    Cloud Connect Help
    17 Posts 3 Posters 3.0k Views 3 Watching
      cmason
      I've followed through the few threads on here trying to setup cloud connect. Mainly this one https://forum.infiniteautomation.com/topic/3812/cloud-connect-401-403-errors
      I've managed to get my cloud connect client to connect to my cloud connect server, though that's about it.
      For background, the server is sitting behind a firewall and I have registered a subdomain.domain name for it. For browser traffic, 80,443 etc, the firewall routes this to a reverse proxy on another machine behind the firewall, and that takes care of users accessing the UI over the web. For the cloud connect I've just set the firewall to bypass the reverse proxy and route all 9005 traffic (the port the cloud connect server is listening on) to the mango server. This seems to be working fine.
      My issue is trying to open a web browser to the client. Whenever I go to the connected clients page, and click the 'open client' button, it just takes me straight to another window with a nonsense url and says it can't find the IP. The URL in the opened window is 'GUID.hostname'. (GUID being the GUID of the client and hostname being the host name of the server). I've followed the settings in the linked thread. I've also tried a all sorts of other combinations but every time it just opens the window with the same url. My understanding is that it should be opening the window with something like 'GUID.mysubomain.mydomain'.
      Also I'm not sure exactly what settings need to be in the proxy, I've attached what I've got so far as at this stage trying to connect in general seems to be the first hurdle. Any help much appreciated.
      2_1598400684031_Proxy Settings.png 1_1598400684031_Cloud Connect Window.png 0_1598400684030_Cloud Connect Client.png
        Have you done a DNS lookup to see if an IP even matches that URL?
          cmason @MattFox
          @mattfox said in Cloud Connect Help:
          Yeah it doesn't, that's kind of the problem. my subdomain.domain is valid. But my the host name 'mangoHTSXXXXX' is just a hostname.
          According to the other thread I should be getting 'GUID.subdomain.domain'.
            Show your env.properties settings. let's compare to see if you missed anything or need to amend anything...
