<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bacnet ip - local equipment - data source - trial]]></title><description><![CDATA[<p dir="auto">Dear sirs,<br />
i'm new in Mango.<br />
The first trial we would like to try is to connect mango to local and remote bacnet ip devices.<br />
So i go to data source, i select bacnet ip, but the sistem doesn't let me to change into local ip into the ip of controller i want to connect to.<br />
I try the explorer too, but a error message appear.<br />
Do anybody knows how to solve the problem?<br />
Thank you<img src="https://camo.nodebb.org/9641c67f4ef6a48d09cf763166f7d9589740e0d8?url=https%3A%2F%2Fi.imgur.com%2FEm3AL6U.png" alt="1_1472829242498_mango_bacnetip_cantchangeiplocaldevice.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/2aee7357401a6cfb9278c7be5a44e2043523f356?url=https%3A%2F%2Fi.imgur.com%2FlSgoOpu.png" alt="0_1472829242497_mango_bacnetip_bacnetdiscoveryerror.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/2433/bacnet-ip-local-equipment-data-source-trial</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 11:59:27 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2433.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Sep 2016 15:14:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Thu, 24 Aug 2017 07:48:00 GMT]]></title><description><![CDATA[<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a></p>
]]></description><link>https://forum.mango-os.com/post/15276</link><guid isPermaLink="true">https://forum.mango-os.com/post/15276</guid><dc:creator><![CDATA[kapsalis]]></dc:creator><pubDate>Thu, 24 Aug 2017 07:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Wed, 23 Aug 2017 16:19:50 GMT]]></title><description><![CDATA[<p dir="auto">I can try. I believe devices will respond on the ethernet to IP address 255.255.255.255 (the broadcast address) which for flooding reasons (and probably others) different routers / operating systems treat the broadcast address differently. Sometimes they forward it, sometimes they don't. But, at the operating system level, it has to decide if binding address 192.168.1.10 (or whatever yours is) should also accept messages not specifically addressed to it at the broadcast, and so it has decided not to. You could probably solve this in your IP tables, for instance. It's possible your other programs are binding the port on the sink address (0.0.0.0) and not being explicit about it.</p>
]]></description><link>https://forum.mango-os.com/post/15271</link><guid isPermaLink="true">https://forum.mango-os.com/post/15271</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 23 Aug 2017 16:19:50 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Wed, 23 Aug 2017 15:36:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> ,</p>
<p dir="auto">I am using  Mango Automation v3.2.0 in an Ubuntu 16.04 machine. I had tried it with my local network address, but not with 0.0.0.0. I did it after your reply and it works. Can you explain it to me?</p>
<p dir="auto">Thank you,</p>
<p dir="auto">Michalis</p>
]]></description><link>https://forum.mango-os.com/post/15270</link><guid isPermaLink="true">https://forum.mango-os.com/post/15270</guid><dc:creator><![CDATA[kapsalis]]></dc:creator><pubDate>Wed, 23 Aug 2017 15:36:07 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Wed, 23 Aug 2017 15:23:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi Michalis,</p>
<p dir="auto">What version of Mango are you using? Have you tried both 0.0.0.0 and your local network address as your bind address? Linux or Windows?</p>
]]></description><link>https://forum.mango-os.com/post/15269</link><guid isPermaLink="true">https://forum.mango-os.com/post/15269</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 23 Aug 2017 15:23:23 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Wed, 23 Aug 2017 10:21:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jackchang" aria-label="Profile: jackchang">@<bdi>jackchang</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a><br />
Hello guys,</p>
<p dir="auto">I also have the same issue as jackchang. I can find BACnet devices with bacpypes or with other workstations, but not with Mango.</p>
<p dir="auto">Do you have any suggestion to solve this problem?</p>
<p dir="auto">Thank you in advance,</p>
<p dir="auto">Regards,<br />
Michalis</p>
]]></description><link>https://forum.mango-os.com/post/15267</link><guid isPermaLink="true">https://forum.mango-os.com/post/15267</guid><dc:creator><![CDATA[kapsalis]]></dc:creator><pubDate>Wed, 23 Aug 2017 10:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Sat, 03 Sep 2016 09:55:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a><br />
Hello Joel,</p>
<p dir="auto">I can get the B/IP controllers using bacnet-stack:</p>
<p dir="auto"><img src="https://camo.nodebb.org/4fdb3670060d2c75fa09fafd22cdbd47415aa148?url=https%3A%2F%2Fi.imgur.com%2FJZ8Wbv8.png" alt="0_1472896354349_Screenshot from 2016-09-03 17:51:34.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">But Mango still can not discover them.</p>
<p dir="auto">Best regards,<br />
Jack Chang</p>
]]></description><link>https://forum.mango-os.com/post/12553</link><guid isPermaLink="true">https://forum.mango-os.com/post/12553</guid><dc:creator><![CDATA[jackchang]]></dc:creator><pubDate>Sat, 03 Sep 2016 09:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 16:13:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a> <img src="https://camo.nodebb.org/b4e225306643716648b3498eab62eb070eaa6bc2?url=https%3A%2F%2Fi.imgur.com%2F1yqs7Ed.png" alt="0_1472832671050_Screenshot from 2016-09-03 00:10:46.png" class=" img-fluid img-markdown" /><br />
