    Serial data source causing crash
    8 Posts 3 Posters 3.1k Views 3 Watching
      Robmalone
      Hi all,
      I just deleted a data source (modbus IP) that I was using for testing purposes. Mango then crashed/shut down and now wont load. It gets to 40/50% and gives and error Unable to load /mango/status/ status:0
      The cmd window closes and there are no errors in ma.log.
      No other changes were made to mango or java.
      Mango version is 3.7.7.
      Java Version is AdoptOpenJDK 11.0.6.10
      EDIT: This appears to be a serial/com port issue. I have set up some modbus serial data points but when I enable the data source Mango crashes. It wont restart until I delete the database. No errors in ma.log, it just crashes when starting data sources.
      EDIT 2: I have tried a USB to RS485 converter in case it was a com port issue but it is also crashing Mango when I enable the data source. I have confirmed the converter is working using ModbusPoll on the same PC and slave device.
      Any Ideas? Thanks
      Rob
        Hi Rob
        Can you have a look if there is a pid_error file in your mango directory after the crash.
          Robmalone
          Hi Craig, There is indeed! WIll I post it?
            Hi Rob can you email it to us.
              Robmalone
              Done. Thanks Craig.
                chrapchp
                I'm getting this as well.
                I restored from a windows crash and using the recommended AdoptOpenJDK JDK. I was using the old JDK from Oracle prior. I now get this error and I know the port works fine as I can communicate using a modbus master tool.
                  Robmalone
                  @chrapchp Have you tried going back to Oracle JDK? I ended up using a Modbus gateway.
                    chrapchp @Robmalone
                    @robmalone Mango did not even what to start up with JDK 1.14. I did recover the old jdk I was using on the crashed system and will revert to that.
                    thx