            feel free to change the domain name as long as it matches your pattern
              cmason @MattFox
              @mattfox thanks man
              Here's the overrides env.properties files
              #    Copyright (C) 2014 Infinite Automation Systems Inc. All rights reserved.
              #    @author Matthew Lohbihler
              # TO OVERRIDE VALUES IN THIS FILE...
              # Do not change the values in this file, because when you upgrade your core
              # your changes will be overwritten. Instead, create a new file called
              # <MA_HOME>/overrides/properties/env.properties and override properties
              # there. The overrides directory will never be overwritten by an upgrade, so
              # your customizations will be safe.
              # The port at which Mango Automation will listen for browser connections
              web.port=80
              # The host interface to which Mango Automation will bind and listen for new connections
              #  0.0.0.0 is the special interface that will force a bind to all available interfaces
              web.host=0.0.0.0
              # Should Mango Automation open (if possible) a browser window when it starts up?
              web.openBrowserOnStartup=true
              # Set this to true if you are running Mango behind a reverse proxy that sends "Forwarded" or "X-Forwarded-*" headers.
              # This includes accessing Mango via Cloud Connect module. By default only requests from localhost are trusted.
              web.forwardedHeaders.enabled=true
              # Set a comma separated list of IP ranges from which to trust Forwarded headers
              web.forwardedHeaders.trustedIpRanges=127.0.0.0/8,::1,10.1.1.0/24
              # HTTP session (authentication) cookie name and domain name settings.
              # Use the Mango GUID as the session cookie name
              sessionCookie.useGuid=true
              # Set the domain name that the cookie is valid for, can be used to make the session login valid for subdomains too.
              # If left blank the session cookie can only be used for the domain that you login at.
              sessionCookie.domain=.mango.abc.wyxz.nz
              # Default database settings, NOTE that on windows this must be an absolute path
              db.type=h2
              db.url=jdbc:h2:${ma.home}/databases/mah2
              db.location=${ma.home}/databases/mah2
              db.username=
              db.password=
              #For web console
              db.web.start=false
              db.web.port=8091
              #General Database Settings
              db.pool.maxActive=100
              db.pool.maxIdle=10
              db.update.log.dir=${ma.home}/logs/
              # setting to show query times in the logs as INFO
              db.useMetrics=false
              #--The following database properties are for RQL REST queries and can be changed during runtime and will be picked up at most in 5s--
              #Force the use of indexes (Experimental and only on MySQL so far)
              db.forceUseIndex=true
              #Tell the jdbc driver to fetch this many rows at a time, useful over network connected dbs (Not MySQL)
              # negative values will force use jdbc driver default
              db.fetchSize=-1
              #Tell the database to not return the entire result set (or fetch blocks) but to return row by row
              # can slow down performance on network systems but reduce memory footprint for large queries
              db.stream=false
              #-- End auto-reloading Database Properties --
              # MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
              #db.type=mysql
              #db.url=jdbc:mysql://localhost/<your mysql schema name>
              #db.username=<your mysql username>
              #db.password=<your mysql password>
              #db.mysqldump=<location/command for mysqldump executable for backups>
              #db.mysql=<location/command for mysql executable for restore>
              # Database settings for conversion. If the db.* settings point to a new database instance, and the convert type setting
              # is set, Mango Automation will attempt to convert from the convert.db.* settings to the db.* settings
              # Note that database conversions should not be performed in the same step as an upgrade. First upgrade, then convert.
              convert.db.type=
              convert.db.url=${convert.db.url}
              convert.db.username=${convert.db.username}
              convert.db.password=${convert.db.password}
              #Set the base path for where the NoSQL data will be stored
              db.nosql.location=${ma.home}/databases/
              #Set the folder name of the point value store
              db.nosql.pointValueStoreName=mangoTSDB
              #Set the number of files the database can have open at one time
              db.nosql.maxOpenFiles=500
              #Time after which a shard will be closed
              db.nosql.shardStalePeriod=36000000
              #Period to check for stale shards
              db.nosql.flushInterval=300000
              #Query Performance Tuning, File Access Type: Available[INPUT_STREAM,FILE_CHANNEL,RANDOM_ACCESS_FILE,MAPPED_BYTE_BUFFER]
              db.nosql.shardStreamType=INPUT_STREAM
              #Setting to speed up NoSQL queries at the expense of a small increase in disk usage
              db.nosql.reversible=false
              #Setting this will convert your existing point value store [NONE, REVERSIBLE, UNREVERSIBLE]
              db.nosql.convert=NONE
              #Number of concurrent threads to use to convert the database
              db.nosql.convertThreads=4
              #Run the corruption scan if the db is marked dirty
              db.nosql.runCorruptionOnStartupIfDirty=false
              #Password encryption scheme [BCRYPT, SHA-1, NONE]
