<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Network Configuration]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I was looking through documentation on changing the network settings, IP/Mask/DNS etc... And see a Network Configuration tab under system settings referenced but when I go to look on my end I'm not seeing the option there.  I know I can use the USB configuration but wanted to see how/where I can do it on this end.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/topic/4945/network-configuration</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 21:36:17 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4945.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Sep 2020 19:03:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Network Configuration on Wed, 23 Sep 2020 18:06:50 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, then I would suggest setting it in the /etc/network/interfaces file.  Download an SSH client like PuTTY and connect to:</p>
<p dir="auto">mango@[currentIpAddress]<br />
Port 2222</p>
<p dir="auto">Your unique SSH password would have been included on a sticker in the MangoGT box.  If you need us to look it up, please send the serial number of the MangoGT to <a href="mailto:support@infiniteautomation.com" rel="nofollow ugc">support@infiniteautomation.com</a>.  Use the following command to edit the file:</p>
<p dir="auto"><em>sudo nano /etc/network/interfaces</em></p>
<p dir="auto">Then change this line:</p>
<p dir="auto"><em>iface eth0 inet dhcp</em></p>
<p dir="auto">To be like this:</p>
<p dir="auto"><em>iface eth0 inet static<br />
address x.x.x.x<br />
netmask x.x.x.x<br />
gateway x.x.x.x<br />
dns-nameservers x.x.x.x</em></p>
<p dir="auto">Ctrl+x, y, Enter to save.  Then sudo reboot to restart the unit with the new static network settings.  Gateway and DNS servers are optional if you don't need them.</p>
]]></description><link>https://forum.mango-os.com/post/25805</link><guid isPermaLink="true">https://forum.mango-os.com/post/25805</guid><dc:creator><![CDATA[Dave Frazier]]></dc:creator><pubDate>Wed, 23 Sep 2020 18:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to Network Configuration on Wed, 23 Sep 2020 17:54:40 GMT]]></title><description><![CDATA[<p dir="auto">It's a Mango GT.  I tried doing that refresh, different browsers, wiping cache still no luck.  Here's what I'm seeing;<br />
<a href="https://ibb.co/HVz33KR" rel="nofollow ugc">https://ibb.co/HVz33KR</a><br />
<a href="https://ibb.co/mqXPRJS" rel="nofollow ugc">https://ibb.co/mqXPRJS</a></p>
]]></description><link>https://forum.mango-os.com/post/25804</link><guid isPermaLink="true">https://forum.mango-os.com/post/25804</guid><dc:creator><![CDATA[bhansen]]></dc:creator><pubDate>Wed, 23 Sep 2020 17:54:40 GMT</pubDate></item><item><title><![CDATA[Reply to Network Configuration on Wed, 23 Sep 2020 17:40:53 GMT]]></title><description><![CDATA[<p dir="auto">Which device are you trying to change the network settings on?  If it is a MangoGT, the module should work - you may just need to refresh without the cache (Ctrl+Shift+R for Chrome/Firefox).  If you're trying to set a static IP for a MangoHTS, the MangoES Configuration module is not supported and you'll want to SSH into the unit and adjust the /etc/network/interfaces file.</p>
<p dir="auto">Let me know if you need instructions for the latter.</p>
]]></description><link>https://forum.mango-os.com/post/25803</link><guid isPermaLink="true">https://forum.mango-os.com/post/25803</guid><dc:creator><![CDATA[Dave Frazier]]></dc:creator><pubDate>Wed, 23 Sep 2020 17:40:53 GMT</pubDate></item><item><title><![CDATA[Reply to Network Configuration on Wed, 23 Sep 2020 14:37:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a>,</p>
<p dir="auto">I got that installed and I now see Mango ES Configuration under settings but only really see where I can upload a file, change Host Name and Time Zone.  Was unsure what I needed to do if i want to change IP/Mask/Gateway/DNS.</p>
]]></description><link>https://forum.mango-os.com/post/25802</link><guid isPermaLink="true">https://forum.mango-os.com/post/25802</guid><dc:creator><![CDATA[bhansen]]></dc:creator><pubDate>Wed, 23 Sep 2020 14:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to Network Configuration on Wed, 23 Sep 2020 11:05:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhansen" aria-label="Profile: bhansen">@<bdi>bhansen</bdi></a></p>
<p dir="auto">You will need to install the MangoES configuration module.</p>
]]></description><link>https://forum.mango-os.com/post/25793</link><guid isPermaLink="true">https://forum.mango-os.com/post/25793</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Wed, 23 Sep 2020 11:05:01 GMT</pubDate></item></channel></rss>
