<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Simple Examples]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I cant get the test-examples to work. I am new to bacnet - so I eventually missed something in DiscoveryTest and Test.</p>
<p dir="auto">My problem with the sources are the IP addresses (LocalDevice 192.168.60.255) maybe use the local loopback 127.0.0.255?<br />
The RemoteDevice uses 206.210.100.134 - use instead 127.0.0.1 as address?</p>
<p dir="auto">Or are these tests not intended to work as is in software only?</p>
<p dir="auto">Arne</p>
]]></description><link>https://forum.mango-os.com/topic/167/simple-examples</link><generator>RSS for Node</generator><lastBuildDate>Thu, 05 Mar 2026 07:48:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/167.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 May 2009 18:30:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Simple Examples on Wed, 09 Nov 2011 02:31:57 GMT]]></title><description><![CDATA[<p dir="auto">Nevermind on that last post... all the test classes which compile correctly can be found in the source archive: bacnet4J-src.zip which can be found here: <a href="http://sourceforge.net/projects/bacnet4j/files/bacnet4j/1.2/" rel="nofollow ugc">http://sourceforge.net/projects/bacnet4j/files/bacnet4j/1.2/</a></p>
<p dir="auto">The are not in bacnet4j.jar or seroUtils.jar</p>
<p dir="auto">I would still love to know the basic design of this package or a good description of the LocalDevice and RemoteDevice classes...</p>
]]></description><link>https://forum.mango-os.com/post/6014</link><guid isPermaLink="true">https://forum.mango-os.com/post/6014</guid><dc:creator><![CDATA[drubin]]></dc:creator><pubDate>Wed, 09 Nov 2011 02:31:57 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Tue, 08 Nov 2011 21:31:19 GMT]]></title><description><![CDATA[<p dir="auto">To prevent hair loss for anyone who stumbles upon this thread looking for somewhere to start with bacnet4j...  I could not find this code anywhere in the bacnet4j Java package.  I created ReadAllAvailabeProperties and LoopDevice classes in my own package.  In order for this code to work with the newer versions of bacnet4j I had to replace all occurrences of DeviceEventListener with DefaultDeviceEventListener in both classes.  This was just guess but it apparently worked.</p>
]]></description><link>https://forum.mango-os.com/post/6012</link><guid isPermaLink="true">https://forum.mango-os.com/post/6012</guid><dc:creator><![CDATA[drubin]]></dc:creator><pubDate>Tue, 08 Nov 2011 21:31:19 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Mon, 03 Aug 2009 17:57:21 GMT]]></title><description><![CDATA[<p dir="auto">Thanks mlohbihler. sorry for my novice question.<br />
-andrew</p>
]]></description><link>https://forum.mango-os.com/post/2647</link><guid isPermaLink="true">https://forum.mango-os.com/post/2647</guid><dc:creator><![CDATA[akc]]></dc:creator><pubDate>Mon, 03 Aug 2009 17:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 31 Jul 2009 20:37:49 GMT]]></title><description><![CDATA[<p dir="auto">You should have downloaded the seroUtils.jar file as well. This needs to be included in your classpath.</p>
]]></description><link>https://forum.mango-os.com/post/2646</link><guid isPermaLink="true">https://forum.mango-os.com/post/2646</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 31 Jul 2009 20:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 31 Jul 2009 20:00:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am also having problems running discovery test.<br />
Here is my error message:</p>
<p dir="auto">Exception in thread "main" java.lang.Error: Unresolved compilation problems:<br />
The import com.serotonin.util cannot be resolved<br />
ObjectUtils cannot be resolved</p>
<pre><code>at com.serotonin.bacnet4j.LocalDevice.&lt;init&gt;(LocalDevice.java:96)
at DiscoveryTest.main(DiscoveryTest.java:22)
<p dir="auto">I am missing the com.serotonin.util directory. Where do I get this file? I only have com.serotonin.bacnet4j.</p>
<p dir="auto">Thanks,<br />
-Andrew</p>
]]></description><link>https://forum.mango-os.com/post/2645</link><guid isPermaLink="true">https://forum.mango-os.com/post/2645</guid><dc:creator><![CDATA[akc]]></dc:creator><pubDate>Fri, 31 Jul 2009 20:00:02 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Mon, 01 Jun 2009 17:39:44 GMT]]></title><description><![CDATA[<p dir="auto">Ok, this has been added with one other change. In ReadAllAvailableProperties at line 220:</p>
<pre><code>        loopDevice = loopDevice;
<p dir="auto">... changed to:</p>
<pre><code>        this.loopDevice = loopDevice;
]]></description><link>https://forum.mango-os.com/post/2596</link><guid isPermaLink="true">https://forum.mango-os.com/post/2596</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 01 Jun 2009 17:39:44 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 29 May 2009 19:41:24 GMT]]></title><description><![CDATA[<p dir="auto">Ok,</p>
<p dir="auto">here we go:</p>
<pre><code>/*
 * GNU Lesser General Public License
 * Copyright (C) 2006-2009 Serotonin Software Technologies Inc. http://serotoninsoftware.com
 * @author Matthew Lohbihler
 * This library is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public
 * License as published by the Free Software Foundation; either
 * version 2.1 of the License, or (at your option) any later version.
 * This library is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 * Lesser General Public License for more details.