              #Legacy is SHA-1, 2.8+ BCRYPT
              #security.hashAlgorithm=BCRYPT
              # The location of the Mango Automation store from which to get license files.
              store.url=https://store.infiniteautomation.com
              # SSL control
              ssl.on=false
              ssl.port=8443
              ssl.keystore.location=/location/to/keystore/file.jks
              ssl.keystore.password=freetextpassword
              # System time zone. Leave blank to use default VM time zone.
              timezone=
              #Rest API Configuration
              rest.enabled=true
              #For using other than timestamp
              rest.customDateOutputFormat=YYYY-MM-dd HH:mm:ss.SSS Z
              rest.customDateInputFormat=YYYY-MM-dd HH:mm:ss.SSS Z
              #Enable to make JSON More readable
              rest.indentJSON=false
              #Cross Origin Request Handling
              rest.cors.enabled=false
              rest.cors.allowedOrigins=*,localhost
              rest.cors.allowedMethods=PUT,POST,GET,OPTIONS,DELETE
              rest.cors.allowedHeaders=LOGOUT,PASSWORD
              rest.cors.exposedHeaders=
              rest.cors.allowCredentials=true
              rest.cors.maxAge=3600
              #For rest API Documentation at /swagger/index.html
              swagger.enabled=true
              #Regex Patter to scan for REST API endpoints for Swagger to document/display
              swagger.mangoApiVersion=v[12]
              #Distributor Settings
              distributor=IA
              #Jetty Thread Pool Tuning
              # Time a thread must be idle before killing to keep pool size at minimum
              web.threads.msIdleTimeout=10000
              # Number of threads to keep around to handle incoming connections
              web.threads.minimum=10
              # Number of threads allowed to be created to handle incoming requests as needed
              web.threads.maximum=200
              # Number of Requests To Queue if all threads are busy
              web.requests.queueSize=200
              # Ping timeout for response from browser
              web.websocket.pingTimeoutMs=10000
              #Jetty JSP Configuration
              # See here for options: http://www.eclipse.org/jetty/documentation/9.2.10.v20150310/configuring-jsp.html
              web.jsp.development=true
              web.jsp.genStringsAsCharArray=true
              web.jsp.trimSpaces=false
              web.jsp.classdebuginfo=false
              web.jsp.supressSmap=true
              web.jsp.compilerClassName=org.apache.jasper.compiler.JDTCompiler
              web.jsp.compiler=modern
              web.jsp.fork=false
              web.jsp.keepgenerated=true
              #iFrame Header Control iFrame Header Control 'X-Frame-Options' (case sensitive options)
              # SAMEORIGIN - Only allow Mango to embed i-frames when the requesting page was loaded from the Mango domain
              # DENY - Do not allow at all
              # ANY - Do not even use the header at all
              # One specific domain name can be supplied so that the header becomes: ALLOW-FROM http://foo.bar.com
              web.security.iFrameAccess=SAMEORIGIN
              #Regex used to match serial ports so they show up in the menu
              serial.port.linux.regex=((cu|ttyS|ttyUSB|ttyACM|ttyAMA|rfcomm|ttyO|COM)[0-9]{1,3}|rs(232|485)-[0-9])
              serial.port.linux.path=/dev/
              serial.port.windows.regex=
              serial.port.windows.path=
              serial.port.osx.path=/dev/
              serial.port.osx.regex=(cu|tty)..*
              #Start data sources in parallel threads
              runtime.datasource.startupThreads=4
              #Log startup times for runtime manager
              runtime.datasource.logStartupMetrics=true
              #Log number of aborted polls for a polling data source this often at a minimum (only logged after next aborted poll past this time)
              runtime.datasource.pollAbortedLogFrequency=3600000
              #Report Javascript Execution Times at INFO Level logging
              # add this to log4j.xml   <category name="org.perf4j.TimingLogger"><level value="info"/></category>
              runtime.javascript.metrics=false
              #Default task queue size for the Real Time Timer, should multiple tasks of the same type be queued up?
              # Tasks are rejected from a full queue, a size of 0 means reject multiple instances of the same task
              runtime.realTimeTimer.defaultTaskQueueSize=0
              #When a task queue is full should the waiting tasks be discarded and replaced with the most recent
              runtime.realTimeTimer.flushTaskQueueOnReject=false
              #Maximum counts to wait to terminate the thread pool's tasks that are running or queued to run
