    Disable the Data Point Details in point Value popup
    7 Posts 5 Posters 4.4k Views 4 Watching
      Pikey4
      Hello!
      Is there a way to disable the link to the data point details link icon when popup is enabled on a live point value?
      Ideally, the enable popup only to display "quick view chart, stats, and point values" and the "set point value" (if available).
      Any Suggestions?
      Mango Core version: 3.5.6
      Mango API module version: 3.5.2
      MangoUi module version: 3.5.5
      Platform: 10.14 MacOS Mojave
      Chrome: Version 70.0.3538.110 (64-bit)
        Yes there is in fact, it is supposed to be an attribute like this data-point-details="false" however the data prefix gets stripped off so its not working correctly. This however works - data-data-point-details="false"
        I'll fix this for 3.6
          Good question I would expect setting data-point-details="false" to achieve that but I just tested it and it does not.
          Edit: lol I must have been testing while Jared responded
            Pikey4
            Thanks for the reply,
            Yes I was trying to utilise the data-point-details="false"
            but was not successful as you have pointed out.
            works just fine
            Cheers!
            • danD Offline
              dan
              Hey Guys, where abouts does this attribute go in the dashboard designer?
              Is it in here?
              Such a javascript newbie :/
                These attributes are usually under "Element Specific"
                • danD Offline
                  dan
                  OK once I realised I was reading into that one a little too much and I just needed to hit the Edit Markup slider and put it in the source for each of the data points, that sorted it.
                  Thanks heaps for that!
