    Simple Examples
    28 Posts 4 Posters 50.3k Views 1 Watching
      Oh, as an explanation of why you got that error... You created the RemoteDevice yourself and added it to your list of remote devices with "localDevice.addRemoteDevice(rd);". Then, in the loop, you asked this remote device for a property that it does not have (because you didn't give the property to it). So, you got an "Unknown Object" error.
        apl
        Thanks, step done ...
        Are you Interested in the changed code?
        next: How to read the Properties of the objects ai0,ai1,bi0,bi1,msg0,ao0 set by SimpleTest? - or in which testfiles are there?
        Arne
          Sure, if you think it will help other users, post it up.
          You send some form of a "read properties" request. Below is a snippet of how Mango does it. It's contextual to Mango, but i think you should be able to figure out what is going on.
              private void pollDevice(RemoteDevice d, List<DataPointRT> points, long time) {
                  // Gather the points into a list of point references.
                  PropertyReferences refs = new PropertyReferences();
                  for (DataPointRT dp : points) {
                      BACnetIPPointLocatorRT locator = (BACnetIPPointLocatorRT)dp.getPointLocator();
                      refs.add(locator.getOid(), locator.getPid());
                  try {
                      // Send the read request.
                      PropertyValues values = localDevice.readProperties(d, refs);
                      // Dereference the property values back into the points.
                          Encodable encodable = values.getNoErrorCheck(locator.getOid(), locator.getPid());
                          if (encodable == null)
                              fireDeviceExceptionEvent("event.bacnet.readError", dp.getVO().getName(), "no value returned");
                          else if (encodable instanceof BACnetError)
                                      ((BACnetError)encodable).getErrorCode());
                          else {
                              Object value = encodableToValue(encodable, dp.getDataTypeId());
                              dp.updatePointValue(new PointValueTime(value, time));
                  catch (BACnetException e) {
                      fireMessageExceptionEvent("event.bacnet.readDevice", d.getAddress().toIpString(), e.getMessage());
            apl
            So this two classes should work straight out of the box on any machine ;-)
            DeviceTest
             * GNU Lesser General Public License
             * Copyright (C) 2006-2009 Serotonin Software Technologies Inc. http://serotoninsoftware.com
             * @author Matthew Lohbihler
             * This library is free software; you can redistribute it and/or
             * modify it under the terms of the GNU Lesser General Public
             * License as published by the Free Software Foundation; either
             * version 2.1 of the License, or (at your option) any later version.
             * This library is distributed in the hope that it will be useful,
             * but WITHOUT ANY WARRANTY; without even the implied warranty of
             * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
             * Lesser General Public License for more details.
             * You should have received a copy of the GNU Lesser General Public
             * License along with this library; if not, write to the Free Software
             * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307, USA.
            package com.serotonin.bacnet4j.test;
            import com.serotonin.bacnet4j.RemoteObject;
            import com.serotonin.bacnet4j.obj.BACnetObject;
            import com.serotonin.bacnet4j.type.Encodable;
            import com.serotonin.bacnet4j.type.constructed.Choice;
            import com.serotonin.bacnet4j.type.constructed.PropertyValue;
            import com.serotonin.bacnet4j.type.constructed.TimeStamp;
            import com.serotonin.bacnet4j.type.enumerated.EventState;
            import com.serotonin.bacnet4j.type.enumerated.EventType;
            import com.serotonin.bacnet4j.type.enumerated.MessagePriority;
            import com.serotonin.bacnet4j.type.enumerated.NotifyType;
            import com.serotonin.bacnet4j.type.notificationParameters.NotificationParameters;
            import com.serotonin.bacnet4j.type.primitive.Boolean;
            import com.serotonin.bacnet4j.type.primitive.CharacterString;
            import java.io.IOException;
            import java.util.List;
            import com.serotonin.bacnet4j.LocalDevice;
            import com.serotonin.bacnet4j.RemoteDevice;
            import com.serotonin.bacnet4j.event.DeviceEventListener;
            import com.serotonin.bacnet4j.exception.BACnetException;
            import com.serotonin.bacnet4j.service.unconfirmed.WhoIsRequest;
            import com.serotonin.bacnet4j.type.constructed.BACnetError;
            import com.serotonin.bacnet4j.type.constructed.PropertyReference;
            import com.serotonin.bacnet4j.type.constructed.SequenceOf;
            import com.serotonin.bacnet4j.type.enumerated.ObjectType;
            import com.serotonin.bacnet4j.type.enumerated.PropertyIdentifier;
            import com.serotonin.bacnet4j.type.primitive.ObjectIdentifier;
            import com.serotonin.bacnet4j.type.primitive.UnsignedInteger;
            import com.serotonin.bacnet4j.util.PropertyReferences;
            import com.serotonin.bacnet4j.util.PropertyValues;
             * Discovers and devices and print all properties of all objects found.
