    Disabled Emailing of alarms and websocket issue
    12 Posts 3 Posters 5.9k Views 3 Watching
    • B Offline
      Bhanner @phildunlap
      @phildunlap
      Hi Phil,
      i have done this and the error is still appearing and causing the page to become unresponsive on the browser and causing lag.
      <Configuration packages="com.serotonin.m2m2.rt.console">
      <Appenders>
      <Console name="stdout" target="SYSTEM_OUT">
      <PatternLayout pattern="%-5p %d{ISO8601} (%C.%M:%L) - %m %n"/>
      </Console>
      <RollingRandomAccessFile name="logfile" filePattern="${sys:ma.home}/logs/%d{MM-dd-yyyy}-%i.ma.log" fileName="${sys:ma.home}/logs/ma.log">
      <Policies>
      <OnStartupTriggeringPolicy />
      <TimeBasedTriggeringPolicy />
      <SizeBasedTriggeringPolicy size="5MB"/>
      </Policies>
      <DefaultRolloverStrategy>
      <Delete basePath="${sys:ma.home}/logs" >
      <IfFileName regex=".*.ma.log" />
      <IfAccumulatedFileCount exceeds="20"/>
      </Delete>
      </DefaultRolloverStrategy>
      </RollingRandomAccessFile>
      <MangoFrontendAppender name="frontend">
      </MangoFrontendAppender>
      <Async name="async" includeLocation="true">
      <AppenderRef ref="logfile"/>
      <AppenderRef ref="stdout" />
      <AppenderRef ref="frontend" />
      </Async>
      </Appenders>
      <Loggers>
      <Logger name="org" level="error"/>
      <Logger name="com.serotonin.m2m2" level="info"/>
      <Logger name="com.infiniteautomation" level="info"/>
      <Root level="error">
      <AppenderRef ref="async"/>
      </Root>
      <Logger name="com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher" level="fatal"/>
      </Loggers>
      </Configuration>
      Regards
      Billy
      Edit: Is there something i can do to prevent the error in the first place?
        You shouldn't still be seeing the log message with that Log4J configuration. Did you restart Mango or reload the Log4J configuration on the System Settings page (you probably will still need to use the old system settings page, /system_settings.shtm ).
        I wonder, are you accessing this instance through a proxy? Are you using HTTPS?
        • B Offline
          Bhanner
          Hi Phil,
          I'm accessing the SCADA via chrome i've just noticed i have https anywhere extension enabled so that will be forcing the page to https if it can.
          The scada is rebooted very regularly as it's currently running on a laptop. i have now reloaded the configuration from the system setting page and rebooted the scada, and removed the https force, to see if the error still occurs.
          • B Offline
            Bhanner @phildunlap
            @phildunlap
            I have uploaded the Log File from the scada if that helps, The scada boots fine then i open the webpage and it works for about 2 mins then the scada freezes and the error appears on the console before the page crashes and i have force shutdown the SCADA
            Log File:
            https://drive.google.com/file/d/1slM9UnJQKMcDG28ZnGji0iNWnjbT_cC6/view?usp=sharing
            Regards
            BIlly
              Id suggest there is something amiss on your dashboard page that is causing Chrome to lock up. This would explain the websocket messages in your log file as the Chrome tab/process is being killed after it freezes up. Id start by opening the Chrome console and watching for any log messages.
              • B Offline
                Bhanner @Jared Wiltshire
                @jared-wiltshire
                Hi Jared,
                It Flags up a missing file that when it first loads the scada page up but the only errors in the logs is timeouts that appear at the same time as the error messages
                Regards
                Billy
                  Can you post or send me the content of the custom page you are displaying, I'll take a look and see if there is anything on there which might obviously cause the Chrome tab/process to lock up.