 * You should have received a copy of the GNU Lesser General Public
 * License along with this library; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307, USA.
package com.serotonin.bacnet4j.test;
import com.serotonin.bacnet4j.LocalDevice;
import com.serotonin.bacnet4j.RemoteDevice;
import com.serotonin.bacnet4j.RemoteObject;
import com.serotonin.bacnet4j.event.DeviceEventListener;
import com.serotonin.bacnet4j.exception.BACnetServiceException;
import com.serotonin.bacnet4j.obj.BACnetObject;
import com.serotonin.bacnet4j.type.Encodable;
import com.serotonin.bacnet4j.type.constructed.Choice;
import com.serotonin.bacnet4j.type.constructed.PropertyValue;
import com.serotonin.bacnet4j.type.constructed.SequenceOf;
import com.serotonin.bacnet4j.type.constructed.TimeStamp;
import com.serotonin.bacnet4j.type.enumerated.BinaryPV;
import com.serotonin.bacnet4j.type.enumerated.EngineeringUnits;
import com.serotonin.bacnet4j.type.enumerated.EventState;
import com.serotonin.bacnet4j.type.enumerated.EventType;
import com.serotonin.bacnet4j.type.enumerated.MessagePriority;
import com.serotonin.bacnet4j.type.enumerated.NotifyType;
import com.serotonin.bacnet4j.type.enumerated.ObjectType;
import com.serotonin.bacnet4j.type.enumerated.PropertyIdentifier;
import com.serotonin.bacnet4j.type.enumerated.Reliability;
import com.serotonin.bacnet4j.type.notificationParameters.NotificationParameters;
import com.serotonin.bacnet4j.type.primitive.Boolean;
import com.serotonin.bacnet4j.type.primitive.CharacterString;
import com.serotonin.bacnet4j.type.primitive.ObjectIdentifier;
import com.serotonin.bacnet4j.type.primitive.Real;
import com.serotonin.bacnet4j.type.primitive.UnsignedInteger;
import java.io.IOException;
 * software only device default local loop ;-)
 * @author mlohbihler
 * @author aploese
public class LoopDevice implements Runnable {
        LoopDevice ld = new LoopDevice("127.0.0.255", LocalDevice.DEFAULT_PORT + 1);
        Thread.sleep(12000); // wait 2 min
        ld.doTerminate();
    private boolean terminate;
    private LocalDevice localDevice;
    private BACnetObject ai0;
    private BACnetObject ai1;
    private BACnetObject bi0;
    private BACnetObject bi1;
    private BACnetObject mso0;
    private BACnetObject ao0;
    public LoopDevice(String broadcastAddress, int port) throws BACnetServiceException, IOException {
        localDevice = new LocalDevice(1968, broadcastAddress);
        try {
            localDevice.setPort(port);
            localDevice.getEventHandler().addListener(new DeviceEventListener() {
                public void listenerException(Throwable e) {
                    System.out.println("loopDevice listenerException");
                public void iAmReceived(RemoteDevice d) {
                    System.out.println("loopDevice iAmReceived");
                public boolean allowPropertyWrite(BACnetObject obj, PropertyValue pv) {
                    System.out.println("loopDevice allowPropertyWrite");
                    return true;
                public void propertyWritten(BACnetObject obj, PropertyValue pv) {
                    System.out.println("loopDevice propertyWritten");
                public void iHaveReceived(RemoteDevice d, RemoteObject o) {
                    System.out.println("loopDevice iHaveReceived");
                public void covNotificationReceived(UnsignedInteger subscriberProcessIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier monitoredObjectIdentifier, UnsignedInteger timeRemaining, SequenceOf&lt;PropertyValue&gt; listOfValues) {
                    System.out.println("loopDevice covNotificationReceived");
                public void eventNotificationReceived(UnsignedInteger processIdentifier, RemoteDevice initiatingDevice, ObjectIdentifier eventObjectIdentifier, TimeStamp timeStamp, UnsignedInteger notificationClass, UnsignedInteger priority, EventType eventType, CharacterString messageText, NotifyType notifyType, Boolean ackRequired, EventState fromState, EventState toState, NotificationParameters eventValues) {
                    System.out.println("loopDevice eventNotificationReceived");
                public void textMessageReceived(RemoteDevice textMessageSourceDevice, Choice messageClass, MessagePriority messagePriority, CharacterString message) {
                    System.out.println("loopDevice textMessageReceived");
                public void privateTransferReceived(UnsignedInteger vendorId, UnsignedInteger serviceNumber, Encodable serviceParameters) {
                    System.out.println("loopDevice privateTransferReceived");
            // for valid property values with valid datatypes see com.serotonin.bacnet4j.obj.ObjectProperties and ther look for the big static block at the end;
            // properties of device object
            localDevice.getConfiguration().setProperty(PropertyIdentifier.modelName, new CharacterString("BACnet4J LoopDevice"));
            // Set up a few objects.