              # each count is 1 second.  So the default of 60 = 1 minute.  Note that the medium and low
              # timeout happens first and then the remaining time is spent waiting of the high priority tasks.
              # So by setting both to the same value will result in waiting only as long as that value.
              runtime.shutdown.medLowTimeout=60
              runtime.shutdown.highTimeout=60
              And here's the core env.properties file
              web.port=8080
              web.host=0.0.0.0
              # Web caching settings
              # disable caching
              web.cache.noStore=false
              web.cache.noStore.rest=true
              web.cache.noStore.resources=false
              # set max age of cached files in seconds, only if noStore=false
              # versioned resources are those with ?v=xxx on the query string
              web.cache.maxAge=0
              web.cache.maxAge.rest=0
              web.cache.maxAge.resources=86400
              web.cache.maxAge.versionedResources=31536000
              #Upload file size limit (bytes) -1 means no limit
              web.fileUpload.maxSize=250000000
              db.type=h2
              db.username=
              db.password=
              #For web console
              db.web.start=false
              db.web.port=8091
              #to compact the database size at shutdown (may take longer but will free up disk space)
              db.h2.shutdownCompact=false
              db.pool.maxIdle=10
              db.useMetrics=false
              # if set, will only log slow queries, above this threshold in ms. Will be logged at WARN level instead of INFO
              db.metricsThreshold=100
              db.fetchSize=-1
              db.stream=false
              #db.type=mysql
              convert.db.type=
              db.nosql.shardStreamType=MAPPED_BYTE_BUFFER
              db.nosql.reversible=true
              # SSL control
              # *** NOTE ***
              # You can generate a self-signed certificate for testing using the following command
              # keytool -genkey -keyalg RSA -alias mango -keystore /location/to/keystore/file.jks -validity 365 -keysize 2048
              # Enter keystore password: {type your keystore password <ENTER>}
              # Re-enter new password: {type your keystore password <ENTER>}
              # What is your first and last name?
              #   [Unknown]: {the hostname mango is running on e.g. mymangotest.com OR localhost <ENTER>}
              # What is the name of your organizational unit?
              #   [Unknown]: {e.g. Mango testing <ENTER>}
              # What is the name of your organization?
              #   [Unknown]: {e.g. Infinite Automation Systems Inc. <ENTER>}
              # What is the name of your City or Locality?
              #   [Unknown]: {e.g. Erie <ENTER>}
              # What is the name of your State or Province?
              #   [Unknown]: {e.g. Colorado <ENTER>}
              # What is the two-letter country code for this unit?
              #   [Unknown]: {e.g. US <ENTER>}
              # Is CN=localhost, OU=Development, O=Infinite Automation Systems Inc., L=Erie, ST=Colorado, C=US correct?
              #   [no]:  {type yes <ENTER>}
              # Enter key password for <mango>
              #         (RETURN if same as keystore password): {type your key password or just press <ENTER>}
              # Note: Enabling SSL also turns on HSTS which may not be desirable, see below
              ssl.on=false
              ssl.port=8443
              ssl.keystore.watchFile=true
              ssl.keystore.location=overrides/keystore.p12
              # If they key password is commented out, it is assumed to be the same as the keystore password
              #ssl.key.password=
              #Time socket can be idle before being closed (ms)
              ssl.socketIdleTimeout=70000
              #Enable ALPN (Application-Layer Protocol Negotiation) for HTTP/2
              # on current browsers HTTP/2 is only available for TLS/SSL connections.
              # Note that with this setting you must also have the ALPN script extension enabled for Mango to start on pre Java 10.
              # (Adds -javaagent:${MA_HOME}/boot/jetty-alpn-agent.jar to the java options)
              # If you are running on Java 10+ this library is not required and will actually cause problems, so make sure you don't use that extension.
