    Menu Folders
    21 Posts 5 Posters 20.7k Views 5 Watching
    • BGB Offline
      BG
      Brilliant Jared!
      Thank you very much for sorting this for me. I will need to create many more folders to group or dashboards and will now be able to get them organised.
      Brian
      • BGB Offline
        BG
        Hello Jared,
        Sorry, I am back.
        I created a second menu folder, put the next set of dashboards in the new folder and the same issue occurred.
        I added the extra property line to the mangoUI-menu as I did for the first folder but it did not fix the new folder. The first folder still works fine, but the templates in the second folder are now showing the scale problem again.
        Is it possible to add that property to the templates themselves so they will work in new folders?
        Sorry,
        Brian
          Jared Wiltshire @BG
          @bg said in Menu Folders:
          Are you nesting the new folder or something? It should work for any number of folders. A screen shot of the markup from the chrome debugger would be useful again.
          No unfortunately not. I've made the fix to the UI module for the next release though.
          • BGB Offline
            BG
            Hello Jared,
            The screen shot is below. I am not nesting the display folders as you can see in the screen shot. Also the first folder (Dashboard Displays) has reverted back to the same problem again after coming out of the browser and going back in.
            This screen shot is from my admin login. I was editing a couple of pages and the menu items again so that may have reset the mangoUI-menu json file.
            If the next release is not too far away I may just wait for that update to continue with the folder items.
            Brian
              Jared Wiltshire @BG
              Yeah you are quite right. Sorry.
              A solution that does stick is to put the markup in the public file store like so -
              Then setup the folder like this -
              Its not imminent. Might be a little while.
              • BGB Offline
                BG
                Hello Jared,
                Thank you very much for finding a solution that sticks. I will try that tonight.
                Brian
                • BGB Offline
                  BG
                  Hello Jared,
                  I just wanted to let you know that it worked great. Thank you for your help on this.
                  Brian
                  • F Offline
                    fishfacs
                    Bump
                    Sorry to drudge this back up. I was encountering the same problem, and the above solution does not appear to work for me.
                    The pages work fine in the root menu, but as soon as I add them to a menu folder, then refuse to render.
                    I have the above file added to my public file-store with the string, and this is referenced in the menu items configuration?
                    Anything else I can try?
                      I can only suggest checking the edit menu page under Administration and ensuring your menu items have a user read capability added to them from what you describe at first glance,
                      • F Offline
                        fishfacs
                        Disregard. It started working as intended following a server reboot.
                        Thanks.