            ai0 = new BACnetObject(localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.analogInput));
            //mandatory properties
            ai0.setProperty(PropertyIdentifier.objectName, new CharacterString("G1-RLT03-TM-01")); // this is a cryptic encoded name of a temp sensor from a drawing... (ahm. actually taken from a book ;-))
            ai0.setProperty(PropertyIdentifier.presentValue, new Real((float)11));
            ai0.setProperty(PropertyIdentifier.outOfService, new Boolean(false));
            ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.degreesCelsius);
            //some optional properties
            ai0.setProperty(PropertyIdentifier.description, new CharacterString("temperature"));
            ai0.setProperty(PropertyIdentifier.deviceType, new CharacterString("random values"));
            ai0.setProperty(PropertyIdentifier.reliability, Reliability.noFaultDetected);
            ai0.setProperty(PropertyIdentifier.updateInterval, new UnsignedInteger(10));
            ai0.setProperty(PropertyIdentifier.minPresValue, new Real(-70));
            ai0.setProperty(PropertyIdentifier.maxPresValue, new Real(120));
            ai0.setProperty(PropertyIdentifier.resolution, new Real((float)0.1));
            ai0.setProperty(PropertyIdentifier.profileName, new CharacterString("funny reader"));
            localDevice.addObject(ai0);
            ai1 = new BACnetObject(
            ai1.setProperty(PropertyIdentifier.units, EngineeringUnits.percentObscurationPerFoot);
            localDevice.addObject(ai1);
            bi0 = new BACnetObject(
                    localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.binaryInput));
            localDevice.addObject(bi0);
            bi0.setProperty(PropertyIdentifier.objectName, new CharacterString("Off and on"));
            bi0.setProperty(PropertyIdentifier.inactiveText, new CharacterString("Off"));
            bi0.setProperty(PropertyIdentifier.activeText, new CharacterString("On"));
            bi1 = new BACnetObject(
            localDevice.addObject(bi1);
            bi1.setProperty(PropertyIdentifier.objectName, new CharacterString("Good and bad"));
            bi1.setProperty(PropertyIdentifier.inactiveText, new CharacterString("Bad"));
            bi1.setProperty(PropertyIdentifier.activeText, new CharacterString("Good"));
            mso0 = new BACnetObject(
                    localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.multiStateOutput));
            mso0.setProperty(PropertyIdentifier.objectName, new CharacterString("Vegetable"));
            mso0.setProperty(PropertyIdentifier.numberOfStates, new UnsignedInteger(4));
            mso0.setProperty(PropertyIdentifier.stateText, 1, new CharacterString("Tomato"));
            mso0.setProperty(PropertyIdentifier.stateText, 2, new CharacterString("Potato"));
            mso0.setProperty(PropertyIdentifier.stateText, 3, new CharacterString("Onion"));
            mso0.setProperty(PropertyIdentifier.stateText, 4, new CharacterString("Broccoli"));
            mso0.setProperty(PropertyIdentifier.presentValue, new UnsignedInteger(1));
            localDevice.addObject(mso0);
            ao0 = new BACnetObject(
                    localDevice, localDevice.getNextInstanceObjectIdentifier(ObjectType.analogOutput));
            ao0.setProperty(PropertyIdentifier.objectName, new CharacterString("Settable analog"));
            localDevice.addObject(ao0);
            // Start the local device.
            localDevice.initialize();
            new Thread(this).start();
        } catch (RuntimeException e) {
            System.out.println("Ex in LoopDevice() ");
            e.printStackTrace();
            localDevice.terminate();
            localDevice = null;
            throw e;
    public void run() {
        try {
            System.out.println("LoopDevice start changing values" + this);
            // Let it go...
            float ai0value = 0;
            float ai1value = 0;
            boolean bi0value = false;
            boolean bi1value = false;
            getMso0().setProperty(PropertyIdentifier.presentValue, new UnsignedInteger(2));
            while (!isTerminate()) {
                System.out.print("Change values of LoopDevice " + this);
                // Update the values in the objects.
                ai0.setProperty(PropertyIdentifier.presentValue, new Real(ai0value));
                ai1.setProperty(PropertyIdentifier.presentValue, new Real(ai1value));
                bi0.setProperty(PropertyIdentifier.presentValue, bi0value ? BinaryPV.active : BinaryPV.inactive);
                bi1.setProperty(PropertyIdentifier.presentValue, bi1value ? BinaryPV.active : BinaryPV.inactive);
                synchronized (this) {
                    wait(1000); // 1 second or notified (faster exit then stupid wait for 1 second)
            System.out.println("Close LoopDevive " + this);
        } catch (Exception ex) {
        localDevice = null;
    @Override
    protected void finalize() throws Throwable {
        if (localDevice != null) {
            localDevice = null;
     * @return the terminate
    public boolean isTerminate() {
        return terminate;
     * @param terminate the terminate to set
    public void doTerminate() {
        this.terminate = true;
            this.notifyAll(); // we may wait for this in run() ...
     * @return the broadcastAddress
    public String getBroadcastAddress() {
        return localDevice.getBroadcastAddress();
     * @return the port
    public int getPort() {
        return localDevice.getPort();
     * @return the localDevice
    public LocalDevice getLocalDevice() {
        return localDevice;
     * @return the ai0
    public BACnetObject getAi0() {
        return ai0;
     * @return the ai1
    public BACnetObject getAi1() {
        return ai1;
     * @return the bi0
    public BACnetObject getBi0() {
        return bi0;
     * @return the bi1
    public BACnetObject getBi1() {
        return bi1;
     * @return the mso0
    public BACnetObject getMso0() {
        return mso0;
     * @return the ao0
    public BACnetObject getAo0() {
        return ao0;
<p dir="auto">the classname was a typo, thank you.</p>
<p dir="auto">You (or probably me) can improve it to pass a broadcastaddress and timeout via main().</p>
]]></description><link>https://forum.mango-os.com/post/2595</link><guid isPermaLink="true">https://forum.mango-os.com/post/2595</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Fri, 29 May 2009 19:41:24 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 29 May 2009 14:03:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi Arne,</p>
<p dir="auto">This looks great. I will add it to the distribution, but a couple things:</p>
<ul>
<li>
<p dir="auto">I changed the class name from ReadAllAvailabeProperties to ReadAllAvailableProperties</p>
</li>
<li>
<p dir="auto">You reference a class named LoopDevice for which i don't have the code. Can you provide it? (Is it just a RemoteObject?)</p>
</li>
</ul>
]]></description><link>https://forum.mango-os.com/post/2593</link><guid isPermaLink="true">https://forum.mango-os.com/post/2593</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 29 May 2009 14:03:10 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 29 May 2009 09:41:11 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, iI got it from CVS.</p>
<p dir="auto">so here is my next "streamlined" ex DiscoveryTest example</p>
<p dir="auto">It sends a WhoIs Request, waits for the first device to answer (in doDiscover()).<br />
And then it requests all available Properties with PropertyIdentifier.all.<br />
Then it prints the properties sorted by ObjectId.</p>
<pre><code>/*
import com.serotonin.bacnet4j.exception.BACnetException;
import java.util.List;
import com.serotonin.bacnet4j.service.unconfirmed.WhoIsRequest;
import com.serotonin.bacnet4j.type.constructed.ObjectPropertyReference;
import com.serotonin.bacnet4j.util.PropertyReferences;
import com.serotonin.bacnet4j.util.PropertyValues;
import java.util.ArrayList;
 * Discovers and devices and print all properties of all objects found.
