    State Chart X-Axis showing different time format
    15 Posts 2 Posters 6.3k Views 2 Watching
    • Z Offline
      zenvakil
      Hey Everyone,
      I am having some issues with the charts below.
      Firstly both charts are displaying a strange time signature along the x-axis, instead of just the date/time. And secondly The state chart does not appear to recognize any of the text rendering of the data points.
      <md-card flex="">
                                      <md-card-content>
                                          <ma-point-values point-xid="UAR-STN-DP_Gen_BreakerState" point="point1" values="point1Values" from="dateBar.from" to="dateBar.to" rollup="{{dateBar.rollupType}}" rollup-interval="{{dateBar.rollupIntervals}} {{dateBar.rollupIntervalPeriod}}">
                                          </ma-point-values>
                                          <ma-point-values point-xid="UAR-STN-DP_Gen_State" point="point2" values="point2Values" from="dateBar.from" to="dateBar.to" rollup="{{dateBar.rollupType}}" rollup-interval="{{dateBar.rollupIntervals}}">
                                          </ma-point-values>
                                          <ma-state-chart series1-values="point1Values" series1-title="Breaker State" series2-values="point2Values" series2-title="Generator State" style="position: inherit; width: 100%; height: 100px;" options="{categoryAxis:{labelTime: transparent}}"></ma-state-chart>
                                      </md-card-content>
                                  </md-card>
                                  <md-card flex="">
                                      <md-card-content>
                                          <ma-point-values point-xid="UAR-STN-DP_Gen_Load" point= "point3" values="point3Values" from="dateBar.from" to="dateBar.to"></ma-point-values>
                                          <ma-serial-chart series-1-values="point3Values" series-1-points="point3" style="height: 200px; width: 100%"></ma-serial-chart>
                                      </md-card-content>
                                  </md-card>
        Hi @zenvakil
        Firstly I would suggest taking the time to run through this tutorial: https://docs.angularjs.org/tutorial
        It will help to understand the basic concepts of angularJS.
        I see a few issues that I suspect are causing your problems:
        • <ma-point-values point-xid="UAR-STN-DP_Gen_Load" point= "point3" values="point3Values" from="dateBar.from" to="dateBar.to"></ma-point-values>
          should be have rendered="true" to receive the rendered value.
        • you have some typos in your components:
        should be:
        series-1-values="point1Values" series-1-title="Breaker State" series-2-values="point2Values" series-2-title="Generator State"
        should be:
        <ma-serial-chart series-1-values="point3Values" series-1-point="point3" style="height: 200px; width: 100%"></ma-serial-chart> (point not points)
        • Z Offline
          zenvakil
          Hey Craig,
          Thanks for the reply, still no cigar. The redered="true" was in place originally but i think i removed it to see if anything would change.
            I just looked at the <ma-start-chart> example and I see you are missing this. :
            series-1-labels="point1.getTextRenderer().values"
            Did the typo fixes, fix the serial chart?
            • Z Offline
              zenvakil
              @craigweb said in State Chart X-Axis showing different time format:
              Hey Craig,
              Thats another thing I had tried, then removed, I've put it back in, but still no luck. Neither of the charts have changed at all :(
                Have you tried getting it working in the statechart example with the points you want to use? at /ui/examples/charts/state-chart
                and what rollup do you have set on the dateBar?
                The <ma-start-chart> is only for multistate points. Are they perhaps not using the range renderer?
                • Z Offline
                  zenvakil
                  Hey Craig,
                  I'm fairly new to this, as I'm sure you can tell. But I had originally tried the chart out in the examples/state-chart section, where it does work. The rollup is set to none and the points are definitely multistate points using the range renderer.
                  Funny enough, at some point (this is something I only work on when I have the time), the time issue seems to have rectified itself and it's now presenting correctly. The text rendering however is still not working :(
                    Please share your code as it is now.
                    • Z Offline
                      zenvakil
                      <md-card flex="">
                                                      <md-card-content>
                                                          </ma-point-values>
                                                          </ma-point-values>
                                                      </md-card-content>
                                                  </md-card>
                                                  <md-card flex="">
                                                      <md-card-content>
                                                      </md-card-content>
                                                  </md-card>
                        add series-1-labels="point1.getTextRenderer().values" series-2-labels="point2.getTextRenderer().values"
                        to your state chart.
                        • Z Offline
                          zenvakil
                          Done, but still unfortunately nothing.
                          <md-card flex="">
                                                          <md-card-content>
                                                              </ma-point-values>
                                                              </ma-point-values>
                                                              <ma-state-chart series1-values="point1Values" series1-title="Breaker State" series2-values="point2Values" series2-title="Generator State" style="position: inherit; width: 100%; height: 100px;" series-1-labels="point1.getTextRenderer().values" series-2-labels="point2.getTextRenderer().values"options="{categoryAxis:{labelTime: transparent}}"></ma-state-chart>
                                                          </md-card-content>
                                                      </md-card>
                                                      <md-card flex="">
                                                          <md-card-content>
                                                          </md-card-content>
                                                      </md-card>
                            I copied your <ma-state-chart> to the state chart example and it works perfectly.
                            Can you put the following code below the charts: {{point1.getTextRenderer().values}} and see if you get the correct labels.
                            • Z Offline
                              zenvakil
                              Hey Craig,
                              Yeah as I said before I originally did this in the example page and it worked perfectly, so I decided to put this in our dashboard then for some reason it's not working (still works on the example page).
                              I've definitely done something absolutely STUPID to stop it from working but I just cannot figure out what it is hahaha.
                              <md-card flex="">
                                                              <md-card-content>
        </ma-point-values>
        </ma-point-values>
        <div style="position:inherit;width:100%;height:100px">{{point1.getTextRenderer().values}}</div>
                                                              </md-card-content>
                                                          </md-card>
                              • Z Offline
                                zenvakil
                                Also just for validation, here's the result when I enter it into the example page:
                                • Z Offline
                                  zenvakil
                                  Hey Craig, Thanks for all the help.
                                  I ended up figuring it out :)
                                  <md-card flex="">
        <md-card-content>
        <ma-get-point-value point-xid="UAR-STN-DP_Gen_BreakerState" point="point1"></ma-get-point-value>
        <ma-get-point-value point-xid="UAR-STN-DP_Gen_State" point="point2"></ma-get-point-value>
        <ma-point-values point="point1" values="point1Values" from="dateBar.to | maMoment:'subtract':1:'day'" to="dateBar.to" rollup="FIRST" rollup-interval="1 hours">
        </ma-point-values>
        <ma-point-values point="point2" values="point2Values" from="dateBar.to | maMoment:'subtract':1:'day'" to="dateBar.to" rollup="FIRST" rollup-interval="1 hours">
        </ma-point-values>
        <ma-state-chart style="height: 500px; width: 100%" series-1-title="{{point1.name}}" series-1-values="point1Values" series-1-labels="point1.getTextRenderer().values" series-2-title="{{point2.name}}" series-2-values="point2Values" series-2-labels="point2.getTextRenderer().values">
        </ma-state-chart>
        </md-card-content>
                                                              </md-card>