                  B 2 Replies Last reply Reply Quote 0
                  • B Offline
                    @jared-wiltshire
                    <div class="ma-designer-root" id="a6832bdd-4cfa-4f2a-b0f0-1c4e44f79338" style="width: 1530px; height: 1050px; position: relative; line-height: 1; padding: 0px; margin: 0px; z-index: auto; overflow: visible; left: 600px;" ma-scale-to="window" ma-maintain-ratio="to-height" ma-center="true">
                    <!-- Header Section -->
                    <div id="a9f3817c-036e-4fa2-8ee6-936955b205ba" style="position: absolute; left: 0px; top: 0px; width: 1530px; height: 100px; text-align: center; background-color: rgb(0, 100, 0); color: rgb(255, 255, 255); font-family: sans-serif; font-size: 100px;">Welcome</div>
                    <!-- Time and Date Objects -->
                    <ma-now update-interval="1 SECONDS" output="time"></ma-now>
                    <!-- Area Titles-->
                    <div id="df6fb5c2-9870-44a2-92f0-2b14dc36848d" style="position: absolute; left: 5px; top: 100px; width: 300px; height: 30px; text-align: left; z-index: 0; font-size: 25px;">Project Pen 1</div>
                    <div id="33106f17-b79e-4a7d-900a-ebb24ee79990" style="position: absolute; left: 310px; top: 100px; width: 300px; height: 30px; text-align: left; z-index: 0; font-size: 25px;">Project Pen 2</div>
                    <div id="9dfaf50f-d5c0-46ad-a37e-254c5e4232ec" style="position: absolute; left: 615px; top: 100px; width: 300px; height: 30px; text-align: left; font-size: 25px;">Project Pen 3</div>
                    <div id="131b689b-52e6-419f-866d-6e497bf41db0" style="position: absolute; left: 5px; top: 540px; width: 605px; height: 30px; text-align: left; font-size: 25px;">Outside Works Projects Deparment</div>
                    <div id="726bd79f-77e6-4fe1-ba0e-164dbe7729ed" style="position: absolute; left: 1225px; top: 100px; width: 300px; height: 30px; text-align: left; font-size: 25px;">South West Office</div>
                    <div id="994e3c44-eb49-46d4-9c04-dad89a148d07" style="position: absolute; left: 920px; top: 100px; width: 300px; height: 30px; text-align: left; z-index: 0; font-size: 25px;">Sales</div>
                    <div id="d2ffbccd-933f-4c4b-a939-dcbc26b48c48" style="position: absolute; left: 615px; top: 540px; width: 605px; height: 30px; text-align: left; z-index: 0; font-size: 25px;">Admin and Management</div>
                    <div id="cefb009a-516b-457d-8775-72fc8fa2a0ab" style="position: absolute; left: 1225px; top: 540px; width: 300px; height: 30px; text-align: left; z-index: 0; font-size: 25px;">Vistors</div>
                    <img id="c930a37c-9e27-41f4-9482-2fcef067c6e0" style="position: absolute; left: 0px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 875px; z-index: 2; padding: 0px;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="4158f4c1-8850-446d-9fb2-45c3c9d688f1" style="position: absolute; left: 305px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 435px; z-index: 1;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="26e13219-7be9-4941-a379-09b38e234ff3" style="position: absolute; left: 610px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 875px; z-index: 1;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="1ff7a7c3-1ad5-4066-a496-0843c271ef42" style="position: absolute; left: 915px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 435px; z-index: 1;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="dd3b1c54-71f2-4aee-bee4-0d9118b41cf2" style="position: absolute; left: 1220px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 875px;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="97411267-59ac-4996-8d3c-48e7df211b84" style="position: absolute; left: 1525px; top: 100px; background-color: rgb(0, 0, 0); width: 5px; height: 875px; border-color: rgb(0, 0, 0); border-width: thin;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="3174d2ed-7b37-4be9-8edf-023f120ddd14" style="position: absolute; left: 0px; top: 130px; background-color: rgb(0, 0, 0); width: 1530px; height: 5px; z-index: 0;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="de726f2e-11c0-4242-a355-0126024a894a" style="position: absolute; left: 0px; top: 535px; background-color: rgb(0, 0, 0); width: 1530px; height: 5px; z-index: 0;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="7e0fb0b9-5e7f-41c5-9e55-c7fd21d881fc" style="position: absolute; left: 0px; top: 570px; background-color: rgb(0, 0, 0); width: 1530px; height: 5px; z-index: 0;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="3f686385-cb24-4ba2-be22-cc7479907c56" style="position: absolute; left: 305px; top: 575px; background-color: rgb(0, 0, 0); width: 5px; height: 400px; z-index: 1;" src="/rest/v2/file-stores/default/black.bmp">
