    Network Configuration
    6 Posts 3 Posters 2.9k Views 3 Watching
    • B Offline
      bhansen
      I was looking through documentation on changing the network settings, IP/Mask/DNS etc... And see a Network Configuration tab under system settings referenced but when I go to look on my end I'm not seeing the option there. I know I can use the USB configuration but wanted to see how/where I can do it on this end.
        Hi @bhansen
        You will need to install the MangoES configuration module.
        • B Offline
          bhansen
          Thanks @CraigWeb,
          I got that installed and I now see Mango ES Configuration under settings but only really see where I can upload a file, change Host Name and Time Zone. Was unsure what I needed to do if i want to change IP/Mask/Gateway/DNS.
          • Dave FrazierD Offline
            Dave Frazier
            Which device are you trying to change the network settings on? If it is a MangoGT, the module should work - you may just need to refresh without the cache (Ctrl+Shift+R for Chrome/Firefox). If you're trying to set a static IP for a MangoHTS, the MangoES Configuration module is not supported and you'll want to SSH into the unit and adjust the /etc/network/interfaces file.
            Let me know if you need instructions for the latter.
            • B Offline
              bhansen
              It's a Mango GT. I tried doing that refresh, different browsers, wiping cache still no luck. Here's what I'm seeing;
              https://ibb.co/HVz33KR
              https://ibb.co/mqXPRJS
                Dave Frazier
                Hmm, then I would suggest setting it in the /etc/network/interfaces file. Download an SSH client like PuTTY and connect to:
                mango@[currentIpAddress]
                Port 2222
                Your unique SSH password would have been included on a sticker in the MangoGT box. If you need us to look it up, please send the serial number of the MangoGT to support@infiniteautomation.com. Use the following command to edit the file:
                sudo nano /etc/network/interfaces
                Then change this line:
                iface eth0 inet dhcp
                To be like this:
                iface eth0 inet static
                address x.x.x.x
                netmask x.x.x.x
                gateway x.x.x.x
                dns-nameservers x.x.x.x
                Ctrl+x, y, Enter to save. Then sudo reboot to restart the unit with the new static network settings. Gateway and DNS servers are optional if you don't need them.
