<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sources.list default]]></title><description><![CDATA[<p dir="auto">Would any of you kind gentlemen be able to provide me with the default sources.list file contents, specifically for Debian Stretch if possible?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mango-os.com/topic/3784/sources-list-default</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 21:43:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3784.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Sep 2018 21:02:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sources.list default on Thu, 18 Oct 2018 19:39:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> said in <a href="/post/20272">Sources.list default</a>:</p>
<p dir="auto">The MangoES v2 has 3.10.82+, which according to the above post is 1.0, which says that it would have to be re-imaged?  I'm not quite sure how to accomplish this or even if I want to pursue this.</p>
<p dir="auto">As the name suggests, it appears you'd be overwriting what you have with a complete image. I have seen the command<br />
<code>sudo make_modules install</code> To install and use the linux kernel.<br />
But I'm not confident that will work given the architecture of the mango unit. I could suggest grub bootloader to select the linux kernel but even then I think you'd just be fiddling as the system itself is a complete image. that is booted and run<br />
Sorry I've exhausted all of my options. I think contact support directly will give you a better outcome now.</p>
]]></description><link>https://forum.mango-os.com/post/20276</link><guid isPermaLink="true">https://forum.mango-os.com/post/20276</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 18 Oct 2018 19:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 18 Oct 2018 18:02:15 GMT]]></title><description><![CDATA[<p dir="auto">Hey Matt,</p>
<p dir="auto">I did go through the aptitude GUI but it wasn't very helpful because it still only uses the sources.list.</p>
<p dir="auto">Here you can see screenshots that it's saying I have installed the 4.5 kernels for both of my MangoES:</p>
<p dir="auto">MangoES original:</p>
<p dir="auto"><img src="https://camo.nodebb.org/55af301dad73dd6ae4311263d41880169fd24114?url=https%3A%2F%2Fi.imgur.com%2FPiwE1AO.png" alt="0_1539885312630_270027dd-456c-4343-9c1e-9389c605dee3-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">MangoES v2:</p>
<p dir="auto"><img src="https://camo.nodebb.org/c0069ee88ff526255a828e0ad22b31f982a0f4cc?url=https%3A%2F%2Fi.imgur.com%2FqfNLd5D.png" alt="0_1539885331801_90018777-5333-43e9-a90a-f129b64719a3-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">but these numbers have nothing to do with what I get when I do a uname -a, as seen in my above post, I am getting 3.8 and 3.10, which I have learned have to do with an ODROID kernel version.</p>
<p dir="auto">Even if it would work, when I search for a new kernel via aptitude on my MangoES v2, I get nothing:</p>
<p dir="auto"><img src="https://camo.nodebb.org/48226c5b36595f89247b6959fda4b721acaa1264?url=https%3A%2F%2Fi.imgur.com%2FNcMkEIw.png" alt="0_1539885818528_06f2a050-d8ce-443b-ac00-e6d84aa520e8-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Whereas for the MangoES original I do get a list of kernels, but I am afraid to upgrade to any of these, as I still don't understand why they woudn't be automatically marked as upgradeable.  My other apprehension is that aptitude on one is not the same as on the other:  Why would MangoES v2 not have any kernel updates but the MangoES original does?</p>
<p dir="auto"><img src="https://camo.nodebb.org/49c01760ee5010e0a23eb42816abaa122582c255?url=https%3A%2F%2Fi.imgur.com%2FLhn6LXz.png" alt="0_1539885983878_8421d4ea-eaa0-456b-81f8-bd0c0f21fb81-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Looking at this <a href="https://forum.odroid.com/viewtopic.php?f=52&amp;t=5908" rel="nofollow ugc">post</a>, I understand that normally, these kernels are not set to upgrade via apt-get, but this person made it possible to do so.</p>
<p dir="auto">I already added these two lists, but they didn't provide any ODROID kernel updates:</p>
<pre><code>wget https://oph.mdrjr.net/meveric/sources.lists/meveric-stretch-main.list        # package list for all ODROID devices / Debian Stretch (not for Debian Wheezy, Jessie, or Ubuntu 12.04, 14.04)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-stretch-backports.list   # package list for all ODROID devices / Debian Stretch (not for Debian Wheezy, Jessie, or Ubuntu 12.04, 14.04)
<p dir="auto">I suspect I may have to add one of these to each MangoES:</p>