             * @author Arne Plöse
            public class DiscoveryTest {
                public static String BROADCAST_ADDRESS = "127.0.0.255";
                private LoopDevice loopDevice;
                private LocalDevice localDevice;
                public DiscoveryTest(String broadcastAddress, int port) throws IOException {
                    localDevice = new LocalDevice(1234, broadcastAddress);
                    localDevice.setPort(port);
                    localDevice.getEventHandler().addListener(new DeviceEventListener() {
                        public void listenerException(Throwable e) {
                            System.out.println("DiscoveryTest listenerException");
                        public void iAmReceived(RemoteDevice d) {
                            System.out.println("DiscoveryTest iAmReceived");
                            synchronized (DiscoveryTest.this) {
                                DiscoveryTest.this.notifyAll();
                        public boolean allowPropertyWrite(BACnetObject obj, PropertyValue pv) {
                            System.out.println("DiscoveryTest allowPropertyWrite");
                            return true;
                        public void propertyWritten(BACnetObject obj, PropertyValue pv) {
                            System.out.println("DiscoveryTest propertyWritten");
                        public void iHaveReceived(RemoteDevice d, RemoteObject o) {
                            System.out.println("DiscoveryTest iHaveReceived");
                        public void covNotificationReceived(UnsignedInteger subscriberProcessIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier monitoredObjectIdentifier, UnsignedInteger timeRemaining, SequenceOf<PropertyValue> listOfValues) {
                            System.out.println("DiscoveryTest covNotificationReceived");
                        public void eventNotificationReceived(UnsignedInteger processIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier eventObjectIdentifier, TimeStamp timeStamp, UnsignedInteger notificationClass, UnsignedInteger priority, EventType eventType, CharacterString messageText, NotifyType notifyType, Boolean ackRequired, EventState fromState, EventState toState, NotificationParameters eventValues) {
                            System.out.println("DiscoveryTest eventNotificationReceived");
                        public void textMessageReceived(RemoteDevice textMessageSourceDevice, Choice messageClass, MessagePriority messagePriority, CharacterString message) {
                            System.out.println("DiscoveryTest textMessageReceived");
                        public void privateTransferReceived(UnsignedInteger vendorId, UnsignedInteger serviceNumber, Encodable serviceParameters) {
                            System.out.println("DiscoveryTest privateTransferReceived");
                    localDevice.initialize();
                public void doDiscover() throws Exception {
                    // Who is
                    System.out.println("Send Broadcast WhoIsRequest() ");
                    // Send the broadcast to the correct port of the LoopDevice !!!
                    localDevice.sendBroadcast(loopDevice.getPort(), new WhoIsRequest(null, null));
                    // wait for notification in iAmReceived() Timeout 2 sec
                    synchronized (this) {
                        final long start = System.currentTimeMillis();
                        this.wait(2000);
                        System.out.println(" waited for iAmReceived: " + (System.currentTimeMillis() - start) + " ms");
                    System.out.println("Start iterating remote devices");
                    // Get extended information for all remote devices.
                    for (RemoteDevice d : localDevice.getRemoteDevices()) {
                        localDevice.getExtendedDeviceInformation(d);
                        List<ObjectIdentifier> oids = ((SequenceOf<ObjectIdentifier>) localDevice.sendReadPropertyAllowNull(
                                d, d.getObjectIdentifier(), PropertyIdentifier.objectList)).getValues();
                        for (ObjectIdentifier oid : oids) {
                            addPropertyReferences(refs, oid);
                        System.out.println("Values of d: " + d);
                        try {
                                printObject(oid, refs, values);
                        } catch (BACnetException e) {
                            System.out.println("event.bacnet.readDevice ADDRESS: " + e.getMessage());
                    System.out.println("Remote devices done...");
                 * Note same Bropadcast address, but different ports!!!