              ssl.alpn.on=true
              #Show debug output for alpn connections in log
              ssl.alpn.debug=false
              # Configure HSTS (HTTP Strict Transport Security)
              # Enabled by default when ssl.on=true
              # Sets the Strict-Transport-Security header, web browsers will always connect using HTTPS when they
              # see this header and they will cache the result for max-age seconds
              ssl.hsts.enabled=true
              ssl.hsts.maxAge=31536000
              ssl.hsts.includeSubDomains=false
              timezone=
              rest.enabled=true
              rest.cors.allowedMethods=PUT,POST,GET,OPTIONS,DELETE,HEAD
              rest.cors.allowedHeaders=content-type,x-requested-with,authorization
              rest.cors.allowCredentials=false
              # disable browser redirects
              rest.disableErrorRedirects=false
              # enable test endpoints
              rest.testMode=false
              # Limits the rate at which an unauthenticated IP address can access the REST API
              # Defaults to an initial 10 request burst then 2 requests per 1 second thereafter
              rateLimit.rest.anonymous.enabled=true
              rateLimit.rest.anonymous.burstQuantity=40
              rateLimit.rest.anonymous.quanitity=5
              rateLimit.rest.anonymous.period=1
              rateLimit.rest.anonymous.periodUnit=SECONDS
              # Limits the rate at which an authenticated user can access the REST API
              # Disabled by default
              rateLimit.rest.user.enabled=false
              rateLimit.rest.user.burstQuantity=20
              rateLimit.rest.user.quanitity=10
              rateLimit.rest.user.period=1
              rateLimit.rest.user.periodUnit=SECONDS
              # Limits the rate at which authentication attempts can occur by an IP address
              # Defaults to an initial 5 attempt burst then 1 attempt per 1 minute thereafter
              rateLimit.authentication.ip.enabled=true
              rateLimit.authentication.ip.burstQuantity=5
              rateLimit.authentication.ip.quanitity=1
              rateLimit.authentication.ip.period=1
              rateLimit.authentication.ip.periodUnit=MINUTES
              # Limits the rate at which authentication attempts can occur against a username
              rateLimit.authentication.user.enabled=true
              rateLimit.authentication.user.burstQuantity=5
              rateLimit.authentication.user.quanitity=1
              rateLimit.authentication.user.period=1
              rateLimit.authentication.user.periodUnit=MINUTES
              #For rest API Documentation at /swagger-ui.html
              swagger.enabled=false
              #path to api-docs for swagger tools, will be appended to base REST api version URL i.e. /rest/v1/
              springfox.documentation.swagger.v2.path=/swagger/v2/api-docs
              # Require authentication to access Swagger API documentation.
              # If you set this to false then you can use an authentication token (generated on the Mango Users page) from the swagger UI instead.
              # To use, enter: Bearer <space> <token value> into the Authorize value input in the swagger ui
              swagger.apidocs.protected=true
              distributor=IA
              web.threads.msIdleTimeout=30000
              # Number of threads allowed to be created to handle incoming requests as needed (defaults to 10x number of processors, or 200, whichever is greater)
              # Number of threads to keep around to handle incoming connections (defaults to max threads, or 8, whichever is lesser)
              # Number of Requests To queue if all threads are busy (defaults 1280)
              web.socketIdleTimeout=70000
              #Jetty QoS filter settings
              # https://www.eclipse.org/jetty/documentation/current/qos-filter.html
              # Filter enabled setting
              web.qos.enabled=false
              #The maximum number of requests to be serviced at a time. The default is 10.
              web.qos.maxRequests=10
              #The length of time, in milliseconds, to wait while trying to accept a new request. Used when the maxRequests limit is reached. Default is 50 ms
              web.qos.waitMs=50
              #Length of time, in milliseconds, that the request will be suspended if it is not accepted immediately. If set to -1, the container default timeout applies. Default is 30000 ms.
              web.qos.suspendMs=30000
              #Jetty DoS filter settings
              # https://www.eclipse.org/jetty/documentation/current/dos-filter.html
              web.dos.enabled=false
              #Maximum number of requests from a connection per second. Requests in excess of this are first delayed, then throttled. Default is 25.
              web.dos.maxRequestsPerSec=75
              #Delay imposed on all requests over the rate limit, before they are considered at all
              #  100ms default, -1 = Reject request, 0 = no delay, any other value is delay in ms
              web.dos.delayMs=100
              #Length of time, in ms, to blocking wait for the throttle semaphore. Default is 50 ms.
              web.dos.maxWaitMs=50
              #Number of requests over the rate limit able to be considered at once. Default is 5.
              web.dos.throttledRequests=5
              #Length of time, in ms, to async wait for semaphore. Default is 30000.
              web.dos.throttleMs=30000
              #Length of time to let the request run, default is 30000 (Keep above 60s for DWR Long Poll to work in legacy UI)
              web.dos.maxRequestMs=120000
              #Length of time, in ms, to keep track of request rates for a connection, before deciding that the user has gone away, and discarding it. Default is 30000.
              web.dos.maxIdleTrackerMs=30000
              #If true, insert the DoSFilter headers into the response. Defaults to true.
              web.dos.insertHeaders=true
              #If true, usage rate is tracked by session if a session exists. Defaults to true.
              web.dos.trackSessions=true
              #If true and session tracking is not used, then rate is tracked by IP and port (effectively connection). Defaults to false.
              web.dos.remotePort=false
              #A comma-separated list of IP addresses that will not be rate limited.
