    Configuring Mango to Send Emails
    23 Posts 5 Posters 27.6k Views 5 Watching
      silvia
      Thanks @phildunlap and @Jared-Wiltshire, I've upgraded Mango to release 3.1. and it's all working now :)
      • ? Offline
        A Former User @JoelHaggar
        @joelhaggar @phildunlap @silvia @Jared-Wiltshire pleas help me :) why my email can't send me any alarms and notification when any events are occur ?
        this is my config :
          Hi Layloosh,
          Have you checked your Mango/logs/ma.log file for any relevant messages? I would expect there to be a suggestion of the issue there.
            Jared Wiltshire @Guest
            @layloosh Firstly check the help page from Google here - https://support.google.com/a/answer/176600?hl=en
            It seems that port 465 will require SSL which is not supported via our Email setup page.
            I use port 587 and TLS which works well for me.
            • ? Offline
              A Former User
              Dear @phildunlap I check it now but I don't know what I do with this file it contain a large of information I can't understand it :(
              Dear @Jared-Wiltshire I config it again but I still have the same problem , and I check if this port (587) is open or not !!! the port is open ...... what I can do
              P.S .... in the last week the email is working and send all notification so what is happened in this week I don't know !!!!!!
              plz help me ^.^
                @Layloosh Your SMTP settings look correct, check your internet connectivity, DNS and username/password.
                Also just upload your ma.log file (there's an upload button just above the text box) and we can look for what might be the issue.
                • ? Offline
                  A Former User
                  I check my internet connectivity every things are correct !!
                  my ma.log file :
                  [0_1513843779567_ma.log](Uploading 100%)
                    @layloosh said in Configuring Mango to Send Emails:
                    my ma.log file :
                    You are going to have to try and upload that again. Be patient.
                    ? 1 Reply Last reply Reply Quote 0
                    • ? Offline
                      A Former User @Jared Wiltshire
                      @jared-wiltshire
                      Dear when I try to upload ma.log file I have this msg.
                      • ? Offline
                        A Former User
                        I read a ma.log and found these errors :
                        ERROR 2017-12-24T05:00:00,000 (com.infiniteautomation.nosql.maint.MangoNoSqlBackupWorkItem$NoSqlBackupTask.run:278) - Unparseable date: "0"
                        java.text.ParseException: Unparseable date: "0"
                        ERROR 2017-12-24T00:05:15,043 (com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run:76) - Error in work item
                        ERROR 2017-12-23T19:25:29,920 (com.serotonin.bacnet4j.transport.DefaultTransport.run:462) - Error during expire messages:
                        java.lang.NullPointerException: null
                          Hi Layloosh,
                          None of those errors are related to your SMTP.
                          The first error is a known issue with incremental backups. It is minor.
                          The second, you did not provide the stack trace below this log message, so I don't know what it's doing.
                          The third pertains to your BACnet setup, and tells me you may not be using the latest Mango, but for SMTP this shouldn't matter.
                          • ? Offline
                            A Former User
                            so what I can do to solve this problem ???
                              We still need to get a look at your logs in order to help you. If you can't upload the log to the forum try uploading it to a third party site such as Google Drive, Dropbox, gist.github.com, pastebin.com etc and post the link here.
                              • ? Offline
                                A Former User
                                why ma.logs file size = 0 ??
                                • ? Offline
                                  A Former User
                                  This post is deleted!
                                    Hi Layloosh,
                                    Going through the errors,
                                    1. Null in jsonWrite for scheduled event - this may be an issue. I will look into it more deeply. It is not the cause of your emails not sending, but it appears it may be causing your configuration backups not to run.
                                    2. Null in default transport - I'm not sure, but i would expect there is an update available for your BACnet module.
                                    3. Unparsable date - known issue, not significant
                                    4. UnknownHostException - is your DNS configured correctly? This is most likely the cause, since it is probably the DNS for the SMTP server cannot be resolved either. From the server, does ping smtp.gmail.com get responses?
                                    • ? Offline
                                      A Former User
                                      yes I get a responses
                                        Hmm, then the SMTP settings are the issue. If you had it working in the past, I would recommend using those settings. Also, it would be good to try to send a few test emails in the period of time covered by the log file, otherwise there's no information in there relevant to the SMTP issue.