                 * @param args
                 * @throws java.lang.Exception
                @SuppressWarnings("unchecked")
                public static void main(String[] args) throws Exception {
                    DiscoveryTest dt = new DiscoveryTest(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT);
                    dt.setLoopDevice(new LoopDevice(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT + 1));
                    try {
                        dt.doDiscover();
                    } finally {
                        dt.localDevice.terminate();
                        System.out.println("Cleanup loopDevice");
                        dt.getLoopDevice().doTerminate();
                private void addPropertyReferences(PropertyReferences refs, ObjectIdentifier oid) {
                    refs.add(oid, PropertyIdentifier.objectName);
                    ObjectType type = oid.getObjectType();
                    if (ObjectType.accumulator.equals(type)) {
                        refs.add(oid, PropertyIdentifier.units);
                    } else if (ObjectType.analogInput.equals(type) ||
                            ObjectType.analogOutput.equals(type) ||
                            ObjectType.analogValue.equals(type) ||
                            ObjectType.pulseConverter.equals(type)) {
                    } else if (ObjectType.binaryInput.equals(type) ||
                            ObjectType.binaryOutput.equals(type) ||
                            ObjectType.binaryValue.equals(type)) {
                        refs.add(oid, PropertyIdentifier.inactiveText);
                        refs.add(oid, PropertyIdentifier.activeText);
                    } else if (ObjectType.lifeSafetyPoint.equals(type)) {
                    } else if (ObjectType.loop.equals(type)) {
                        refs.add(oid, PropertyIdentifier.outputUnits);
                    } else if (ObjectType.multiStateInput.equals(type) ||
                            ObjectType.multiStateOutput.equals(type) ||
                            ObjectType.multiStateValue.equals(type)) {
                        refs.add(oid, PropertyIdentifier.stateText);
                    } else {
                        return;
                    refs.add(oid, PropertyIdentifier.presentValue);
                 * @return the loopDevice
                public LoopDevice getLoopDevice() {
                    return loopDevice;
                 * @param loopDevice the loopDevice to set
                public void setLoopDevice(LoopDevice loopDevice) {
                    this.loopDevice = loopDevice;
                private void printObject(ObjectIdentifier oid, PropertyReferences refs, PropertyValues values) {
                    System.out.println("\t" + oid);
                    // print propertie
                    for (PropertyReference pr : refs.getProperties().get(oid)) {
                        Encodable encodable = values.getNoErrorCheck(oid, pr);
                        if (encodable == null) {
                            System.out.println("event.bacnet.readError: no value returned");
                        } else if (encodable instanceof BACnetError) {
                            System.out.println("event.bacnet.readError NAME: " + ((BACnetError) encodable).getErrorCode());
                        } else {
                            System.out.println(String.format("\t\t %s = %s", pr.getPropertyIdentifier(), encodable.toString()));
            LoopDevice
            import com.serotonin.bacnet4j.exception.BACnetServiceException;
            import com.serotonin.bacnet4j.type.enumerated.BinaryPV;
            import com.serotonin.bacnet4j.type.enumerated.EngineeringUnits;
            import com.serotonin.bacnet4j.type.primitive.Real;
             * software only device default local loop ;-)
             * @author mlohbihler
             * @author aploese
            public class LoopDevice implements Runnable {
                    LoopDevice ld = new LoopDevice("127.0.0.255", LocalDevice.DEFAULT_PORT + 1);
                    Thread.sleep(12000); // wait 2 min
                    ld.doTerminate();
                private boolean terminate;
                private BACnetObject ai0;
                private BACnetObject ai1;
                private BACnetObject bi0;
                private BACnetObject bi1;
                private BACnetObject mso0;
                private BACnetObject ao0;
                public LoopDevice(String broadcastAddress, int port) throws BACnetServiceException, IOException {
                    localDevice = new LocalDevice(1968, broadcastAddress);
                            System.out.println("loopDevice listenerException");
                            System.out.println("loopDevice iAmReceived");
                            System.out.println("loopDevice allowPropertyWrite");
                            return true;
                            System.out.println("loopDevice propertyWritten");
                            System.out.println("loopDevice iHaveReceived");
                            System.out.println("loopDevice covNotificationReceived");
                            System.out.println("loopDevice eventNotificationReceived");
                            System.out.println("loopDevice textMessageReceived");
                            System.out.println("loopDevice privateTransferReceived");
                    // Set up a few objects.
