    REGEX with Serial Input Data Point
    9 Posts 2 Posters 3.4k Views 2 Watching
    • thutchisT Offline
      thutchis
      In my lab I periodically run a moisture test on the germination and kilning of the malt. I use a moisture balance that outputs the test results as ASCII text on a RS232 serial port. I need some help extracting the moisture value from the output strings to enter as a data point.
      The output looks like this:
      ***** AUTO STOP *****
      LAST TEMP: 131 C
      FINAL MASS: 12.215 g
      TEST TIME: 56:15
      MASS LOST: 8.531 g
      RESULT: 41.12 %M
      ----------------------------- (the dashes are mine)
      I need to extract just the value (in this case 41.12) from the "RESULT:" line using REGEX. I am NOT very good with regular expressions and have been pulling my hair out all morning. The best I have come up with is: "/RESULT:\s*([\d][\d].[\d][\d])\s%M*/g" but that selects the entire line, not just the value. Any help would be very appreciated.
      Craft Malt from the Ground Up
        Hi thutchis,
        You are using a serial data source?
        It sounds like if you used a value index of 1 instead of 0 you should be extracting your value, currently. You don't need to use the /.../g type format to input the regex, you can enter what would come between the slashes for the serial data source fields.
        I always encourage people to do their troubleshooting using a setup that will catch all the values, for your data, that might mean something like...
        DATA SOURCE:
        Use terminator: No
        Message Regex: ()[^;]+
        Point Identifier Group: 1
        Configuration in Hex: No
        DATA POINT:
        Data Type: Alphanumeric
        Point Identifier:
        Value Group: 0
        Value Regex [^;]+
        I am using [^;]+ because you do not have any semicolons in your example data, so it will match everything. You could probably get the specific value you're looking for with a serial data point setup on that data source like,
        DATA POINT:
        Point Identifier:
        Value Group: 1
        Value Regex [^;]+RESULT: (\d+\.?\d*) %M.*
        • thutchisT Offline
          thutchis
          Thanks Phil,
          Yes, I plan to use a Serial Data Source.
          I am using a Regex tester at: https://regexr.com/ to work out the correct syntax for getting my desired value into a data point. If I put your suggestion, " [^;]+RESULT: (\d+.?\d*) %M.* " in the tester it shows "no match". I would assume the Mango REGEX parser would perform the same.
            Hmm, that is not my experience with that website:
            Perhaps it is from the extra spaces inside your quote marks?
            • thutchisT Offline
              thutchis
              @phildunlap said in REGEX with Serial Input Data Point:
              Strange, I didn't use the spaces after/before the double quotes, they was only to indicate the quotes were not included in the expression I was trying to convey to the reader. But I still don't get a match. Your screen shot shows the entire message was matched, not just the value between "RESULT:" and "%M".
                It shows that value was extracted as group #1, which would be the value group index in Mango.
                It looks like I was supposed to have written (\d+\.?\d*) but the \ before the dot was removed the forum's formatting, and so I didn't copy it into the image. But, it would work either way.
                • thutchisT Offline
                  thutchis
                  I was able to get the REGEX tester to duplicate your results and got the value as group 1.
                  Thanks for your help today, I learned a lot. I plan to connect the serial data source to the Mango server tomorrow. I'll see what happens then.
                  Tom
                  • thutchisT Offline
                    thutchis
                    I connected the moisture balance as a serial data source and it works. I get the percent moisture value as an alpha-numeric which is fine for logging. I don't need any charting. I changed the Regex to include "%M" so a unit is displayed when looking at point details.
                    The data source (moisture balance RS232) sends a 0x04 (EOT End Of Transmission) at the end of each message. If I try to use a terminator string of 0x04 it won't work. If I ignore the terminator it does work, so no big deal. Just curious why I cant use the hex value 0x04 as a terminator. Is there another encoding that would work?
                    Now I need to figure out how to have the result emailed to me when the data point is logged.
                    Tom
                      Hi Tom,
                      At the bottom of the edit point page is a section for event detectors. You're either looking for a Change or Update detector. After the event detector is created, you will need to create an Email event handler on the /event_handlers.shtm page for the event, and you will need to configure your SMTP server in the system settings.