              # Note: These are actual client IPs when behind a proxy server if you configure web.forwardedHeaders.trustedIpRanges to trust your proxy's IP
              web.dos.ipWhitelist=
              #Jetty Low Resource Management (Used to attempt to free resources when under heavy load)
              # https://www.eclipse.org/jetty/documentation/current/limit-load.html
              web.lowResource.enabled=false
              # Period in ms to check for a low resource condition, default 10000
              web.lowResource.checkPeriod=10000
              # In low resource condition all existing connection idle timeouts are set to this value, default 1000
              web.lowResource.lowResourcesIdleTimeout=1000
              # check connectors executors to see if their ThreadPool instances that are low on threads, default true
              web.lowResource.monitorThreads=true
              # The maximum memory in bytes that Java is allowed to use before the low resource condition is triggered.
              # If left empty, the default is 90% of the maximum memory the JVM is configured to use.
              # Set to 0 to disable the memory usage checks.
              web.lowResource.maxMemory=
              # The time in milliseconds that a low resource state can persist before the low resource idle timeout is reapplied to all connections, default 5000
              web.lowResource.maxLowResourceTime=5000
              # If false, new connections are not accepted while in low resources
              web.lowResource.acceptingInLowResources=true
              # Maximum number of allowed connections, defaults to 0 (disabled)
              web.connectionLimit=0
              # Jetty JSP servlet configuration (init parameters)
              # See for descriptions
              # https://github.com/eclipse/jetty.project/blob/jetty-9.4.x/jetty-webapp/src/main/config/etc/webdefault.xml
              web.jsp.fork=false
              web.jsp.modificationTestInterval=4
              # Jetty default servlet configuration (init parameters)
              web.defaultServlet.dirAllowed=false
              web.defaultServlet.maxCacheSize=256000000
              web.defaultServlet.maxCachedFileSize=200000000
              web.defaultServlet.maxCachedFiles=2048
              web.defaultServlet.etags=false
              # defaults to false for Windows, defaults to true for all other OS
              # see https://www.eclipse.org/jetty/documentation/current/troubleshooting-locked-files-on-windows.html
              #web.defaultServlet.useFileMappedBuffer=true
              #Follow symbolic links when serving files from Jetty
              web.security.followSymlinks=true
              # Content Security Policy settings, please see https://developer.mozilla.org/en-US/docs/Web/HTTP/CSP
              # The reasons for the default policy are outlined below
              # style-src 'unsafe-inline' - inline styles are used by AngularJS Material for the dynamic theming
              # script-src 'unsafe-eval' - needed by Fabric.js used in amCharts for drawing on charts, also gives AngularJS a 30% performance boost
              # connect-src ws: wss: - necessary as 'self' does not permit connections to websockets on the same origin, this should be configured to restrict it to your server's actual hostname
              # img-src data: - allows for small base64 encoded images to be embedded inline into the html
              # img-src/script-src https://www.google-analytics.com - allows for enabling Google analytics (not enabled by default, must be manually enabled by admin via UI Settings page)
              # img-src/script-src https://maps.google.com https://maps.googleapis.com https://maps.gstatic.com - allows for using the Google maps component
              # style-src/font-src https://fonts.googleapis.com https://fonts.gstatic.com - allows for using Google fonts in dashboards
              web.security.contentSecurityPolicy.enabled=false
              web.security.contentSecurityPolicy.reportOnly=false
              web.security.contentSecurityPolicy.defaultSrc='self'
              web.security.contentSecurityPolicy.scriptSrc='self' 'unsafe-eval' https://maps.google.com https://maps.googleapis.com https://www.google-analytics.com
