    State Chart X-Axis showing different time format
    15 Posts 2 Posters 8.0k Views 2 Watching
      I just looked at the <ma-start-chart> example and I see you are missing this. :
      series-1-labels="point1.getTextRenderer().values"
      Did the typo fixes, fix the serial chart?
      • Z Offline
        zenvakil
        @craigweb said in State Chart X-Axis showing different time format:
        Hey Craig,
        Thats another thing I had tried, then removed, I've put it back in, but still no luck. Neither of the charts have changed at all :(
          Have you tried getting it working in the statechart example with the points you want to use? at /ui/examples/charts/state-chart
          and what rollup do you have set on the dateBar?
          The <ma-start-chart> is only for multistate points. Are they perhaps not using the range renderer?
          • Z Offline
            zenvakil
            Hey Craig,
            I'm fairly new to this, as I'm sure you can tell. But I had originally tried the chart out in the examples/state-chart section, where it does work. The rollup is set to none and the points are definitely multistate points using the range renderer.
            Funny enough, at some point (this is something I only work on when I have the time), the time issue seems to have rectified itself and it's now presenting correctly. The text rendering however is still not working :(
              Please share your code as it is now.
              • Z Offline
                zenvakil
                <md-card flex="">
                                                <md-card-content>
                                                    <ma-point-values point-xid="UAR-STN-DP_Gen_BreakerState" point="point1" values="point1Values" from="dateBar.from" to="dateBar.to" rollup="{{dateBar.rollupType}}" rollup-interval="{{dateBar.rollupIntervals}} {{dateBar.rollupIntervalPeriod}}">
                                                    </ma-point-values>
                                                    <ma-point-values point-xid="UAR-STN-DP_Gen_State" point="point2" values="point2Values" from="dateBar.from" to="dateBar.to" rollup="{{dateBar.rollupType}}" rollup-interval="{{dateBar.rollupIntervals}}">
                                                    </ma-point-values>
                                                    <ma-state-chart series1-values="point1Values" series1-title="Breaker State" series2-values="point2Values" series2-title="Generator State" style="position: inherit; width: 100%; height: 100px;" options="{categoryAxis:{labelTime: transparent}}"></ma-state-chart>
                                                </md-card-content>
                                            </md-card>
                                            <md-card flex="">
                                                <md-card-content>
                                                    <ma-point-values point-xid="UAR-STN-DP_Gen_Load" point= "point3" values="point3Values" from="dateBar.from" to="dateBar.to"></ma-point-values>
                                                    <ma-serial-chart series-1-values="point3Values" series-1-points="point3" style="height: 200px; width: 100%"></ma-serial-chart>
                                                </md-card-content>
                                            </md-card>
                  add series-1-labels="point1.getTextRenderer().values" series-2-labels="point2.getTextRenderer().values"
                  to your state chart.
                  • Z Offline
                    zenvakil
                    Done, but still unfortunately nothing.
                    <md-card flex="">
                                                    <md-card-content>
                                                        </ma-point-values>
                                                        </ma-point-values>
                                                        <ma-state-chart series1-values="point1Values" series1-title="Breaker State" series2-values="point2Values" series2-title="Generator State" style="position: inherit; width: 100%; height: 100px;" series-1-labels="point1.getTextRenderer().values" series-2-labels="point2.getTextRenderer().values"options="{categoryAxis:{labelTime: transparent}}"></ma-state-chart>
                                                    </md-card-content>
                                                </md-card>
                                                <md-card flex="">
                                                    <md-card-content>
                                                    </md-card-content>
                                                </md-card>
                      I copied your <ma-state-chart> to the state chart example and it works perfectly.
                      Can you put the following code below the charts: {{point1.getTextRenderer().values}} and see if you get the correct labels.
                      • Z Offline
                        zenvakil
                        Hey Craig,
                        Yeah as I said before I originally did this in the example page and it worked perfectly, so I decided to put this in our dashboard then for some reason it's not working (still works on the example page).
                        I've definitely done something absolutely STUPID to stop it from working but I just cannot figure out what it is hahaha.
                        <md-card flex="">
                                                        <md-card-content>
                                                            </ma-point-values>
                                                            </ma-point-values>
                                                            <div style="position:inherit;width:100%;height:100px">{{point1.getTextRenderer().values}}</div>
                                                        </md-card-content>
                                                    </md-card>
                        • Z Offline
                          zenvakil
                          Also just for validation, here's the result when I enter it into the example page:
                          • Z Offline
                            zenvakil
                            Hey Craig, Thanks for all the help.
                            I ended up figuring it out :)
                            <md-card flex="">
                                                            <md-card-content>
        <ma-get-point-value point-xid="UAR-STN-DP_Gen_BreakerState" point="point1"></ma-get-point-value>
        <ma-get-point-value point-xid="UAR-STN-DP_Gen_State" point="point2"></ma-get-point-value>
        <ma-point-values point="point1" values="point1Values" from="dateBar.to | maMoment:'subtract':1:'day'" to="dateBar.to" rollup="FIRST" rollup-interval="1 hours">
        </ma-point-values>
        <ma-point-values point="point2" values="point2Values" from="dateBar.to | maMoment:'subtract':1:'day'" to="dateBar.to" rollup="FIRST" rollup-interval="1 hours">
        </ma-point-values>
        <ma-state-chart style="height: 500px; width: 100%" series-1-title="{{point1.name}}" series-1-values="point1Values" series-1-labels="point1.getTextRenderer().values" series-2-title="{{point2.name}}" series-2-values="point2Values" series-2-labels="point2.getTextRenderer().values">
        </ma-state-chart>
                                                            </md-card-content>
                                                        </md-card>
