    Two question need to help
    Scheduled Pinned Locked Moved Solved Dashboard Designer & Custom AngularJS Pages
    8 Posts 3 Posters 2.9k Views 2 Watching
    • seanS Offline
      sean
      Q1:why markup use ng-controller it will not work?like pic.0_1513051309127_pic1 ng-controller.PNG
      Q2:when I use <ma-get-point-value> get a value.How do I do write into script?
      I get point like mypoint. I want this mypoint can be write into script?
      series: [{
                          data: [5],<---
      all code
      <script src="http://code.highcharts.com/highcharts.js"></script>
      <script src="http://code.highcharts.com/highcharts-more.js"></script>
      <script src="http://code.highcharts.com/modules/solid-gauge.js"></script>
      <div style="width: 600px; height: 400px; margin: 0 auto">
      	<div id="container-speed" style="width: 300px; height: 200px; float: left"></div>
      <ma-get-point-value point-xid="DP_MainDC/AA/LCP1/Fan#1_RPM" point="mypoint"></ma-get-point-value>
      <script>
      $(function () {
          var gaugeOptions = {
              chart: {
                      type: 'solidgauge',
                          margin: [0, 0, 0, 0],
                          backgroundColor: 'transparent'
                      title: null,
                      yAxis: {
                          min: 0,
                          max: 30,
                          minColor: '#009CE8',
                          maxColor: '#009CE8',
                          lineWidth: 0,
                          tickWidth: 0,
                          minorTickLength: 0,
                          minTickInterval: 500,
                          labels: {
                              enabled: false
                      pane: {
                          center: ['50%', '50%'],
                          startAngle: -130,
                          endAngle: 130,
                          background: {
                          borderWidth: 20,
                          backgroundColor: '#DBDBDB',
                          shape: 'arc',
                          borderColor: '#DBDBDB',
                              outerRadius: '90%',
                              innerRadius: '90%'
                      tooltip: {
                          enabled: false
                      plotOptions: {
                          solidgauge: {
                              borderColor: '#009CE8',
                              borderWidth: 20,
                              radius: 90,
                              innerRadius: '90%',
                              dataLabels: {
                                  y: -25,
                                  borderWidth: 0,
                                  useHTML: true
                      series: [{
                          data: [5],
                          dataLabels: {
                              format: '<div style="Width: 50px;text-align:center"><span style="font-size:45px;color:#009ce8">{y}</span></div>'
                  credits: {
                      enabled: false
          // The speed gauge
          $('#container-speed').highcharts(gaugeOptions);
          // Tweak SVG
          var svg;
          svg = document.getElementsByTagName('svg');
          if (svg.length > 0) {
              var path = svg[0].getElementsByTagName('path');
              if (path.length > 1) {
                  // First path is gauge background
                  path[0].setAttributeNS(null, 'stroke-linejoin', 'round');
                  // Second path is gauge value
                  path[1].setAttributeNS(null, 'stroke-linejoin', 'round');
      </script>
        @sean
        Q1: You can absolutely use ng-controller. You just can't put the angular code in a <script> tag like that. You should use a user module - https://help.infiniteautomation.com/getting-started-with-a-user-module/
        Q2: This is not how AngularJS works at all, you are trying to marry old school jQuery with Angular. I would suggest looking for some examples of how to create a AngularJS component or directive for Highcharts. Or you can use our provided charting directives which make use of AmCharts.
        • seanS Offline
          sean
          @Jared-Wiltshire Thank Jared.
          Q1.You mean when we want use ng-controller must write in user-module. It will be work?
          Q2.AmCharts in <ma-gauge-chart> can't use some setting in AmCharts.
          like bands
          I try some setting maybe just arrows and axes can be use.
          <ma-gauge-chart point="myPoint" interval="10" start="-20" end="120" style="width:100%; height:200px" options="{ arrows:[{startWidth:3}], axes:[{endAngle:180,startAngle:-90}] }"></ma-gauge-chart>
          have some trouble?
            @sean The JS code you have in between your <script> tags goes into the user module. Then the ng-controller attribute goes in your markup.
            Q2: You can't use multiple point values on a <ma-gauge-chart>. If that is what you are are trying to do then perhaps copy the code from https://github.com/infiniteautomation/ma-dashboards/blob/main/UI/web/ngMango/directives/gaugeChart.js into your user module and modify it to suit your needs.
            If you are just trying to change the color bands have a look at the examples at /ui/examples/single-value-displays/gauges and the API docs at /ui/docs/ng-mango/ma-gauge-chart
            • seanS Offline
              sean
              @Jared-Wiltshire Thank you Jared.
              I'll try ng-knob and Angular Gauge but I don't know how to write in user module.
              Can you do a example for me ?