                    ai0 = new BACnetObject(
                            localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.analogInput));
                    ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.centimeters);
                    localDevice.addObject(getAi0());
                    ai1 = new BACnetObject(
                    ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.percentObscurationPerFoot);
                    localDevice.addObject(getAi1());
                    bi0 = new BACnetObject(
                            localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.binaryInput));
                    localDevice.addObject(getBi0());
                    bi0.setProperty(PropertyIdentifier.objectName, new CharacterString("Off and on"));
                    bi0.setProperty(PropertyIdentifier.inactiveText, new CharacterString("Off"));
                    bi0.setProperty(PropertyIdentifier.activeText, new CharacterString("On"));
                    bi1 = new BACnetObject(
                    localDevice.addObject(getBi1());
                    bi1.setProperty(PropertyIdentifier.objectName, new CharacterString("Good and bad"));
                    bi1.setProperty(PropertyIdentifier.inactiveText, new CharacterString("Bad"));
                    bi1.setProperty(PropertyIdentifier.activeText, new CharacterString("Good"));
                    mso0 = new BACnetObject(
                            localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.multiStateOutput));
                    mso0.setProperty(PropertyIdentifier.objectName, new CharacterString("Vegetable"));
                    mso0.setProperty(PropertyIdentifier.numberOfStates, new UnsignedInteger(4));
                    mso0.setProperty(PropertyIdentifier.stateText, 1, new CharacterString("Tomato"));
                    mso0.setProperty(PropertyIdentifier.stateText, 2, new CharacterString("Potato"));
                    mso0.setProperty(PropertyIdentifier.stateText, 3, new CharacterString("Onion"));
                    mso0.setProperty(PropertyIdentifier.stateText, 4, new CharacterString("Broccoli"));
                    mso0.setProperty(PropertyIdentifier.presentValue, new UnsignedInteger(1));
                    localDevice.addObject(getMso0());
                    ao0 = new BACnetObject(
                            localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.analogOutput));
                    ao0.setProperty(PropertyIdentifier.objectName, new CharacterString("Settable analog"));
                    localDevice.addObject(getAo0());
                    // Start the local device.
                    new Thread(this).start();
                public void run() {
                    try {
                        System.out.println("LoopDevice start changing values" + this);
                        // Let it go...
                        float ai0value = 0;
                        float ai1value = 0;
                        boolean bi0value = false;
                        boolean bi1value = false;
                        getMso0().setProperty(PropertyIdentifier.presentValue, new UnsignedInteger(2));
                        while (!isTerminate()) {
                            System.out.print("Change values of LoopDevice " + this);
                            // Change the values.
                            ai0value += 0.1;
                            ai1value += 0.7;
                            bi0value = !bi0value;
                            bi1value = !bi1value;
                            // Update the values in the objects.
                            ai0.setProperty(PropertyIdentifier.presentValue, new Real(ai0value));
                            ai1.setProperty(PropertyIdentifier.presentValue, new Real(ai1value));
                            bi0.setProperty(PropertyIdentifier.presentValue, bi0value ? BinaryPV.active : BinaryPV.inactive);
                            bi1.setProperty(PropertyIdentifier.presentValue, bi1value ? BinaryPV.active : BinaryPV.inactive);
                                wait(1000); // 1 second or notified (faster exit then stupid wait for 1 second)
                        System.out.println("Close LoopDevive " + this);
                    } catch (Exception ex) {
                    localDevice = null;
                @Override
                protected void finalize() throws Throwable {
                    if (localDevice != null) {
                        localDevice = null;
                 * @return the terminate
                public boolean isTerminate() {
                    return terminate;
                 * @param terminate the terminate to set
                public void doTerminate() {
                    this.terminate = true;
                        this.notifyAll(); // we may wait for this in run() ...