 * this is done by using PropertyIdentifier.all so the Device will send all propertys that are set.
 * if you want poll all PropertyId {@link ReadPropertyRangeTest}.
 * @author Arne Plöse
public class ReadAllAvailabeProperties {
    public static String BROADCAST_ADDRESS = "127.0.0.255";
    private LoopDevice loopDevice;
    // remote devices found
    private List&lt;RemoteDevice&gt; remoteDevices = new ArrayList&lt;RemoteDevice&gt;();
    public ReadAllAvailabeProperties(String broadcastAddress, int port) throws IOException {
        localDevice = new LocalDevice(1234, broadcastAddress);
                System.out.println("DiscoveryTest listenerException");
                System.out.println("DiscoveryTest iAmReceived");
                remoteDevices.add(d);
                synchronized (ReadAllAvailabeProperties.this) {
                    ReadAllAvailabeProperties.this.notifyAll();
                System.out.println("DiscoveryTest allowPropertyWrite");
                return true;
                System.out.println("DiscoveryTest propertyWritten");
                System.out.println("DiscoveryTest iHaveReceived");
                System.out.println("DiscoveryTest covNotificationReceived");
                System.out.println("DiscoveryTest eventNotificationReceived");
                System.out.println("DiscoveryTest textMessageReceived");
                System.out.println("DiscoveryTest privateTransferReceived");
     * Send a WhoIs request and wait for the first to answer
     * @throws java.lang.Exception
    public void doDiscover() throws Exception {
        // Who is
        System.out.println("Send Broadcast WhoIsRequest() ");
        // Send the broadcast to the correct port of the LoopDevice !!!
        localDevice.sendBroadcast(loopDevice.getPort(), new WhoIsRequest(null, null));
        // wait for notification in iAmReceived() Timeout 2 sec
            final long start = System.currentTimeMillis();
            this.wait(2000);
            System.out.println(" waited for iAmReceived: " + (System.currentTimeMillis() - start) + " ms");
        // An other way to get to the list of devices
        // return localDevice.getRemoteDevices();
    private void printDevices() throws BACnetException {
        for (RemoteDevice d : remoteDevices) {
            localDevice.getExtendedDeviceInformation(d);
            List&lt;ObjectIdentifier&gt; oids = ((SequenceOf&lt;ObjectIdentifier&gt;) localDevice.sendReadPropertyAllowNull(
                    d, d.getObjectIdentifier(), PropertyIdentifier.objectList)).getValues();
            PropertyReferences refs = new PropertyReferences();
            // add the property references of the "device object" to the list
            refs.add(d.getObjectIdentifier(), PropertyIdentifier.all);
            // and now from all objects under the device object &gt;&gt; ai0, ai1,bi0,bi1...
            for (ObjectIdentifier oid : oids) {
                refs.add(oid, PropertyIdentifier.all);
            System.out.println("Start read properties");
            PropertyValues pvs = localDevice.readProperties(d, refs);
            System.out.println(String.format("Properties read done in %d ms", System.currentTimeMillis() - start));
            printObject(d.getObjectIdentifier(), pvs);
                printObject(oid, pvs);
        System.out.println("Remote devices done...");
    private void printObject(ObjectIdentifier oid, PropertyValues pvs) {
        System.out.println(String.format("\t%s", oid));
        for (ObjectPropertyReference opr : pvs) {
            if (oid.equals(opr.getObjectIdentifier())) {
                System.out.println(String.format("\t\t%s = %s", opr.getPropertyIdentifier().toString(), pvs.getNoErrorCheck(opr)));
     * Note same Bropadcast address, but different ports!!!