My PC's IP address and Ping B/IP contriller, and Mango logs.</p>
]]></description><link>https://forum.mango-os.com/post/12545</link><guid isPermaLink="true">https://forum.mango-os.com/post/12545</guid><dc:creator><![CDATA[jackchang]]></dc:creator><pubDate>Fri, 02 Sep 2016 16:13:00 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jackchang" aria-label="Profile: jackchang">@<bdi>jackchang</bdi></a> I have enough information here to tell you what's wrong.  It could be a issue with your controller configuration or your network configuration.</p>
]]></description><link>https://forum.mango-os.com/post/12543</link><guid isPermaLink="true">https://forum.mango-os.com/post/12543</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:55:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebraggion" aria-label="Profile: ebraggion">@<bdi>ebraggion</bdi></a> BACnet is probably not going to work over the internet without special network configuration over a vpn but even then I would not recommend it.  The whois messages are need to be received and are prodcast to 255.255.255.255 so Mango needs to be on the same subnet as the BACnet devices.</p>
]]></description><link>https://forum.mango-os.com/post/12542</link><guid isPermaLink="true">https://forum.mango-os.com/post/12542</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:46:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello Joel,</p>
<p dir="auto">Could you kindly help why my BACnet IP controller can not been found?</p>
<p dir="auto">I can ping the B/IP controller's IP Address:<br />
<img src="https://camo.nodebb.org/4f6cec111000e1dd87f65209ac17ec2de3e1cbe7?url=https%3A%2F%2Fi.imgur.com%2FgsUlkRe.png" alt="0_1472831075359_Screenshot from 2016-09-02 23:38:07.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I can bind my pc's IP Address:<br />
<img src="https://camo.nodebb.org/e0d127d21ea4697884bdc3e8ae57442aa8f46e7e?url=https%3A%2F%2Fi.imgur.com%2FaknvHua.png" alt="0_1472831125837_Screenshot from 2016-09-02 23:38:23.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">But I can not discover the B/IP controller:<br />
<img src="https://camo.nodebb.org/9fe93b3561ca6f09e4128526399b6cdaadd45773?url=https%3A%2F%2Fi.imgur.com%2F1IMrrpw.png" alt="0_1472831164743_Screenshot from 2016-09-02 23:40:40.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Many thanks!<br />
Jack Chang</p>
]]></description><link>https://forum.mango-os.com/post/12541</link><guid isPermaLink="true">https://forum.mango-os.com/post/12541</guid><dc:creator><![CDATA[jackchang]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:46:50 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:36:37 GMT]]></title><description><![CDATA[<p dir="auto">Changing from 0.0.0.0. ip local bind address into 192.168.1.40 that is the address my adsl router give to my pc where mango is running...i solved the problem... and the bacnet discovery is working correctly.<br />
So another question is, if i have a remote site, working with public ip, is that possible to configure a data source to go into a remote site? Thank you <img src="https://camo.nodebb.org/fc4ebccce01c14c4a7154c6d561a2fa4e3f5c13f?url=https%3A%2F%2Fi.imgur.com%2FfMtfnL8.png" alt="0_1472830572443_mango_bacnetip_bacnetdiscoveryok.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/12540</link><guid isPermaLink="true">https://forum.mango-os.com/post/12540</guid><dc:creator><![CDATA[ebraggion]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:36:37 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:31:29 GMT]]></title><description><![CDATA[<p dir="auto">WIth BACnet Mango will broadcast a WhoIs message to your whole network and find any devices that are there.  Based on the error " Address already in use: Cannot bind" I think your issue is that some other program is binding to port 47808 on the computer that Mango is running on.</p>
]]></description><link>https://forum.mango-os.com/post/12539</link><guid isPermaLink="true">https://forum.mango-os.com/post/12539</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:28:43 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Joel,<br />
doing that in system setting, when i plug into local bind address, the system automatically reconaise the ip of my pc, where Mango is running.<br />
Here do I have to select the Mango ip address, or the address of my controller with bacnet ip protocol?<br />
Thanks</p>
]]></description><link>https://forum.mango-os.com/post/12538</link><guid isPermaLink="true">https://forum.mango-os.com/post/12538</guid><dc:creator><![CDATA[ebraggion]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:28:43 GMT</pubDate></item><item><title><![CDATA[Reply to Bacnet ip - local equipment - data source - trial on Fri, 02 Sep 2016 15:20:07 GMT]]></title><description><![CDATA[<p dir="auto">So from what I can tell something on the computer is already using port 47808.</p>
<p dir="auto">If you want to change your Local device you can do that on the System Setting Page in Mango:</p>
<p dir="auto"><img src="https://camo.nodebb.org/ac85ed5977967c9cf81a64d487cb1a0b93568f39?url=https%3A%2F%2Fi.imgur.com%2Fg0KKb6b.png" alt="0_1472829599384_upload-6f8575bf-5b22-4cd9-89a7-ab72a7d202f9" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/12537</link><guid isPermaLink="true">https://forum.mango-os.com/post/12537</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 02 Sep 2016 15:20:07 GMT</pubDate></item></channel></rss>