<pre><code>wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-N1.list              # package list for ODROID N1 devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-U.list               # package list for ODROID U2/U3 devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-X.list               # package list for ODROID X devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-X2.list              # package list for ODROID X2 devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-XU.list              # package list for ODROID XU devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-XU3.list             # package list for ODROID XU3 devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-C1.list              # package list for ODROID C1 devices and all Distributions (Kernel and Headers)
wget https://oph.mdrjr.net/meveric/sources.lists/meveric-all-C2.list              # package list for ODROID C2 devices and all Distributions (Kernel and Headers)
<p dir="auto">So now, my next problem is to figure out which is the correct ODROID hardware version that these MangoES run.</p>
<p dir="auto">I found this <a href="https://forum.odroid.com/viewtopic.php?f=112&amp;t=8563" rel="nofollow ugc">post</a> when searching on how to figure out which ODROID version I am running.</p>
<p dir="auto">The MangoES v2 has 3.10.82+, which according to the above post is 1.0, which says that it would have to be re-imaged?  I'm not quite sure how to accomplish this or even if I want to pursue this.<br />
The MangoES original has 3.8.13.30, which could mean it could be a sub 1.0 version or something?</p>
<p dir="auto">And again I don't understand why I am getting different versions with uname and what is showing up on Aptitude.</p>
<p dir="auto">I feel like I'm rambling, so I'll just stop for now.</p>
]]></description><link>https://forum.mango-os.com/post/20272</link><guid isPermaLink="true">https://forum.mango-os.com/post/20272</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Thu, 18 Oct 2018 18:02:15 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 17 Oct 2018 20:44:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> Did you run sudo aptitude as I instructed? There is an option in there for kernels.</p>
]]></description><link>https://forum.mango-os.com/post/20266</link><guid isPermaLink="true">https://forum.mango-os.com/post/20266</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 17 Oct 2018 20:44:30 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 17 Oct 2018 20:43:21 GMT]]></title><description><![CDATA[<p dir="auto">So I am running into an issue with cifs mounting that I'm pretty sure a kernel upgrade will resolve.</p>
<p dir="auto">Matt, that original debian stretch list you gave me is not providing me with any kernel updates.</p>
<p dir="auto">If anyone have a MangoES v1 and a MangoES v2 I would love to see what the default contents are of the /etc/apt/sources.list file is.</p>
<p dir="auto">My MangoES v1 is currently stuck at this kernel version:</p>
<pre><code>Linux 22historian 3.8.13.30 #1 SMP PREEMPT Wed Mar 4 17:26:56 BRT 2015 armv7l GNU/Linux
<p dir="auto">My MangoES v2, which has an updated kernel version, works well:</p>
<pre><code>Linux lobbyhistorian 3.10.82+ #1 SMP PREEMPT Mon Sep 7 16:31:39 MDT 2015 armv7l GNU/Linux
<p dir="auto">Anyone know either how I can get a source list to update this kernel version using apt or manually downloading the kernel?</p>
]]></description><link>https://forum.mango-os.com/post/20265</link><guid isPermaLink="true">https://forum.mango-os.com/post/20265</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Wed, 17 Oct 2018 20:43:21 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 27 Sep 2018 17:48:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: mattfox">@<bdi>mattfox</bdi></a> Thanks Matt, I'll continue to investigate.</p>
]]></description><link>https://forum.mango-os.com/post/20019</link><guid isPermaLink="true">https://forum.mango-os.com/post/20019</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Thu, 27 Sep 2018 17:48:41 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 26 Sep 2018 22:04:32 GMT]]></title><description><![CDATA[<p dir="auto">I suggest you run sudo aptitude and manually go through what available packages there are then...<br />
Should be able to select the kernel you want then.<br />
Do note however stretch has been ported for only these architectures:</p>
<p dir="auto">Architectures</p>
<p dir="auto">Stretch was released with 10 architecture ports as announced by the release team:</p>
<p dir="auto">amd64</p>
<p dir="auto">arm64</p>
<p dir="auto">armel</p>
<p dir="auto">armhf</p>
<p dir="auto">i386</p>
<p dir="auto">mips</p>
<p dir="auto">mips64el</p>
<p dir="auto">mipsel</p>
<p dir="auto">ppc64el</p>
<p dir="auto">s390x</p>
]]></description><link>https://forum.mango-os.com/post/20005</link><guid isPermaLink="true">https://forum.mango-os.com/post/20005</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 26 Sep 2018 22:04:32 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 26 Sep 2018 21:53:54 GMT]]></title><description><![CDATA[<p dir="auto">Oops I didn't catch that.  Yes I am running on stretch:</p>
<p dir="auto">Both have this for lsb_release -a</p>
<pre><code>Distributor ID: Debian
Description:    Debian GNU/Linux 9.5 (stretch)
Release:        9.5
Codename:       stretch
<p dir="auto">There are no updates available.</p>
<p dir="auto">I upgraded to stretch last year I think.</p>
