<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disable the Data Point Details in point Value popup]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">Is there a way to disable the link to the data point details link icon when popup is enabled on a live point value?</p>
<p dir="auto">Ideally, the enable popup only to display "quick view chart, stats, and point values" and the "set point value" (if available).</p>
<p dir="auto">Any Suggestions?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/topic/4191/disable-the-data-point-details-in-point-value-popup</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 08:45:08 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4191.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 May 2019 09:15:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Tue, 21 Jul 2020 09:17:21 GMT]]></title><description><![CDATA[<p dir="auto">OK once I realised I was reading into that one a little too much and I just needed to hit the Edit Markup slider and put it in the source for each of the data points, that sorted it.</p>
<p dir="auto">Thanks heaps for that!</p>
]]></description><link>https://forum.mango-os.com/post/25518</link><guid isPermaLink="true">https://forum.mango-os.com/post/25518</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 21 Jul 2020 09:17:21 GMT</pubDate></item><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Mon, 20 Jul 2020 23:25:58 GMT]]></title><description><![CDATA[<p dir="auto">These attributes are usually under "Element Specific"<br />
<img src="https://camo.nodebb.org/3e01f2bb8e35758563e5cf8b246fbd2839f2f45c?url=https%3A%2F%2Fi.imgur.com%2FTb5im2t.png" alt="0_1595288889616_448171d2-3e3a-4f70-abbf-66a7a39e782e-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/25496</link><guid isPermaLink="true">https://forum.mango-os.com/post/25496</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 20 Jul 2020 23:25:58 GMT</pubDate></item><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Mon, 20 Jul 2020 22:53:00 GMT]]></title><description><![CDATA[<p dir="auto">Hey Guys, where abouts does this attribute go in the dashboard designer?<br />
Is it in here?</p>
<p dir="auto"><img src="https://camo.nodebb.org/a53d11675f4ebef3a1fe8b1d8ec4646db9c2eeb4?url=https%3A%2F%2Fi.imgur.com%2FCX0KUqB.png" alt="0_1595286899878_f12e7e8c-d0bf-45d4-bbf6-b3f2a60a96bd-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Such a javascript newbie :/</p>
]]></description><link>https://forum.mango-os.com/post/25488</link><guid isPermaLink="true">https://forum.mango-os.com/post/25488</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 20 Jul 2020 22:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Fri, 03 May 2019 03:28:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply,</p>
<p dir="auto">Yes I was trying to utilise the <code>data-point-details="false"</code><br />
but was not successful as you have pointed out.</p>
<pre><code>data-data-point-details="false"
<p dir="auto">works just fine</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.mango-os.com/post/22027</link><guid isPermaLink="true">https://forum.mango-os.com/post/22027</guid><dc:creator><![CDATA[Pikey4]]></dc:creator><pubDate>Fri, 03 May 2019 03:28:14 GMT</pubDate></item><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Thu, 02 May 2019 16:27:51 GMT]]></title><description><![CDATA[<p dir="auto">Good question I would expect setting data-point-details="false" to achieve that but I just tested it and it does not.</p>
<p dir="auto">Edit: lol I must have been testing while Jared responded</p>
]]></description><link>https://forum.mango-os.com/post/22020</link><guid isPermaLink="true">https://forum.mango-os.com/post/22020</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 02 May 2019 16:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to Disable the Data Point Details in point Value popup on Thu, 02 May 2019 15:26:33 GMT]]></title><description><![CDATA[<p dir="auto">Yes there is in fact, it is supposed to be an attribute like this <code>data-point-details="false"</code> however the data prefix gets stripped off so its not working correctly. This however works - <code>data-data-point-details="false"</code><br />
I'll fix this for 3.6</p>
]]></description><link>https://forum.mango-os.com/post/22019</link><guid isPermaLink="true">https://forum.mango-os.com/post/22019</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 02 May 2019 15:26:33 GMT</pubDate></item></channel></rss>