                 * @return the broadcastAddress
                public String getBroadcastAddress() {
                    return localDevice.getBroadcastAddress();
                 * @return the port
                public int getPort() {
                    return localDevice.getPort();
                 * @return the localDevice
                public LocalDevice getLocalDevice() {
                    return localDevice;
                 * @return the ai0
                public BACnetObject getAi0() {
                    return ai0;
                 * @return the ai1
                public BACnetObject getAi1() {
                    return ai1;
                 * @return the bi0
                public BACnetObject getBi0() {
                    return bi0;
                 * @return the bi1
                public BACnetObject getBi1() {
                    return bi1;
                 * @return the mso0
                public BACnetObject getMso0() {
                    return mso0;
                 * @return the ao0
                public BACnetObject getAo0() {
                    return ao0;
            Arne
              This is excellent Arne. Thanks very much for sharing your work.
                apl
                trying to read all property values by using this changed code in :
                        for (int i = 0; i < 12; i++) {
                            refs.add(oid, new PropertyIdentifier(75 + i));
                and choose values greater of 12 >> the app will fail.
                Any hints?
                Arne
                  apl
                  Hi Matthew,
                  the offending PropertyId are: 8, 87, 105, which throw a java.lang.reflect.InvocationTargetException.
                  Should I file a bug against it in the SF bug parade?
                  Arne
                    Hi Arne,
                    I can't reproduce the problem. This code worked fine for me:
                            ObjectIdentifier oid = new ObjectIdentifier(ObjectType.accumulator, 0);
                            for (int i=0; i&lt200; i++)
                                refs.add(oid, new PropertyIdentifier(i));
                    A stack trace goes a long way to explaining things. Maybe you can include that if you still have this problem.
                    Also, can you please start a new topic when you are changing subject. This thread is getting too expansive.
                      apl
                      Sorry,
                      I thought this belongs also to create a bunch of example that runs out of the box.
                      OK, here is my stack trace:
                      com.serotonin.bacnet4j.exception.BACnetException: java.lang.reflect.InvocationTargetException
                              at com.serotonin.bacnet4j.type.Encodable.read(Encodable.java:168)
                              at com.serotonin.bacnet4j.type.constructed.SequenceOf.<init>(SequenceOf.java:54)
                              at com.serotonin.bacnet4j.type.Encodable.readSequenceOf(Encodable.java:213)
                              at com.serotonin.bacnet4j.service.acknowledgement.ReadPropertyMultipleAck.<init>(ReadPropertyMultipleAck.java:50)
                              at com.serotonin.bacnet4j.service.acknowledgement.AcknowledgementService.createAcknowledgementService(AcknowledgementService.java:48)
                              at com.serotonin.bacnet4j.apdu.ComplexACK.parseServiceData(ComplexACK.java:196)
                              at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.waitForAck(IpMessageControl.java:658)
                              at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:288)
                              at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:268)
                              at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:224)
                              at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:411)
                              at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:399)
                              at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:392)
                              at com.serotonin.bacnet4j.LocalDevice.readProperties(LocalDevice.java:760)
                              at com.serotonin.bacnet4j.test.DiscoveryTest.doDiscover(DiscoveryTest.java:155)
                              at com.serotonin.bacnet4j.test.DiscoveryTest.main(DiscoveryTest.java:187)
                      Caused by: java.lang.reflect.InvocationTargetException
                              at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
                              at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
                              at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
                              at com.serotonin.bacnet4j.type.Encodable.read(Encodable.java:165)
                              ... 15 more
                      Caused by: com.serotonin.bacnet4j.exception.BACnetException: java.lang.reflect.InvocationTargetException
