    Setting values with specific timestamps
    3 Posts 3 Posters 1.5k Views 3 Watching
      psysak
      Hey guys, I'm sure this has been asked somewhere in here before. Is there a way I can create a dashboard page which would allow me to set the value of a specified point but also pass a timestamp? We have several parameters which come from the electrical company which change every few months and then need to applied to calculations. I need to be able to allow end users to open a dashboard, select the point and basically specify something like May 2019. The system would take that value and apply it to the point as of May 1 2019 00:00:00.000
        What about using scheduled events to trigger a script to change a data points value?
        Surely there is some set pattern to the dates that the value should change?
        You could still have a dashboard where they set a virtual point that will be used in their calculation.
          Hi psysak,
          There are a few ways you could go about it,
          1. Build a UI widget that POSTs to the /rest/v2/point-values endpoint.
               "xid": "DP_Num_Example",
               "timestamp": 1557250438657,
               "dataType": "NUMERIC",
               "value": 123.456
          1. Encode the date and rate information into one or more points, then trigger a scripting data source which "Saves historic" to .set(value, timestamp) to the appropriate points. I may set an alphanumeric to 52.13~1557250438657 which is a context point that updates the context of a script which simply splits the string on ~ and turns it back to numbers.
          Neither of these methods would cause point events to run currently (no websocket notification of the new value, , but the value would be available for recalculating meta point histories, for instance.