                    <img id="70af13c0-66c6-4a8b-a319-cbf7c94de19d" style="position: absolute; left: 915px; top: 575px; background-color: rgb(0, 0, 0); width: 5px; height: 400px; z-index: 1;" src="/rest/v2/file-stores/default/black.bmp">
                    <div id="31dd8f49-4ffe-44c7-aa02-559404dce2e3" style="position: absolute; left: 0px; top: 975px; width: 1530px; height: 75px; background-color: rgb(0, 100, 0); z-index: 0;"></div>
                    <!-- Navigation/Command Buttons -->
                    <ma-button id="8e4a01cd-efd3-4684-b8f5-dd8062ee35e0" style="position: absolute; left: 1426px; top: 1000px; z-index: 3;" raised="true" ui-sref="logout" label="Logout">Logout</ma-button>
                    <ma-button id="a4ecddc0-0326-4f7d-9066-bc7a698c3192" style="position: absolute; left: 1321.99px; top: 1002.01px; z-index: 4;" raised="true" ui-sref="scada.staffSigningConfig" label="Config"></ma-button>
                    <ma-button raised="true" label="Print" onclick="window.print()"></ma-button>
                    <ma-point-value id="4b36515b-7a2f-4cf1-a5c2-dc2d9cf58cd7" enable-popup="hide" style="position: absolute; left: 5px; top: 135px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S1"></ma-point-value>
                    <ma-get-point-value point-xid="Visitor-Number-Selected" point="Vist_Num"></ma-get-point-value>
                    <ma-get-point-value point-xid="Visitor-Number-Selected-Script" point="Script"></ma-get-point-value>
                    <ma-button id="New-Vist" style="position: absolute; left: 1217.99px; top: 1002.03px; z-index: 4;" raised="true" label="New Visitor" ng-click="Vist_Num.setValue(Script.value); $state.go('scada.vistorSetupPage')"></ma-button>
                    <!-- Pen 1 Items-->
                    <ma-switch-img id="df27f044-c2c3-4d35-ad98-6f999ff77c24" style="position: absolute; left: 245px; top: 135px; height: 40px; width: 60px;" point-xid="P1-S1-S" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="6b0acd70-300c-429d-851b-4d57a7a3f9be" style="position: absolute; left: 245px; top: 175px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S2-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="ed35d81d-e054-489c-a028-47691df8d661" style="position: absolute; left: 245px; top: 215px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S3-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="4904cc14-923d-4598-8263-07327ce5ca46" style="position: absolute; left: 245px; top: 255px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S4-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="9b471242-2e24-4796-986b-89db0fd99ddb" style="position: absolute; left: 245px; top: 295px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S5-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="b5359cd1-1b4c-4809-94e4-abba8c49196c" style="position: absolute; left: 245px; top: 335px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S6-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="3cf7adfb-5efc-4cc4-aa91-e45c6bd6fd5b" style="position: absolute; left: 245px; top: 375px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S7-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="233280f7-963d-419e-b199-605be42835e1" style="position: absolute; left: 245px; top: 415px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S8-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="eef83167-2699-4474-a831-47cc422bea4e" style="position: absolute; left: 245px; top: 455px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S9-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="a0cc9722-02d3-46a8-a043-6a1ab7d563ab" style="position: absolute; left: 245px; top: 495px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="P1-S10-S" toggle-on-click="true"></ma-switch-img>
                    <ma-point-value id="923955ab-1339-4886-866b-b03a81d006a7" enable-popup="hide" style="position: absolute; left: 5px; top: 175px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S2"></ma-point-value>