]]></description><link>https://forum.mango-os.com/post/20004</link><guid isPermaLink="true">https://forum.mango-os.com/post/20004</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Wed, 26 Sep 2018 21:53:54 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 26 Sep 2018 21:46:49 GMT]]></title><description><![CDATA[<p dir="auto">get rid of the jessie stuff, stick to one repo!<br />
The only time you'll use different versions if there's a specific version of a binary you want from a certain open source provider. That jessie repo is for the linux kernel, get rid of it.<br />
Make sure you run after<br />
sudo apt-get update<br />
sudo apt-get upgrade</p>
<p dir="auto">Have you moved to stretch yet?</p>
]]></description><link>https://forum.mango-os.com/post/20003</link><guid isPermaLink="true">https://forum.mango-os.com/post/20003</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 26 Sep 2018 21:46:49 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 26 Sep 2018 21:43:19 GMT]]></title><description><![CDATA[<p dir="auto">So does anyone know why my MangoES is running on kernel Linux 3.8.13.30 armv7l, but my MangoES v2 on Linux 3.10.82+ armv7l?</p>
<p dir="auto">I'm not able to get the original ES kernel to find updates.</p>
<p dir="auto">This is my sources.list identical on both:</p>
<pre><code>deb http://deb.debian.org/debian/ stretch main contrib
deb-src http://deb.debian.org/debian/ stretch main contrib
deb http://security.debian.org/ stretch/updates main contrib
deb-src http://security.debian.org/ stretch/updates main contrib
deb http://deb.debian.org/debian/ stretch-updates main contrib
deb-src http://deb.debian.org/debian/ stretch-updates main contrib
deb http://http.debian.net/debian stretch main contrib
deb-src http://http.debian.net/debian stretch main contrib
deb http://mirrors.kernel.org/debian jessie main contrib
]]></description><link>https://forum.mango-os.com/post/20002</link><guid isPermaLink="true">https://forum.mango-os.com/post/20002</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Wed, 26 Sep 2018 21:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 20 Sep 2018 21:00:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Thanks in that case I'll comment it out in my sources list.</p>
]]></description><link>https://forum.mango-os.com/post/19914</link><guid isPermaLink="true">https://forum.mango-os.com/post/19914</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 20 Sep 2018 21:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 20 Sep 2018 20:59:01 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately I wouldn't expect either of those to resolve. I do not believe that package source is still online.</p>
]]></description><link>https://forum.mango-os.com/post/19912</link><guid isPermaLink="true">https://forum.mango-os.com/post/19912</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 20 Sep 2018 20:59:01 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 20 Sep 2018 20:06:13 GMT]]></title><description><![CDATA[<p dir="auto">Why don't you follow the upgrade instructions for debian?<br />
<a href="https://linuxconfig.org/how-to-upgrade-debian-8-jessie-to-debian-9-stretch" rel="nofollow ugc">https://linuxconfig.org/how-to-upgrade-debian-8-jessie-to-debian-9-stretch</a><br />
From what I can see on the mango there is this sole repo:</p>
<pre><code>deb http://mangoautomation.net:9902/Applications/apt/debian/ jessie main contrib non-free
<p dir="auto">You can <em>probably</em> change it to</p>
<pre><code>deb http://mangoautomation.net:9902/Applications/apt/debian/ stretch main contrib non-free
<p dir="auto">I do not see any arm related repos. <a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> may have to comment on that...</p>
<p dir="auto">Good Luck</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/19911</link><guid isPermaLink="true">https://forum.mango-os.com/post/19911</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 20 Sep 2018 20:06:13 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Thu, 20 Sep 2018 14:56:45 GMT]]></title><description><![CDATA[<p dir="auto">Hey Matt, much appreciated.</p>
<p dir="auto">I forgot to mention though: this is for the MangoES, are there armhf updates on that list?  I'm not sure how this works.</p>
<p dir="auto">I'm specifically looking to upgrade the kernel.  My two ES kernels are not the same version.</p>
]]></description><link>https://forum.mango-os.com/post/19904</link><guid isPermaLink="true">https://forum.mango-os.com/post/19904</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Thu, 20 Sep 2018 14:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to Sources.list default on Wed, 19 Sep 2018 21:23:19 GMT]]></title><description><![CDATA[<pre><code>deb http://deb.debian.org/debian/ stretch main
]]></description><link>https://forum.mango-os.com/post/19900</link><guid isPermaLink="true">https://forum.mango-os.com/post/19900</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 19 Sep 2018 21:23:19 GMT</pubDate></item></channel></rss>