                              at com.serotonin.bacnet4j.type.constructed.SequenceOf.<init>(SequenceOf.java:66)
                              at com.serotonin.bacnet4j.type.Encodable.readSequenceOf(Encodable.java:224)
                              at com.serotonin.bacnet4j.type.Encodable.readOptionalSequenceOf(Encodable.java:233)
                              at com.serotonin.bacnet4j.type.constructed.ReadAccessResult.<init>(ReadAccessResult.java:64)
                              ... 20 more
                              at sun.reflect.GeneratedConstructorAccessor3.newInstance(Unknown Source)
                              ... 24 more
                              at com.serotonin.bacnet4j.type.Encodable.readWrapped(Encodable.java:318)
                              at com.serotonin.bacnet4j.type.Encodable.readEncodable(Encodable.java:263)
                              at com.serotonin.bacnet4j.type.constructed.ReadAccessResult$Result.<init>(ReadAccessResult.java:124)
                              ... 28 more
                              ... 31 more
                              at com.serotonin.bacnet4j.type.constructed.PriorityArray.<init>(PriorityArray.java:41)
                              ... 36 more
                              ... 38 more
                      Caused by: com.serotonin.bacnet4j.exception.BACnetErrorException
                              at com.serotonin.bacnet4j.type.Encodable.popStart(Encodable.java:109)
                              at com.serotonin.bacnet4j.type.AmbiguousValue.<init>(AmbiguousValue.java:11)
                              at com.serotonin.bacnet4j.type.constructed.PriorityValue.<init>(PriorityValue.java:83)
                              ... 43 more
                      Any Idea?
                      Arne
                        apl
                        Hi Matthew,
                        this happends by ObjectType == multiStateOutput and analogOutput
                        Arne
                          If the goal is to provide a set of simple examples, i would think the reporting of possible errors would just clutter things up.
                          But in any case, i still cannot reproduce this error. It appears to be an incorrectly formatted response. I expanded my test code to the following. It won't work for you because i added some convenience methods in the PropertyValues object, but i think you'll see what i'm getting at.
                                  LocalDevice localDevice = new LocalDevice(1234, &quot;192.168.0.255&quot;);
                                  localDevice.sendBroadcast(2068, new WhoIsRequest(null, null));
                                  Thread.sleep(1000);
                                  RemoteDevice d = localDevice.getRemoteDevices().get(0);
                                  ObjectIdentifier oid = new ObjectIdentifier(ObjectType.analogInput, 0);
                                  PropertyValues pvs = localDevice.readProperties(d, refs);
                                  for (ObjectPropertyReference opr : pvs)
                                      System.out.println(pvs.getNoErrorCheck(opr));
                                  Thread.sleep(2000);
                          The listener that returned the response is the SlaveDeviceTest example.
                            Hi Arne,
                            I have a fix for the PriorityArray (87). The class was not decoding properly. I have checked the updates into the CVS repo, but did not release a new version of the library. Here are the changes:
                            In PriorityArray, added an int to the constructor:
                                public PriorityArray(ByteQueue queue, int contextId) throws BACnetException {
                                    super(queue, PriorityValue.class, contextId);
                            In Encodable, added this method:
                                protected static &lt;T extends Encodable&gt; T readSequenceType(ByteQueue queue, Class&lt;T&gt; clazz, int contextId)
                                    popStart(queue, contextId);
                                    T result;
                                    try {
                                        result = clazz.getConstructor(new Class[] {ByteQueue.class, Integer.TYPE}).newInstance(
                                                new Object[] {queue, contextId});
                                    catch (Exception e) {
                                        throw new BACnetException(e);
                                    popEnd(queue, contextId);
                                    return result;
                            ... and added a call to that method in this method as shown:
                                protected static Encodable readEncodable(ByteQueue queue, ObjectType objectType,
                                        PropertyIdentifier propertyIdentifier, UnsignedInteger propertyArrayIndex, int contextId)
                                    // A property array index of 0 indicates a request for the length of an array.