                    <ma-point-value id="8d3e2cd9-b006-4b1a-8631-6f023c47295c" enable-popup="hide" style="position: absolute; left: 5px; top: 215px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S3"></ma-point-value>
                    <ma-point-value id="9ea096a6-3194-4dcd-a450-f465d9523dff" enable-popup="hide" style="position: absolute; left: 5px; top: 255px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S4"></ma-point-value>
                    <ma-point-value id="c3ba7b27-059e-4666-9d6a-490f3296f1bb" enable-popup="hide" style="position: absolute; left: 5px; top: 295px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S5"></ma-point-value>
                    <ma-point-value id="c7dc9ce1-93d2-4c98-89eb-b81416a7f865" enable-popup="hide" style="position: absolute; left: 5px; top: 335px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S6"></ma-point-value>
                    <ma-point-value id="892510e7-d12e-4e04-b527-e161778f8b60" enable-popup="hide" style="position: absolute; left: 5px; top: 375px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S7"></ma-point-value>
                    <ma-point-value id="40ef3ce5-5a90-44fb-93a9-1b811107e18c" enable-popup="hide" style="position: absolute; left: 5px; top: 415px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S8"></ma-point-value>
                    <ma-point-value id="df1759a8-93a3-451e-8c6a-a8b3976cbf82" enable-popup="hide" style="position: absolute; left: 5px; top: 455px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S9"></ma-point-value>
                    <ma-point-value id="d111ace4-05e5-4366-8438-86a351e4f194" enable-popup="hide" style="position: absolute; left: 5px; top: 495px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="P1-S10"></ma-point-value>
                    <!-- Visitor Items-->
                    <ma-point-value id="977b2a96-3209-4144-b857-488225412f5f" enable-popup="hide" style="position: absolute; left: 1225px; top: 575px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-1-Name"></ma-point-value>
                    <ma-switch-img id="63e0c5d3-9c32-4050-b1ac-5c18f6b6128c" style="position: absolute; left: 1465px; top: 575px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" toggle-on-click="true" point-xid="Vist-1-S"></ma-switch-img>
                    <ma-switch-img id="4acea326-590a-432f-bd38-a6f183d33907" style="position: absolute; left: 1465px; top: 615px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" toggle-on-click="true" point-xid="Vist-2-S"></ma-switch-img>
                    <ma-switch-img id="0ba4f2db-45bb-4356-95c6-01567c0b8c91" style="position: absolute; left: 1465px; top: 655px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" toggle-on-click="true" point-xid="Vist-3-S"></ma-switch-img>
                    <ma-switch-img id="e35677ab-b646-445f-b0e2-4cda9312844a" style="position: absolute; left: 1465px; top: 695px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-4-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="9f7d6335-f353-46b6-9bd8-8149e6703afe" style="position: absolute; left: 1465px; top: 735px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-5-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="83afc332-e867-421e-a5e2-3a85b07fb659" style="position: absolute; left: 1465px; top: 775px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-6-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="e102d94b-b29f-4d1f-90de-a7d1ba4309a9" style="position: absolute; left: 1465px; top: 815px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-7-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="04a2d2de-87b6-45a5-bb91-8438720e2a9f" style="position: absolute; left: 1465px; top: 855px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-8-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="5ff3d4c3-7670-49b2-9dc5-c7b8107206b4" style="position: absolute; left: 1465px; top: 895px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-9-S" toggle-on-click="true"></ma-switch-img>
                    <ma-switch-img id="dfed93a4-4054-4c01-9c33-77dc4a3ecdb8" style="position: absolute; left: 1465px; top: 935px; height: 40px; width: 60px;" src-false="/rest/v2/file-stores/default/Signed Out.bmp" src-true="/rest/v2/file-stores/default/Signed In.bmp" point-xid="Vist-10-S" toggle-on-click="true"></ma-switch-img>
                    <ma-point-value id="b9cdd979-9e3d-4b9b-9ed6-1a0b96efc7e4" enable-popup="hide" style="position: absolute; left: 1225px; top: 615px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-2-Name"></ma-point-value>
