    Bacnet ip - local equipment - data source - trial
    15 Posts 5 Posters 6.8k Views 5 Watching
    • E Offline
      ebraggion
      Dear sirs,
      i'm new in Mango.
      The first trial we would like to try is to connect mango to local and remote bacnet ip devices.
      So i go to data source, i select bacnet ip, but the sistem doesn't let me to change into local ip into the ip of controller i want to connect to.
      I try the explorer too, but a error message appear.
      Do anybody knows how to solve the problem?
      Thank you1_1472829242498_mango_bacnetip_cantchangeiplocaldevice.png 0_1472829242497_mango_bacnetip_bacnetdiscoveryerror.png
        So from what I can tell something on the computer is already using port 47808.
        If you want to change your Local device you can do that on the System Setting Page in Mango:
        0_1472829599384_upload-6f8575bf-5b22-4cd9-89a7-ab72a7d202f9
        • E Offline
          ebraggion
          Thank you Joel,
          doing that in system setting, when i plug into local bind address, the system automatically reconaise the ip of my pc, where Mango is running.
          Here do I have to select the Mango ip address, or the address of my controller with bacnet ip protocol?
            WIth BACnet Mango will broadcast a WhoIs message to your whole network and find any devices that are there. Based on the error " Address already in use: Cannot bind" I think your issue is that some other program is binding to port 47808 on the computer that Mango is running on.
            • E Offline
              ebraggion
              Changing from 0.0.0.0. ip local bind address into 192.168.1.40 that is the address my adsl router give to my pc where mango is running...i solved the problem... and the bacnet discovery is working correctly.
              So another question is, if i have a remote site, working with public ip, is that possible to configure a data source to go into a remote site? Thank you 0_1472830572443_mango_bacnetip_bacnetdiscoveryok.png
                jackchang
                Hello Joel,
                Could you kindly help why my BACnet IP controller can not been found?
                I can ping the B/IP controller's IP Address:
                0_1472831075359_Screenshot from 2016-09-02 23:38:07.png
                I can bind my pc's IP Address:
                0_1472831125837_Screenshot from 2016-09-02 23:38:23.png
                But I can not discover the B/IP controller:
                0_1472831164743_Screenshot from 2016-09-02 23:40:40.png
                Many thanks!
                Jack Chang
                  JoelHaggar @ebraggion
                  @ebraggion BACnet is probably not going to work over the internet without special network configuration over a vpn but even then I would not recommend it. The whois messages are need to be received and are prodcast to 255.255.255.255 so Mango needs to be on the same subnet as the BACnet devices.
                    JoelHaggar @jackchang
                    @jackchang I have enough information here to tell you what's wrong. It could be a issue with your controller configuration or your network configuration.
                      jackchang @JoelHaggar
                      @JoelHaggar 0_1472832671050_Screenshot from 2016-09-03 00:10:46.png
                      My PC's IP address and Ping B/IP contriller, and Mango logs.
                        @JoelHaggar
                        Hello Joel,
                        I can get the B/IP controllers using bacnet-stack:
                        0_1472896354349_Screenshot from 2016-09-03 17:51:34.png
                        But Mango still can not discover them.
                        Jack Chang
                        • K Offline
                          kapsalis @jackchang
                          @jackchang @JoelHaggar
                          Hello guys,
                          I also have the same issue as jackchang. I can find BACnet devices with bacpypes or with other workstations, but not with Mango.
                          Do you have any suggestion to solve this problem?
                          Thank you in advance,
                          Regards,
                          Michalis
                            Hi Michalis,
                            What version of Mango are you using? Have you tried both 0.0.0.0 and your local network address as your bind address? Linux or Windows?
                            • K Offline
                              kapsalis @phildunlap
                              Hi @phildunlap ,
                              I am using Mango Automation v3.2.0 in an Ubuntu 16.04 machine. I had tried it with my local network address, but not with 0.0.0.0. I did it after your reply and it works. Can you explain it to me?
                              Thank you,
                              Michalis
                                I can try. I believe devices will respond on the ethernet to IP address 255.255.255.255 (the broadcast address) which for flooding reasons (and probably others) different routers / operating systems treat the broadcast address differently. Sometimes they forward it, sometimes they don't. But, at the operating system level, it has to decide if binding address 192.168.1.10 (or whatever yours is) should also accept messages not specifically addressed to it at the broadcast, and so it has decided not to. You could probably solve this in your IP tables, for instance. It's possible your other programs are binding the port on the sink address (0.0.0.0) and not being explicit about it.
                                • K Offline
                                  Thank you @phildunlap