                                    if (propertyArrayIndex != null && propertyArrayIndex.intValue() == 0)
                                        return readWrapped(queue, UnsignedInteger.class, contextId);
                                    if (!matchNonEndTag(queue, contextId))
                                        throw new BACnetErrorException(ErrorClass.property, ErrorCode.missingRequiredParameter);
                                    PropertyTypeDefinition def = ObjectProperties.getPropertyTypeDefinition(objectType, propertyIdentifier);
                                    if (def == null)
                                        return new AmbiguousValue(queue, contextId);
                                    if (propertyArrayIndex != null && !def.isSequence())
                                        throw new BACnetErrorException(ErrorClass.property, ErrorCode.propertyIsNotAList);
                                    if (propertyArrayIndex == null && def.isSequence())
                                        return readSequenceOf(queue, def.getClazz(), contextId);
                                    if (propertyArrayIndex == null && SequenceOf.class.isAssignableFrom(def.getClazz()))
                                        return readSequenceType(queue, def.getClazz(), contextId);
                                    return readWrapped(queue, def.getClazz(), contextId);
                            Can you let me know if this has any effect on the other types you mentioned (8 and 105).
                              apl
                              Thank you, iI got it from CVS.
                              so here is my next "streamlined" ex DiscoveryTest example
                              It sends a WhoIs Request, waits for the first device to answer (in doDiscover()).
                              And then it requests all available Properties with PropertyIdentifier.all.
                              Then it prints the properties sorted by ObjectId.
                              import com.serotonin.bacnet4j.type.constructed.ObjectPropertyReference;
                              import java.util.ArrayList;
                               * this is done by using PropertyIdentifier.all so the Device will send all propertys that are set.
                               * if you want poll all PropertyId {@link ReadPropertyRangeTest}.
                              public class ReadAllAvailabeProperties {
                                  // remote devices found
                                  private List<RemoteDevice> remoteDevices = new ArrayList<RemoteDevice>();
                                  public ReadAllAvailabeProperties(String broadcastAddress, int port) throws IOException {
                                              remoteDevices.add(d);
                                              synchronized (ReadAllAvailabeProperties.this) {
                                                  ReadAllAvailabeProperties.this.notifyAll();
                                              return true;
                                   * Send a WhoIs request and wait for the first to answer
                                      // Who is
                                          this.wait(2000);
                                      // An other way to get to the list of devices
                                      // return localDevice.getRemoteDevices();
                                  private void printDevices() throws BACnetException {
                                      for (RemoteDevice d : remoteDevices) {
                                          // add the property references of the "device object" to the list
                                          refs.add(d.getObjectIdentifier(), PropertyIdentifier.all);
                                          // and now from all objects under the device object >> ai0, ai1,bi0,bi1...
                                              refs.add(oid, PropertyIdentifier.all);
                                          System.out.println("Start read properties");
                                          System.out.println(String.format("Properties read done in %d ms", System.currentTimeMillis() - start));
                                          printObject(d.getObjectIdentifier(), pvs);
                                              printObject(oid, pvs);
                                  private void printObject(ObjectIdentifier oid, PropertyValues pvs) {
                                      System.out.println(String.format("\t%s", oid));
                                      for (ObjectPropertyReference opr : pvs) {
                                          if (oid.equals(opr.getObjectIdentifier())) {
                                              System.out.println(String.format("\t\t%s = %s", opr.getPropertyIdentifier().toString(), pvs.getNoErrorCheck(opr)));
                                   * @param args
                                      ReadAllAvailabeProperties dt = new ReadAllAvailabeProperties(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT);
                                      try {
                                      } catch (RuntimeException e) {
                                          throw e;
                                      try {
                                          dt.doDiscover();
                                          dt.printDevices();
                                      } finally {
                                      return loopDevice;
                              If you find this useful, you may add this to CVS.
                              If you interested, I would write a read specific property the old DiscoveryTest and a writeProperty test.
                              Arne
                                Hi Arne,
                                This looks great. I will add it to the distribution, but a couple things:
                                • I changed the class name from ReadAllAvailabeProperties to ReadAllAvailableProperties
                                • You reference a class named LoopDevice for which i don't have the code. Can you provide it? (Is it just a RemoteObject?)
