    Bacnet ip - local equipment - data source - trial
    15 Posts 5 Posters 11.4k Views 5 Watching
      jackchang
      Hello Joel,
      Could you kindly help why my BACnet IP controller can not been found?
      I can ping the B/IP controller's IP Address:
      0_1472831075359_Screenshot from 2016-09-02 23:38:07.png
      I can bind my pc's IP Address:
      0_1472831125837_Screenshot from 2016-09-02 23:38:23.png
      But I can not discover the B/IP controller:
      0_1472831164743_Screenshot from 2016-09-02 23:40:40.png
      Many thanks!
      Jack Chang
        JoelHaggar @ebraggion
        @ebraggion BACnet is probably not going to work over the internet without special network configuration over a vpn but even then I would not recommend it. The whois messages are need to be received and are prodcast to 255.255.255.255 so Mango needs to be on the same subnet as the BACnet devices.
          JoelHaggar @jackchang
          @jackchang I have enough information here to tell you what's wrong. It could be a issue with your controller configuration or your network configuration.
            jackchang @JoelHaggar
            @JoelHaggar 0_1472832671050_Screenshot from 2016-09-03 00:10:46.png
            My PC's IP address and Ping B/IP contriller, and Mango logs.
              @JoelHaggar
              Hello Joel,
              I can get the B/IP controllers using bacnet-stack:
              0_1472896354349_Screenshot from 2016-09-03 17:51:34.png
              But Mango still can not discover them.
              Jack Chang
              • K Offline
                kapsalis @jackchang
                @jackchang @JoelHaggar
                Hello guys,
                I also have the same issue as jackchang. I can find BACnet devices with bacpypes or with other workstations, but not with Mango.
                Do you have any suggestion to solve this problem?
                Thank you in advance,
                Regards,
                Michalis
                  Hi Michalis,
                  What version of Mango are you using? Have you tried both 0.0.0.0 and your local network address as your bind address? Linux or Windows?
                  • K Offline
                    kapsalis @phildunlap
                    Hi @phildunlap ,
                    I am using Mango Automation v3.2.0 in an Ubuntu 16.04 machine. I had tried it with my local network address, but not with 0.0.0.0. I did it after your reply and it works. Can you explain it to me?
                    Thank you,
                    Michalis
                      I can try. I believe devices will respond on the ethernet to IP address 255.255.255.255 (the broadcast address) which for flooding reasons (and probably others) different routers / operating systems treat the broadcast address differently. Sometimes they forward it, sometimes they don't. But, at the operating system level, it has to decide if binding address 192.168.1.10 (or whatever yours is) should also accept messages not specifically addressed to it at the broadcast, and so it has decided not to. You could probably solve this in your IP tables, for instance. It's possible your other programs are binding the port on the sink address (0.0.0.0) and not being explicit about it.
                      • K Offline
                        Thank you @phildunlap