              web.security.contentSecurityPolicy.styleSrc='self' 'unsafe-inline' https://fonts.googleapis.com
              web.security.contentSecurityPolicy.connectSrc='self' ws: wss:
              web.security.contentSecurityPolicy.imgSrc='self' data: https://maps.google.com https://maps.gstatic.com https://www.google-analytics.com
              web.security.contentSecurityPolicy.fontSrc='self' https://fonts.gstatic.com
              web.security.contentSecurityPolicy.mediaSrc=
              web.security.contentSecurityPolicy.objectSrc=
              web.security.contentSecurityPolicy.frameSrc=
              web.security.contentSecurityPolicy.workerSrc=
              web.security.contentSecurityPolicy.manifestSrc=
              web.security.contentSecurityPolicy.other=
              # script-src 'unsafe-inline' - inline scripts are used extensively throughout the Mango legacy UI
              # script-src 'unsafe-eval' - The Dojo JS library uses eval()
              # style-src 'unsafe-inline' - inline styles are used throughout the Mango legacy UI
              web.security.contentSecurityPolicy.legacyUi.enabled=false
              web.security.contentSecurityPolicy.legacyUi.reportOnly=false
              web.security.contentSecurityPolicy.legacyUi.defaultSrc='self'
              web.security.contentSecurityPolicy.legacyUi.scriptSrc='self' 'unsafe-inline' 'unsafe-eval' https://www.google-analytics.com
              web.security.contentSecurityPolicy.legacyUi.styleSrc='self' 'unsafe-inline'
              web.security.contentSecurityPolicy.legacyUi.connectSrc='self' ws: wss:
              web.security.contentSecurityPolicy.legacyUi.imgSrc='self' data: https://www.google-analytics.com
              web.security.contentSecurityPolicy.legacyUi.fontSrc=
              web.security.contentSecurityPolicy.legacyUi.mediaSrc=
              web.security.contentSecurityPolicy.legacyUi.objectSrc=
              web.security.contentSecurityPolicy.legacyUi.frameSrc=
              web.security.contentSecurityPolicy.legacyUi.workerSrc=
              web.security.contentSecurityPolicy.legacyUi.manifestSrc=
              web.security.contentSecurityPolicy.legacyUi.other=
              #Number of bytes read events to queue up before discarding
              serial.port.eventQueueSize=10000
              #Rate at which to poll the serial port for new data in Linux (Windows uses interrupts)
              serial.port.linux.readPeriods=100
              serial.port.linux.readPeriodType=NANOSECONDS
              runtime.datasource.startupThreads=8
              #Delay (in ms) to wait to rate limit task rejection log messages so they don't fill up logs and use too much cpu doing it
              runtime.taskRejectionLogPeriod=10000
              # Set the location of the file stores, (relative to $MA_HOME if not absolute)
              # If not set, the location is $MA_HOME/filestore
              filestore.location=filestore
              # Set the location of the modules data directory, (relative to $MA_HOME if not absolute)
              # If not set, the location is $MA_HOME/data
              moduleData.location=data
              # name takes precedence over useGuid if set
              sessionCookie.name=
              # Controls the poll period for collecting internal metrics
              internal.monitor.pollPeriod=10000
              # Controls the poll period for collecting disk usage
              internal.monitor.diskUsage.pollPeriod=1200000
              # Should MA_HOME and each file store directory be monitored individually in addition to the partitions?
              internal.monitor.diskUsage.monitorDirectories=false
                Is your client running on port 80?
                Looking at that, the server will connect on the same port it's set up on. Also note your ssh settings as well. since ES units run on port 2222, you'd have to configure port forwarding if you're coming in from port 22.
                  Hi @cmason
                  Have you set up a wildcard DNS record for *.subdomain.hostname?
                  Is your Certificate a wildcard certificate?
