copy Overrides” part. But on that part we cannot find classes folder and classes debug-log4j2.xml file on the directory.<br />
Also, on the Run Configuration part while we are configuring VM Arguments, we could not set debug-log4j2.xml file.<br />
We saw that properties file is on the resources file. On the run configuration dependencies tab, what should we connect to Classpath Entries?</p>
<p dir="auto">Is there a different documentation for beta.5 development environment?<br />
]]></description><link>https://forum.mango-os.com/post/26181</link><guid isPermaLink="true">https://forum.mango-os.com/post/26181</guid><dc:creator><![CDATA[hazel]]></dc:creator><pubDate>Wed, 13 Jan 2021 18:28:54 GMT</pubDate></item><item><title><![CDATA[Reply to New Developer Documentation on Sun, 23 Feb 2020 21:27:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi Terry, just letting you know I clicked in and nothing appeared on mobile when I clicked on the Ui Development process menu item.<br />
Sorry, disregard, it wasn't until I went into my pc I realised the page is actually a file download...</p>
]]></description><link>https://forum.mango-os.com/post/24770</link><guid isPermaLink="true">https://forum.mango-os.com/post/24770</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sun, 23 Feb 2020 21:27:53 GMT</pubDate></item></channel></rss>