     * @param args
    @SuppressWarnings("unchecked")
        ReadAllAvailabeProperties dt = new ReadAllAvailabeProperties(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT);
        try {
            dt.setLoopDevice(new LoopDevice(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT + 1));
            dt.localDevice.terminate();
            throw e;
        try {
            dt.doDiscover();
            dt.printDevices();
        } finally {
            System.out.println("Cleanup loopDevice");
            dt.getLoopDevice().doTerminate();
     * @return the loopDevice
    public LoopDevice getLoopDevice() {
        return loopDevice;
     * @param loopDevice the loopDevice to set
    public void setLoopDevice(LoopDevice loopDevice) {
<p dir="auto">If you find this useful, you may add this to CVS.</p>
<p dir="auto">If you interested, I would write a read specific property the old DiscoveryTest and a writeProperty test.</p>
]]></description><link>https://forum.mango-os.com/post/2592</link><guid isPermaLink="true">https://forum.mango-os.com/post/2592</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Fri, 29 May 2009 09:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Fri, 29 May 2009 01:05:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi Arne,</p>
<p dir="auto">I have a fix for the PriorityArray (87). The class was not decoding properly. I have checked the updates into the CVS repo, but did not release a new version of the library. Here are the changes:</p>
<p dir="auto">In PriorityArray, added an int to the constructor:</p>
<pre><code>    public PriorityArray(ByteQueue queue, int contextId) throws BACnetException {
        super(queue, PriorityValue.class, contextId);
<p dir="auto">In Encodable, added this method:</p>
<pre><code>    protected static &amp;lt;T extends Encodable&amp;gt; T readSequenceType(ByteQueue queue, Class&amp;lt;T&amp;gt; clazz, int contextId)
        popStart(queue, contextId);
        T result;
        try {
            result = clazz.getConstructor(new Class[] {ByteQueue.class, Integer.TYPE}).newInstance(
                    new Object[] {queue, contextId});
        catch (Exception e) {
            throw new BACnetException(e);
        popEnd(queue, contextId);
        return result;
<p dir="auto">... and added a call to that method in this method as shown:</p>
<pre><code>    protected static Encodable readEncodable(ByteQueue queue, ObjectType objectType,
            PropertyIdentifier propertyIdentifier, UnsignedInteger propertyArrayIndex, int contextId)
        // A property array index of 0 indicates a request for the length of an array.
        if (propertyArrayIndex != null &amp;&amp; propertyArrayIndex.intValue() == 0)
            return readWrapped(queue, UnsignedInteger.class, contextId);
        if (!matchNonEndTag(queue, contextId))
            throw new BACnetErrorException(ErrorClass.property, ErrorCode.missingRequiredParameter);
        PropertyTypeDefinition def = ObjectProperties.getPropertyTypeDefinition(objectType, propertyIdentifier);
        if (def == null)
            return new AmbiguousValue(queue, contextId);
        if (propertyArrayIndex != null &amp;&amp; !def.isSequence())
            throw new BACnetErrorException(ErrorClass.property, ErrorCode.propertyIsNotAList);
        if (propertyArrayIndex == null &amp;&amp; def.isSequence())
            return readSequenceOf(queue, def.getClazz(), contextId);
        if (propertyArrayIndex == null &amp;&amp; SequenceOf.class.isAssignableFrom(def.getClazz()))
            return readSequenceType(queue, def.getClazz(), contextId);
        return readWrapped(queue, def.getClazz(), contextId);
<p dir="auto">Can you let me know if this has any effect on the other types you mentioned (8 and 105).</p>
]]></description><link>https://forum.mango-os.com/post/2590</link><guid isPermaLink="true">https://forum.mango-os.com/post/2590</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 29 May 2009 01:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 14:32:22 GMT]]></title><description><![CDATA[<p dir="auto">If the goal is to provide a set of simple examples, i would think the reporting of possible errors would just clutter things up.</p>
<p dir="auto">But in any case, i still cannot reproduce this error. It appears to be an incorrectly formatted response. I expanded my test code to the following. It won't work for you because i added some convenience methods in the PropertyValues object, but i think you'll see what i'm getting at.</p>
<pre><code>        LocalDevice localDevice = new LocalDevice(1234, &amp;quot;192.168.0.255&amp;quot;);
        localDevice.sendBroadcast(2068, new WhoIsRequest(null, null));
        Thread.sleep(1000);
        RemoteDevice d = localDevice.getRemoteDevices().get(0);
        ObjectIdentifier oid = new ObjectIdentifier(ObjectType.analogInput, 0);
        for (int i=0; i&amp;lt200; i++)
            refs.add(oid, new PropertyIdentifier(i));
            System.out.println(pvs.getNoErrorCheck(opr));
        Thread.sleep(2000);
<p dir="auto">The listener that returned the response is the SlaveDeviceTest example.</p>
]]></description><link>https://forum.mango-os.com/post/2589</link><guid isPermaLink="true">https://forum.mango-os.com/post/2589</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 28 May 2009 14:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 14:22:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matthew,</p>
<p dir="auto">this happends by ObjectType == multiStateOutput and analogOutput</p>
]]></description><link>https://forum.mango-os.com/post/2588</link><guid isPermaLink="true">https://forum.mango-os.com/post/2588</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Thu, 28 May 2009 14:22:29 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 14:06:40 GMT]]></title><description><![CDATA[<p dir="auto">Sorry,</p>
<p dir="auto">I thought this belongs also to create a bunch of example that runs out of the box.</p>
<p dir="auto">OK, here is my stack trace:</p>
<pre><code>com.serotonin.bacnet4j.exception.BACnetException: java.lang.reflect.InvocationTargetException
        at com.serotonin.bacnet4j.type.Encodable.read(Encodable.java:168)
        at com.serotonin.bacnet4j.type.constructed.SequenceOf.&lt;init&gt;(SequenceOf.java:54)
        at com.serotonin.bacnet4j.type.Encodable.readSequenceOf(Encodable.java:213)