                  The proxy basically routes guid.subdomain.domain -> localhost:"client web port" . I have never seen this before where you get a guid.mangoHTS### URL. Probably cause it's not common to set up an HTS as the CC server.
                  Please go to administration --> system settings -> ES configuration and change the hostname to your public hostname. I believe that will fix the URL issue.
                    cmason @MattFox
                    This post is deleted!
                      The reverse proxy will setup port forwarding for both web and ssh ports so that you will be able to access both from your CC server. You will not need to setup port forwarding on the mangoHTS side.
                      If you want to ssh into your mangoHTS you will ssh into the CC server and then run the following cmd:
                      ssh -p 37001 mango@localhost the CC server will route that to the mangoHTS on the reverse proxy connection.
                        Was what i was referring to
                          cmason @CraigWeb
                          Yes this did fix the issue of the url that was given to the new window.
                          The new windows now opens up with 'GUID.subdomain.domain'
                          However I've got a new problem. The window just opens and directs straight into the servers UI from where I just came from. Basically just loops it around on itself.
                          Not technically but the subdomain.domain is resolving to the domain. the subdomain part is really so the reverse proxy can identify it.
                          Yes
                            I suggest trying to get it working without the complexity of your reverse proxy first.
                            You will need a wildcard DNS record that resolves to your MangoHTS server.
                            Basically, when you open the link the traffic will go as below
                            GUID.subdomain.domain --> "CC server"-->.localhost:37000-->MangoHTS:8080
                              cmason @CraigWeb
                              @craigweb said in Cloud Connect Help:
                              Ok I'll try that out. What's the recommended way to secure the connections then between the mango and the internet? The main reason I was using the reverse proxy was for security.
                              @MattFox Are you using cloud connect with the reverse proxy? If so is that using apache on the same machine as your mango like I've seen you describe in some of the other threads?
                                Ive just dropped apache in favour of Nginx because it has better support for proxy headers.
                                Happy to help you with that.
                                In the meantime we can focus on plain http with the mango running on port 8080 then using the proxy engine to handle all requests and merely serve them to mango.
                                Im going to bed now so Ill assist with that tomorrow. In fact I think Ill write a tutorial...
                                  CraigWeb @cmason
                                  @cmason
                                  Mount your certificate on the mango web server so all HTTP traffic is encrypted.
                                  Mango webserver has a rate limiter on unauthorized API requests.
                                  CC server uses ssh so those sockets are all encrypted.
                                  The persistent data source/publisher uses encryption as well. you can choose the size of the shared key.
                                  Use a firewall to block all unused ports.
                                  I may be wrong but how I don't see how the reverse proxy will make it more secure.
                                    cmason @MattFox
                                    @MattFox @CraigWeb
                                    Thanks Guys. I followed what you guys said and stripped it all back to the basics and got it working without the proxy. Funnily enough though It worked with HTTPS 'ssl.on=true' (self signed on the mango) but HTTP was having issues.
                                    Anyway I enabled set 'ssl.on=true' on the server and got it all working.
                                    Then I moved it all back behind the reverse proxy, and so far it all seems to be working fine.
                                    The only difference this time is the ssl.on = true.
                                    Yeah I mainly did this because I'm using a Synology NAS as the reverse proxy, it has nginx built in. Having this take care of the certificates and the auto renewals etc seemed a lot more straight forward then getting it to work on the mango with the java keystore etc. Perhaps a feature to add for Mango 4? haha.
                                    I'll see how this goes and keep you posted.
                                    Bearing in mind that the ports 9005 for cloud connect and the ports I've opened for the PTCP publishers get forwarded straight to the mango itself. I haven't got them going through the reverse proxy. Are the HTTP/S payloads?
                                      Awesome!
                                      They are not HTTP payloads.
                                      I use let's encrypt and certbot to handle certificate renewals. There is a script in mango that can be run after the cert is renewed that will move the certificate into the keystore and replace the old cert. /mango/bin/certbot-deploy.sh
                                      You may want to look at that.