                                  apl
                                  Ok,
                                  here we go:
                                  import com.serotonin.bacnet4j.type.enumerated.Reliability;
                                   * @author aploese
                                          ld.doTerminate();
                                          try {
                                                      return true;
                                              // for valid property values with valid datatypes see com.serotonin.bacnet4j.obj.ObjectProperties and ther look for the big static block at the end;
                                              // properties of device object
                                              localDevice.getConfiguration().setProperty(PropertyIdentifier.modelName, new CharacterString("BACnet4J LoopDevice"));
                                              ai0 = new BACnetObject(localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.analogInput));
                                              //mandatory properties
                                              ai0.setProperty(PropertyIdentifier.objectName, new CharacterString("G1-RLT03-TM-01")); // this is a cryptic encoded name of a temp sensor from a drawing... (ahm. actually taken from a book ;-))
                                              ai0.setProperty(PropertyIdentifier.presentValue, new Real((float)11));
                                              ai0.setProperty(PropertyIdentifier.outOfService, new Boolean(false));
                                              ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.degreesCelsius);
                                              //some optional properties
                                              ai0.setProperty(PropertyIdentifier.description, new CharacterString("temperature"));
                                              ai0.setProperty(PropertyIdentifier.deviceType, new CharacterString("random values"));
                                              ai0.setProperty(PropertyIdentifier.reliability, Reliability.noFaultDetected);
                                              ai0.setProperty(PropertyIdentifier.updateInterval, new UnsignedInteger(10));
                                              ai0.setProperty(PropertyIdentifier.minPresValue, new Real(-70));
                                              ai0.setProperty(PropertyIdentifier.maxPresValue, new Real(120));
                                              ai0.setProperty(PropertyIdentifier.resolution, new Real((float)0.1));
                                              ai0.setProperty(PropertyIdentifier.profileName, new CharacterString("funny reader"));
                                              localDevice.addObject(ai0);
                                              ai1.setProperty(PropertyIdentifier.units, EngineeringUnits.percentObscurationPerFoot);
                                              localDevice.addObject(ai1);
                                              localDevice.addObject(bi0);
                                              localDevice.addObject(bi1);
                                              localDevice.addObject(mso0);
                                              localDevice.addObject(ao0);
                                              System.out.println("Ex in LoopDevice() ");
                                              e.printStackTrace();
                                              localDevice = null;
                                              throw e;
                                      public void run() {
                                          try {
                                              // Let it go...
                                              float ai0value = 0;
                                              float ai1value = 0;
                                          localDevice = null;
                                      @Override
                                              localDevice = null;
                                          return terminate;
                                       * @return the port
                                          return localDevice;
                                       * @return the ai0
                                          return ai0;
                                       * @return the ai1
                                          return ai1;
                                       * @return the bi0
                                          return bi0;
                                       * @return the bi1
                                          return bi1;
                                       * @return the mso0
                                          return mso0;
                                       * @return the ao0
                                          return ao0;
                                  the classname was a typo, thank you.
                                  You (or probably me) can improve it to pass a broadcastaddress and timeout via main().
                                  Arne
                                    Ok, this has been added with one other change. In ReadAllAvailableProperties at line 220:
                                    ... changed to:
                                      akc
                                      I am also having problems running discovery test.
                                      Here is my error message:
                                      Exception in thread "main" java.lang.Error: Unresolved compilation problems:
                                      The import com.serotonin.util cannot be resolved
                                      ObjectUtils cannot be resolved
                                      at com.serotonin.bacnet4j.LocalDevice.<init>(LocalDevice.java:96)
                                      at DiscoveryTest.main(DiscoveryTest.java:22)
                                      I am missing the com.serotonin.util directory. Where do I get this file? I only have com.serotonin.bacnet4j.
                                      -Andrew
                                        You should have downloaded the seroUtils.jar file as well. This needs to be included in your classpath.
                                          akc
                                          Thanks mlohbihler. sorry for my novice question.
                                          -andrew
                                          • D Offline
                                            drubin
                                            To prevent hair loss for anyone who stumbles upon this thread looking for somewhere to start with bacnet4j... I could not find this code anywhere in the bacnet4j Java package. I created ReadAllAvailabeProperties and LoopDevice classes in my own package. In order for this code to work with the newer versions of bacnet4j I had to replace all occurrences of DeviceEventListener with DefaultDeviceEventListener in both classes. This was just guess but it apparently worked.