        at com.serotonin.bacnet4j.service.acknowledgement.ReadPropertyMultipleAck.&lt;init&gt;(ReadPropertyMultipleAck.java:50)
        at com.serotonin.bacnet4j.service.acknowledgement.AcknowledgementService.createAcknowledgementService(AcknowledgementService.java:48)
        at com.serotonin.bacnet4j.apdu.ComplexACK.parseServiceData(ComplexACK.java:196)
        at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.waitForAck(IpMessageControl.java:658)
        at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:288)
        at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:268)
        at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.send(IpMessageControl.java:224)
        at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:411)
        at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:399)
        at com.serotonin.bacnet4j.LocalDevice.send(LocalDevice.java:392)
        at com.serotonin.bacnet4j.LocalDevice.readProperties(LocalDevice.java:760)
        at com.serotonin.bacnet4j.test.DiscoveryTest.doDiscover(DiscoveryTest.java:155)
        at com.serotonin.bacnet4j.test.DiscoveryTest.main(DiscoveryTest.java:187)
Caused by: java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
        at com.serotonin.bacnet4j.type.Encodable.read(Encodable.java:165)
        ... 15 more
Caused by: com.serotonin.bacnet4j.exception.BACnetException: java.lang.reflect.InvocationTargetException
        at com.serotonin.bacnet4j.type.constructed.SequenceOf.&lt;init&gt;(SequenceOf.java:66)
        at com.serotonin.bacnet4j.type.Encodable.readSequenceOf(Encodable.java:224)
        at com.serotonin.bacnet4j.type.Encodable.readOptionalSequenceOf(Encodable.java:233)
        at com.serotonin.bacnet4j.type.constructed.ReadAccessResult.&lt;init&gt;(ReadAccessResult.java:64)
        ... 20 more
        at sun.reflect.GeneratedConstructorAccessor3.newInstance(Unknown Source)
        ... 24 more
        at com.serotonin.bacnet4j.type.Encodable.readWrapped(Encodable.java:318)
        at com.serotonin.bacnet4j.type.Encodable.readEncodable(Encodable.java:263)
        at com.serotonin.bacnet4j.type.constructed.ReadAccessResult$Result.&lt;init&gt;(ReadAccessResult.java:124)
        ... 28 more
        ... 31 more
        at com.serotonin.bacnet4j.type.constructed.PriorityArray.&lt;init&gt;(PriorityArray.java:41)
        ... 36 more
        ... 38 more
Caused by: com.serotonin.bacnet4j.exception.BACnetErrorException
        at com.serotonin.bacnet4j.type.Encodable.popStart(Encodable.java:109)
        at com.serotonin.bacnet4j.type.AmbiguousValue.&lt;init&gt;(AmbiguousValue.java:11)
        at com.serotonin.bacnet4j.type.constructed.PriorityValue.&lt;init&gt;(PriorityValue.java:83)
        ... 43 more
<p dir="auto">Any Idea?</p>
]]></description><link>https://forum.mango-os.com/post/2587</link><guid isPermaLink="true">https://forum.mango-os.com/post/2587</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Thu, 28 May 2009 14:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 13:39:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Arne,</p>
<p dir="auto">I can't reproduce the problem. This code worked fine for me:</p>
<pre><code>    public static void main(String[] args) throws Exception {
        ObjectIdentifier oid = new ObjectIdentifier(ObjectType.accumulator, 0);
<p dir="auto">A stack trace goes a long way to explaining things. Maybe you can include that if you still have this problem.</p>
<p dir="auto">Also, can you please start a new topic when you are changing subject. This thread is getting too expansive.</p>
]]></description><link>https://forum.mango-os.com/post/2586</link><guid isPermaLink="true">https://forum.mango-os.com/post/2586</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 28 May 2009 13:39:22 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 13:08:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matthew,</p>
<p dir="auto">the offending PropertyId are: 8, 87, 105, which throw a java.lang.reflect.InvocationTargetException.</p>
<p dir="auto">Should I file a bug against it in the SF bug parade?</p>
]]></description><link>https://forum.mango-os.com/post/2585</link><guid isPermaLink="true">https://forum.mango-os.com/post/2585</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Thu, 28 May 2009 13:08:23 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Thu, 28 May 2009 07:56:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">trying to read all property values by using this changed code in :</p>
<pre><code>    private void addPropertyReferences(PropertyReferences refs, ObjectIdentifier oid) {
        for (int i = 0; i &lt; 12; i++) {
            refs.add(oid, new PropertyIdentifier(75 + i));
<p dir="auto">and choose values greater of 12 &gt;&gt; the app will fail.</p>
<p dir="auto">Any hints?</p>
]]></description><link>https://forum.mango-os.com/post/2584</link><guid isPermaLink="true">https://forum.mango-os.com/post/2584</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Thu, 28 May 2009 07:56:15 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Wed, 27 May 2009 14:22:52 GMT]]></title><description><![CDATA[<p dir="auto">This is excellent Arne. Thanks very much for sharing your work.</p>
]]></description><link>https://forum.mango-os.com/post/2583</link><guid isPermaLink="true">https://forum.mango-os.com/post/2583</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 27 May 2009 14:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Wed, 27 May 2009 08:21:32 GMT]]></title><description><![CDATA[<p dir="auto">So this two classes should work straight out of the box on any machine ;-)</p>
<p dir="auto">DeviceTest</p>
<pre><code>/*
import com.serotonin.bacnet4j.type.constructed.BACnetError;
import com.serotonin.bacnet4j.type.constructed.PropertyReference;
public class DiscoveryTest {
    public DiscoveryTest(String broadcastAddress, int port) throws IOException {
                synchronized (DiscoveryTest.this) {
                    DiscoveryTest.this.notifyAll();
                return true;
        // Who is
            this.wait(2000);
        System.out.println("Start iterating remote devices");
        // Get extended information for all remote devices.
        for (RemoteDevice d : localDevice.getRemoteDevices()) {
                addPropertyReferences(refs, oid);
            System.out.println("Values of d: " + d);
            try {
                // Send the read request.