              I try to use https://github.com/infiniteautomation/ma-dashboards/blob/main/UI/web/ngMango/directives/gaugeChart.js
              this code. I know Amchart setting will write in the
              function defaultOptions() {
                  return {
                      type: 'gauge',
                      theme: 'light',
                      addClassNames: true,
                      axes: [{
                          startValue: 0,
                          endValue: 100,
                          bands: [],
                          bottomText: ''
                      arrows: [{
                          nailAlpha: 0,
                          borderAlpha: 0,
                          nailBorderThickness: 6
              But I don't know how to write into userModule let it work.
              I don't see userModule have come to the gaugeChart.
              All code
              'use strict';
              userModule.component('gaugeChart',{
                      restrict: 'E',
                      template: '<div ng-class="classes" class="amchart"></div>' +
                      '<ma-point-statistics point="$ctrl.point" point-xid="{{$ctrl.pointXid}}"' +
                      ' from="from" to="to" statistics="$ctrl.pointStats" rendered="false"></ma-point-statistics>' +
                      '<ma-date-range-picker from="from" to="to" preset="LAST_1_MONTHS" update-interval="1 minutes"' +
                      ' style="display: none;"></ma-date-range-picker>',
                      scope: {},
                      controller: GaugeChartController,
                      controllerAs: '$ctrl',
                      bindings: {
                        point: '<?',
                        pointXid: '@?',
                        start: '<?',
                        end: '<?',
                        autoStart: '<?',
                        autoEnd: '<?',
                        interval: '<?',
                        band1End: '<?',
                        band1Color: '@',
                        band2End: '<?',
                        band2Color: '@',
                        band3End: '<?',
                        band3Color: '@',
                        radius: '@',
                        valueOffset: '<?',
                        valueFontSize: '<?',
                        axisLabelFontSize: '<?',
                        axisThickness: '<?',
                        tickInterval: '<?',
                        arrowInnerRadius: '<?',
                        arrowAlpha: '<?',
                        axisAlpha: '<?',
                        options: '<?',
                        value: '<?',
                        renderValue: '&?'
                      designerInfo: {
                          translation: 'ui.components.gaugeChart',
                          icon: 'donut_large',
                          category: 'pointValue',
                              width: '200px',
                              height: '200px'
                          attributes: {
                              point: {nameTr: 'ui.app.dataPoint', type: 'datapoint'},
                              pointXid: {nameTr: 'ui.components.dataPointXid', type: 'datapoint-xid'},
                              band1Color: {type: 'color'},
                              band2Color: {type: 'color'},
                              band3Color: {type: 'color'},
                              autoStart: {type: 'boolean'},
                              autoEnd: {type: 'boolean'}
              GaugeChartController.$inject = PointValueController.$inject;
              function GaugeChartController() {
                  PointValueController.apply(this, arguments);
                  this.chartOptions = defaultOptions();
              GaugeChartController.prototype = Object.create(PointValueController.prototype);
              GaugeChartController.prototype.constructor = GaugeChartController;
              GaugeChartController.prototype.$onInit = function() {
                  this.updateChart();
                  this.chart = AmCharts.makeChart(this.$element.find('.amchart')[0], this.chartOptions);
                  this.updateChartValue();
                  if(this.autoStart || this.autoEnd) {
                      this.$scope.$watch('$ctrl.pointStats', function(newValue, oldValue) {
                          if (newValue === undefined) return;
                          if (this.autoStart) {
                              this.start = Math.floor(newValue.minimum.value / 10) * 10;
                          if (this.autoEnd) {
                              this.end =  Math.ceil(newValue.maximum.value / 10) * 10;
                          this.updateChart();
                      }.bind(this));
              GaugeChartController.prototype.$onChanges = function(changes) {
                  PointValueController.prototype.$onChanges.apply(this, arguments);
                  var optionsChanged = false;
                  for (var key in changes) {
                      if (key !== 'point' && key !== 'pointXid' && key !== 'value' && !changes[key].isFirstChange()) {
                          optionsChanged = true;
                          break;
                  if (optionsChanged) {
                      this.updateChart();
              GaugeChartController.prototype.valueChangeHandler = function() {
                  PointValueController.prototype.valueChangeHandler.apply(this, arguments);
              GaugeChartController.prototype.updateChartValue = function() {
                  if (!this.chart) return;
                  var value = this.getValue();
                  var textValue = this.getTextValue();
                  this.chart.arrows[0].setValue(value || 0);
                  this.chart.axes[0].setBottomText(textValue);
              GaugeChartController.prototype.updateChart = function() {
                  var options = angular.merge(this.chartOptions, this.options);
                  var axis = options.axes[0];
                  var arrow = options.arrows[0];
                  axis.bands = [];
                  axis.startValue = asNumber(this.start);
                  axis.endValue = asNumber(this.end, 100);
