    Sources.list default
    15 Posts 3 Posters 7.4k Views 3 Watching
      mihairosu
      Would any of you kind gentlemen be able to provide me with the default sources.list file contents, specifically for Debian Stretch if possible?
      Thank you!
        deb http://deb.debian.org/debian/ stretch main
        deb-src http://deb.debian.org/debian/ stretch main
        deb http://security.debian.org/ stretch/updates main
        deb-src http://security.debian.org/ stretch/updates main
        deb http://deb.debian.org/debian/ stretch-updates main
        deb-src http://deb.debian.org/debian/ stretch-updates main
        deb http://http.debian.net/debian stretch main
        deb-src http://http.debian.net/debian stretch main
          mihairosu
          Hey Matt, much appreciated.
          I forgot to mention though: this is for the MangoES, are there armhf updates on that list? I'm not sure how this works.
          I'm specifically looking to upgrade the kernel. My two ES kernels are not the same version.
            Why don't you follow the upgrade instructions for debian?
            https://linuxconfig.org/how-to-upgrade-debian-8-jessie-to-debian-9-stretch
            From what I can see on the mango there is this sole repo:
            deb http://mangoautomation.net:9902/Applications/apt/debian/ jessie main contrib non-free
            You can probably change it to
            deb http://mangoautomation.net:9902/Applications/apt/debian/ stretch main contrib non-free
            I do not see any arm related repos. @phildunlap may have to comment on that...
            Good Luck
              Unfortunately I wouldn't expect either of those to resolve. I do not believe that package source is still online.
                MattFox @phildunlap
                @phildunlap Thanks in that case I'll comment it out in my sources list.
                  mihairosu
                  So does anyone know why my MangoES is running on kernel Linux 3.8.13.30 armv7l, but my MangoES v2 on Linux 3.10.82+ armv7l?
                  I'm not able to get the original ES kernel to find updates.
                  This is my sources.list identical on both:
                  deb http://deb.debian.org/debian/ stretch main contrib
                  deb-src http://deb.debian.org/debian/ stretch main contrib
                  deb http://security.debian.org/ stretch/updates main contrib
                  deb-src http://security.debian.org/ stretch/updates main contrib
                  deb http://deb.debian.org/debian/ stretch-updates main contrib
                  deb-src http://deb.debian.org/debian/ stretch-updates main contrib
                  deb http://http.debian.net/debian stretch main contrib
                  deb-src http://http.debian.net/debian stretch main contrib
                  deb http://mirrors.kernel.org/debian jessie main contrib
                    get rid of the jessie stuff, stick to one repo!
                    The only time you'll use different versions if there's a specific version of a binary you want from a certain open source provider. That jessie repo is for the linux kernel, get rid of it.
                    Make sure you run after
                    sudo apt-get update
                    sudo apt-get upgrade
                    Have you moved to stretch yet?
                      mihairosu
                      Oops I didn't catch that. Yes I am running on stretch:
                      Both have this for lsb_release -a
                      Distributor ID: Debian
                      Description:    Debian GNU/Linux 9.5 (stretch)
                      Release:        9.5
                      Codename:       stretch
                      There are no updates available.
                      I upgraded to stretch last year I think.
                        I suggest you run sudo aptitude and manually go through what available packages there are then...
                        Should be able to select the kernel you want then.
                        Do note however stretch has been ported for only these architectures:
                        Architectures
                        Stretch was released with 10 architecture ports as announced by the release team:
                        amd64
                        arm64
                        armel
                        armhf
                        i386
                        mips
                        mips64el
                        mipsel
                        ppc64el
                        s390x
                          mihairosu @MattFox
                          @mattfox Thanks Matt, I'll continue to investigate.
                            mihairosu
                            So I am running into an issue with cifs mounting that I'm pretty sure a kernel upgrade will resolve.
                            Matt, that original debian stretch list you gave me is not providing me with any kernel updates.
                            If anyone have a MangoES v1 and a MangoES v2 I would love to see what the default contents are of the /etc/apt/sources.list file is.
                            My MangoES v1 is currently stuck at this kernel version:
                            Linux 22historian 3.8.13.30 #1 SMP PREEMPT Wed Mar 4 17:26:56 BRT 2015 armv7l GNU/Linux
                            My MangoES v2, which has an updated kernel version, works well:
                            Linux lobbyhistorian 3.10.82+ #1 SMP PREEMPT Mon Sep 7 16:31:39 MDT 2015 armv7l GNU/Linux
                            Anyone know either how I can get a source list to update this kernel version using apt or manually downloading the kernel?
                              MattFox @mihairosu
                              @mihairosu Did you run sudo aptitude as I instructed? There is an option in there for kernels.
                                mihairosu
                                Hey Matt,
                                I did go through the aptitude GUI but it wasn't very helpful because it still only uses the sources.list.
                                Here you can see screenshots that it's saying I have installed the 4.5 kernels for both of my MangoES:
                                MangoES original:
                                MangoES v2:
                                but these numbers have nothing to do with what I get when I do a uname -a, as seen in my above post, I am getting 3.8 and 3.10, which I have learned have to do with an ODROID kernel version.
                                Even if it would work, when I search for a new kernel via aptitude on my MangoES v2, I get nothing:
                                Whereas for the MangoES original I do get a list of kernels, but I am afraid to upgrade to any of these, as I still don't understand why they woudn't be automatically marked as upgradeable. My other apprehension is that aptitude on one is not the same as on the other: Why would MangoES v2 not have any kernel updates but the MangoES original does?
                                Looking at this post, I understand that normally, these kernels are not set to upgrade via apt-get, but this person made it possible to do so.
                                I already added these two lists, but they didn't provide any ODROID kernel updates:
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-stretch-main.list        # package list for all ODROID devices / Debian Stretch (not for Debian Wheezy, Jessie, or Ubuntu 12.04, 14.04)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-stretch-backports.list   # package list for all ODROID devices / Debian Stretch (not for Debian Wheezy, Jessie, or Ubuntu 12.04, 14.04)
                                I suspect I may have to add one of these to each MangoES:
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-N1.list              # package list for ODROID N1 devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-U.list               # package list for ODROID U2/U3 devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-X.list               # package list for ODROID X devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-X2.list              # package list for ODROID X2 devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-XU.list              # package list for ODROID XU devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-XU3.list             # package list for ODROID XU3 devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-C1.list              # package list for ODROID C1 devices and all Distributions (Kernel and Headers)
                                wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-C2.list              # package list for ODROID C2 devices and all Distributions (Kernel and Headers)
                                So now, my next problem is to figure out which is the correct ODROID hardware version that these MangoES run.
                                I found this post when searching on how to figure out which ODROID version I am running.
                                The MangoES v2 has 3.10.82+, which according to the above post is 1.0, which says that it would have to be re-imaged? I'm not quite sure how to accomplish this or even if I want to pursue this.
                                The MangoES original has 3.8.13.30, which could mean it could be a sub 1.0 version or something?
                                And again I don't understand why I am getting different versions with uname and what is showing up on Aptitude.
                                I feel like I'm rambling, so I'll just stop for now.
                                  @mihairosu said in Sources.list default:
                                  As the name suggests, it appears you'd be overwriting what you have with a complete image. I have seen the command
                                  sudo make_modules install To install and use the linux kernel.
                                  But I'm not confident that will work given the architecture of the mango unit. I could suggest grub bootloader to select the linux kernel but even then I think you'd just be fiddling as the system itself is a complete image. that is booted and run
                                  Sorry I've exhausted all of my options. I think contact support directly will give you a better outcome now.