                PropertyValues values = localDevice.readProperties(d, refs);
                // Dereference the property values back into the points.
                    printObject(oid, refs, values);
            } catch (BACnetException e) {
                System.out.println("event.bacnet.readDevice ADDRESS: " + e.getMessage());
     * @param args
        DiscoveryTest dt = new DiscoveryTest(BROADCAST_ADDRESS, LocalDevice.DEFAULT_PORT);
        try {
            dt.doDiscover();
        } finally {
        refs.add(oid, PropertyIdentifier.objectName);
        ObjectType type = oid.getObjectType();
        if (ObjectType.accumulator.equals(type)) {
            refs.add(oid, PropertyIdentifier.units);
        } else if (ObjectType.analogInput.equals(type) ||
                ObjectType.analogOutput.equals(type) ||
                ObjectType.analogValue.equals(type) ||
                ObjectType.pulseConverter.equals(type)) {
        } else if (ObjectType.binaryInput.equals(type) ||
                ObjectType.binaryOutput.equals(type) ||
                ObjectType.binaryValue.equals(type)) {
            refs.add(oid, PropertyIdentifier.inactiveText);
            refs.add(oid, PropertyIdentifier.activeText);
        } else if (ObjectType.lifeSafetyPoint.equals(type)) {
        } else if (ObjectType.loop.equals(type)) {
            refs.add(oid, PropertyIdentifier.outputUnits);
        } else if (ObjectType.multiStateInput.equals(type) ||
                ObjectType.multiStateOutput.equals(type) ||
                ObjectType.multiStateValue.equals(type)) {
            refs.add(oid, PropertyIdentifier.stateText);
        } else {
            return;
        refs.add(oid, PropertyIdentifier.presentValue);
        return loopDevice;
    private void printObject(ObjectIdentifier oid, PropertyReferences refs, PropertyValues values) {
        System.out.println("\t" + oid);
        // print propertie
        for (PropertyReference pr : refs.getProperties().get(oid)) {
            Encodable encodable = values.getNoErrorCheck(oid, pr);
            if (encodable == null) {
                System.out.println("event.bacnet.readError: no value returned");
            } else if (encodable instanceof BACnetError) {
                System.out.println("event.bacnet.readError NAME: " + ((BACnetError) encodable).getErrorCode());
            } else {
                System.out.println(String.format("\t\t %s = %s", pr.getPropertyIdentifier(), encodable.toString()));
<p dir="auto">LoopDevice</p>
<pre><code>/*
 * @author aploese
        ld.doTerminate();
                return true;
        ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.centimeters);
        localDevice.addObject(getAi0());
        ai0.setProperty(PropertyIdentifier.units, EngineeringUnits.percentObscurationPerFoot);
        localDevice.addObject(getAi1());
        localDevice.addObject(getBi0());
        localDevice.addObject(getBi1());
        localDevice.addObject(getMso0());
        localDevice.addObject(getAo0());
    public void run() {
        try {
            // Let it go...
            float ai0value = 0;
            float ai1value = 0;
                // Change the values.
                ai0value += 0.1;
                ai1value += 0.7;
                bi0value = !bi0value;
                bi1value = !bi1value;
        localDevice = null;
    @Override
            localDevice = null;
        return terminate;
     * @return the port
        return localDevice;
     * @return the ai0
        return ai0;
     * @return the ai1
        return ai1;
     * @return the bi0
        return bi0;
     * @return the bi1
        return bi1;
     * @return the mso0
        return mso0;
     * @return the ao0
        return ao0;
]]></description><link>https://forum.mango-os.com/post/2582</link><guid isPermaLink="true">https://forum.mango-os.com/post/2582</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Wed, 27 May 2009 08:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Wed, 27 May 2009 01:16:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Are you Interested in the changed code?<br />
Sure, if you think it will help other users, post it up.</p>
<p dir="auto">next: How to read the Properties of the objects<br />
You send some form of a "read properties" request. Below is a snippet of how Mango does it. It's contextual to Mango, but i think you should be able to figure out what is going on.</p>
<pre><code>    private void pollDevice(RemoteDevice d, List&amp;lt;DataPointRT&amp;gt; points, long time) {
        // Gather the points into a list of point references.