                  if (this.band1End != null) {
                      var stop1 = asNumber(this.band1End);
                      axis.bands.push({
                          color: this.band1Color || '#84b761',
                          startValue: axis.startValue,
                          endValue: stop1
                      if (!this.end)
                          axis.endValue = stop1;
                  if (this.band1End != null && this.band2End != null) {
                      var stop2 = asNumber(this.band2End);
                      axis.bands.push({
                          color: this.band2Color || '#fdd400',
                          startValue: axis.bands[0].endValue,
                          endValue: stop2
                      if (!this.end)
                          axis.endValue = stop2;
                  if (this.band1End != null && this.band2End != null && this.band3End != null) {
                      var stop3 = asNumber(this.band3End);
                      axis.bands.push({
                          color: this.band3Color || '#cc4748',
                          startValue: axis.bands[1].endValue,
                          endValue: stop3
                      if (!this.end)
                          axis.endValue = stop3;
                  axis.valueInterval = asNumber(this.interval, (axis.endValue - axis.startValue) / 5);
                  axis.radius = this.radius || '100%';
                  axis.bottomTextYOffset =  asNumber(this.valueOffset, -20);
                  axis.bottomTextFontSize =  asNumber(this.valueFontSize, 12);
                  axis.axisThickness =  asNumber(this.axisThickness, 1);
                  axis.axisAlpha =  asNumber(this.axisAlpha, 0.5);
                  axis.tickAlpha =  asNumber(this.axisAlpha, 0.5);
                  if (this.axisLabelFontSize != null) {
                      axis.fontSize = asNumber(this.axisLabelFontSize);
                  if (this.tickInterval != null) {
                      axis.minorTickInterval = asNumber(this.tickInterval);
                  arrow.nailRadius = asNumber(this.arrowInnerRadius, 8);
                  arrow.innerRadius = arrow.nailRadius + 3;
                  arrow.alpha = asNumber(this.arrowAlpha, 1);
                  arrow.nailBorderAlpha = arrow.alpha;
                  if (this.chart) {
                      this.chart.validateNow();
              function asNumber(value, defaultValue) {
                  if (typeof value === 'number' && isFinite(value)) {
                      return value;
                  } else if (typeof value === 'string') {
                      try {
                          return parseFloat(value);
                      } catch (e) {}
                  return defaultValue || 0;
                  return {
                      type: 'gauge',
                      theme: 'light',
                      axes: [{
                          startValue: 0,
                          endValue: 100,
                          bands: [],
                          bottomText: ''
                      arrows: [{
                          nailAlpha: 0,
                          borderAlpha: 0,
              return gaugeChart;
              }); // define
                Here is an article how to set up a user module: https://help.infiniteautomation.com/getting-started-with-a-user-module/
                seanS 1 Reply Last reply Reply Quote 0
                • seanS Offline
                  sean @JoelHaggar
                  @joelhaggar
                  I saw this page.
                  But I don't know how to write script code to be user module.
                  like https://radmie.github.io/ng-knob/
                  I just wire
                  Angular.js:
                  var app = angular.module('KnobDemoApp', ['ui.knob'])
                  app.controller('knobCtrl', function ($scope) {
                    $scope.value = 65;
                    $scope.options = {
                      //other options
                  in the the userModule.js
                  in edit pages just type
                  <body ng-app="KnobDemoApp">
                    <div ng-controller="knobCtrl">
                      <ui-knob value="value" options="options"></ui-knob>
                  </body>
                  <script src="https://ajax.googleapis.com/ajax/libs/angularjs/1.4.8/angular.min.js"></script>
                  <script src="https://cdnjs.cloudflare.com/ajax/libs/d3/3.5.10/d3.min.js"></script>
                  <script src="bower_components/ng-knob/dist/ng-knob.min.js"></script>
                  It will work?
                    @sean I'll just show you how to use the ng-knob module instead of customising our gauge since it seems that is what you really want to use.
                    Use this for your usermodule file. This loads the ng-knob and d3 libraries (you dont need to load angular as our app already loads it) and tells the user module it needs to include the ui.knob module.
                    define(['angular', 'require',
                    'https://cdnjs.cloudflare.com/ajax/libs/ng-knob/0.1.3/ng-knob.js',
                    'https://cdnjs.cloudflare.com/ajax/libs/d3/3.5.10/d3.min.js'], function(angular, require) {
                    'use strict';
                    var userModule = angular.module('userModule', ['maUiApp', 'ui.knob']);
                    return userModule;
                    }); // define
                    You don't really need to define and use a controller as you can just use the <ui-knob> directive in your pages.
                    e.g. Put a point value on the gauge and set some options -
                    <div class="ma-designer-root" id="8167524e-1ad3-414d-9b65-d872f1317b4d" style="width: 1366px; height: 768px; position: relative;">
                        <ui-knob id="2666c64f-0a4f-4041-82ee-1f132d82728e" value="myPoint.value" options="{size:300}" style="position: absolute; left: 220px; top: 80px;"></ui-knob>
                        <ma-get-point-value id="82a89bb2-cf03-49d2-a001-f9abf219c5fb" style="position: absolute; left: 28px; top: 159px;" point-xid="voltage" point="myPoint"></ma-get-point-value>