                    <ma-point-value id="4c5c7729-b363-42af-9bdd-713e321ca6fe" enable-popup="hide" style="position: absolute; left: 1225px; top: 655px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-3-Name"></ma-point-value>
                    <ma-point-value id="683c8f86-3fda-4ed6-b353-d4128bf166ac" enable-popup="hide" style="position: absolute; left: 1225px; top: 695px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-4-Name"></ma-point-value>
                    <ma-point-value id="8ab0d3a7-c5e8-4e67-b217-25bc982e2fc3" enable-popup="hide" style="position: absolute; left: 1225px; top: 735px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-5-Name"></ma-point-value>
                    <ma-point-value id="24fd8af7-79e1-45ad-b4fe-584363affb70" enable-popup="hide" style="position: absolute; left: 1225px; top: 775px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-6-Name"></ma-point-value>
                    <ma-point-value id="2bc4ef1d-5588-4ba5-9f9c-6fdc1fbe3d8e" enable-popup="hide" style="position: absolute; left: 1225px; top: 815px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-7-Name"></ma-point-value>
                    <ma-point-value id="2c516cc2-8bbd-4a22-9ed1-75f70abc77da" enable-popup="hide" style="position: absolute; left: 1225px; top: 855px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-8-Name"></ma-point-value>
                    <ma-point-value id="d1a434a6-214e-4beb-88d3-d4234e3b2aab" enable-popup="hide" style="position: absolute; left: 1225px; top: 895px; width: 230px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-9-Name"></ma-point-value>
                    <ma-point-value id="d8d16661-0cd7-48a9-b82e-4674fd9c15bc" enable-popup="hide" style="position: absolute; left: 1225px; top: 935px; width: 229.992px; height: 30px; padding: 10px 5px 0px; margin: 0px; font-size: 25px;" flash-on-change="false" point-xid="Vist-10-Name"></ma-point-value>
                    <!-- Visitor Badge page nav-->
                    <ma-button id="Vist 1" style="position: absolute; left: 1225px; top: 575px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(1)"></ma-button>
                    <ma-button id="Vist 2" style="position: absolute; left: 1225px; top: 615px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(2)"></ma-button>
                    <ma-button id="Vist 3" style="position: absolute; left: 1225px; top: 655px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(3)"></ma-button>
                    <ma-button id="Vist 4" style="position: absolute; left: 1225px; top: 695px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(4)"></ma-button>
                    <ma-button id="Vist 5" style="position: absolute; left: 1225px; top: 735px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(5)"></ma-button>
                    <ma-button id="Vist 6" style="position: absolute; left: 1225px; top: 775px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(6)"></ma-button>
                    <ma-button id="Vist 7" style="position: absolute; left: 1225px; top: 815px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(7)"></ma-button>
                    <ma-button id="Vist 8" style="position: absolute; left: 1225px; top: 855px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(8)"></ma-button>
                    <ma-button id="Vist 9" style="position: absolute; left: 1225px; top: 895px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(9)"></ma-button>
                    <ma-button id="Vist 10" style="position: absolute; left: 1225px; top:935px; z-index: 4; height: 40px; width: 240px;" raised="false" ui-sref="scada.vistorSetupPage" ng-click="Vist_Num.setValue(10)"></ma-button>
                    • B Offline
                      @jared-wiltshire
                      Any ideas what's going on?
                        @Bhanner just looked it over and it doesn't look like there's anything wrong with it. Are you using the latest Chrome and the latest Mango and UI module? Does the tab freeze up every time at the same time? Is it reproducible under a certain set of conditions?
                        [edit] Its possible this is from a bug where the point value component was fetching events from the API too frequently, maybe try purging old events and upgrading your UI/API module.
