    ng-if condition used with point query
    5 Posts 3 Posters 2.1k Views 3 Watching
    • D Offline
      dgm
      This supplies my serialChart with 8 dataPoints from my plc and works fine...
      <div ng-model="theDevice" ng-init="theDevice='unit#1_plc'" ></div>
       <ma-point-query query="{$and: true, deviceName:theDevice, name:ptName}" limit="8" points="points"></ma-point-query>
       <ma-point-values points="points" values="combined" from="from" to="to" ></ma-point-values>
      This does not... but why not?
      <div ng-if="true" ng-model="theDevice" ng-init="theDevice='unit#1_plc'" ></div>
        I'd wager the ng-if is looking for a variable called true. Check your console for errors.
        Why do you want the ngif there in the first place?
          ye true is probably returning as undefined.
          • D Offline
            dgm
            thanks guys,
            here is my reasoning:
            I was testing 2 datapoints on 2 different plc. if they were equal, then plc1 would be my source for the seriesChart, if false then plc2. the ng-if was going to help me swap out the devices . I did have a variable that tested the condition and it did evaluate to true or false but when plan didnt work i started to backup and check why.
              Use <ma-get-point-value> for both points.
              2) in your ng if, use both points with the challenge:
              ng-if="pt1.value==pt2.value"
              This way you are comparing two variables to see if they are the same/both equal to one another.
              For false simply:
              ng-if="pt1.value!=pt2.value"
              That should you help you with where you want to go!