        for (DataPointRT dp : points) {
            BACnetIPPointLocatorRT locator = (BACnetIPPointLocatorRT)dp.getPointLocator();
            refs.add(locator.getOid(), locator.getPid());
        try {
                Encodable encodable = values.getNoErrorCheck(locator.getOid(), locator.getPid());
                    fireDeviceExceptionEvent("event.bacnet.readError", dp.getVO().getName(), "no value returned");
                            ((BACnetError)encodable).getErrorCode());
                else {
                    Object value = encodableToValue(encodable, dp.getDataTypeId());
                    dp.updatePointValue(new PointValueTime(value, time));
            fireMessageExceptionEvent("event.bacnet.readDevice", d.getAddress().toIpString(), e.getMessage());
]]></description><link>https://forum.mango-os.com/post/2581</link><guid isPermaLink="true">https://forum.mango-os.com/post/2581</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 27 May 2009 01:16:24 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Tue, 26 May 2009 18:46:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, step done ...</p>
<p dir="auto">Are you Interested in the changed code?</p>
<p dir="auto">next: How to read the Properties of the objects ai0,ai1,bi0,bi1,msg0,ao0 set by SimpleTest? - or in which testfiles are there?</p>
]]></description><link>https://forum.mango-os.com/post/2580</link><guid isPermaLink="true">https://forum.mango-os.com/post/2580</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Tue, 26 May 2009 18:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Tue, 26 May 2009 12:47:35 GMT]]></title><description><![CDATA[<p dir="auto">Oh, as an explanation of why you got that error... You created the RemoteDevice yourself and added it to your list of remote devices with "localDevice.addRemoteDevice(rd);". Then, in the loop, you asked this remote device for a property that it does not have (because you didn't give the property to it). So, you got an "Unknown Object" error.</p>
]]></description><link>https://forum.mango-os.com/post/2579</link><guid isPermaLink="true">https://forum.mango-os.com/post/2579</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 26 May 2009 12:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Tue, 26 May 2009 12:44:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Arne,</p>
<p dir="auto">I think i see what the problem is. The DiscoveryTest code has been modified over time to suit some different tests, and so not all of the code in there is necessary for what you want to do. In particular you do not need to declare remote devices yourself - this would defeat the purpose of discovery after all. All the code you should need is this (I have not compiled or tested this, so modify as required):</p>
<pre><code>
        LocalDevice localDevice = new LocalDevice(1234, "192.168.0.255");
        // Who is
        // Wait a bit for responses to come in.
        Thread.sleep(1000);
           ... use existing code
        Thread.sleep(2000);
<p dir="auto">Change port numbers as you see fit. In this example i've assumed that some remote device is running on port 2068 - presumably the SlaveDeviceTest example.</p>
<p dir="auto">I mentioned before an issue with commercial products not handling non-standard ports properly. If i recall correctly, this issue is as follows. Say i create a LocalDevice listening on port 8000. I use this to send a WhoIs broadcast to port 0xBAC0 (the standard port). Many commercial packages will return their IAm response over port 0xBAC0, which is incorrect. The original port 8000 is available to the remote device, but for whatever reason it is not used. Please be aware of this may happen when you are creating your BACnet network. BACnet4J handles its use of ports correctly.</p>
]]></description><link>https://forum.mango-os.com/post/2578</link><guid isPermaLink="true">https://forum.mango-os.com/post/2578</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 26 May 2009 12:44:07 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Tue, 26 May 2009 07:34:23 GMT]]></title><description><![CDATA[<p dir="auto">I changedt the IP-Addresses to localhost ans set the Port of the localDevice to default +1.<br />
running this I get an:</p>
<p dir="auto">com.serotonin.bacnet4j.exception.ErrorAPDUException: ErrorAPDU(choice=12, errorClass=Object, errorCode=Unknown object</p>
<p dir="auto">at: localDevice.getExtendedDeviceInformation(d);</p>
<p dir="auto">Any Idea what happend?</p>
<pre><code>
        LocalDevice localDevice = new LocalDevice(1234, "127.0.0.255");
        localDevice.setPort(LocalDevice.DEFAULT_PORT + 1);
        try {
            RemoteDevice rd = new RemoteDevice(105, new Address(new UnsignedInteger(LocalDevice.DEFAULT_PORT),
                    new OctetString(new byte[]{127, 0, 0, 1})), null);
            rd.setSegmentationSupported(Segmentation.segmentedBoth);
            rd.setMaxAPDULengthAccepted(1476);
            Thread.sleep(2000);
                System.out.println(d);
            Thread.sleep(2000);
        } finally {
<p dir="auto">If you add the following constructot to OctetSting:</p>
<pre><code>    public OctetString(int ... intValues) {
        this.value = new byte[intValues.length];
        for (int i = 0; i &lt; intValues.length; i++) {
            this.value* = (byte)intValues*;
<p dir="auto">One can write ```<br />
new OctetString(206, 210, 100, 134);</p>
<pre><code class="language-:wink:">
Arne
]]></description><link>https://forum.mango-os.com/post/2577</link><guid isPermaLink="true">https://forum.mango-os.com/post/2577</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Tue, 26 May 2009 07:34:23 GMT</pubDate></item><item><title><![CDATA[Reply to Simple Examples on Mon, 25 May 2009 20:19:50 GMT]]></title><description><![CDATA[<p dir="auto">Yes, the software will work in a software-only environment, but you need to be careful in choosing port numbers. BACnet4J actually works better than some commercial packages in this regard in the sense that it properly will handle broadcasts when non-standard port numbers are used, but that doesn't let the developer off the hook. :) The problem is that when you run BACnet4J on a single host, only one of them can have the standard port number 0xBAC0.</p>
<p dir="auto">For example, I'll use the SlaveDeviceTest included in the source. It creates a device that listens on port 2068. When i want to discover this device on the same workstation (say, using DiscoveryTest), i need to make sure the LocalDevice i use there listens on a different port number, and that i send my WhoIs broadcast to port 2068.</p>
<p dir="auto">This code should do the trick:</p>
<pre><code>
<p dir="auto">... at least, when you add in the code that lists out discovered devices (also in DiscoveryTest).</p>
]]></description><link>https://forum.mango-os.com/post/2576</link><guid isPermaLink="true">https://forum.mango-os.com/post/2576</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 25 May 2009 20:19:50 GMT</pubDate></item></channel></rss>
