Solved Multiple Watch List Charts
How to configure multiple Watch List Charts to get data based on different Watch Lists sources on the same page?
I'm using the dashboard designer.
Budi -
This can be done but you will need to dive into the markup a little.
Start by creating a dashboard, linking it to a watch list then add two watch list charts. Then toggle the "Edit markup" view. You should see something like this.
<ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_ac76beaa-10f4-40f0-b714-d0fda1c1e801"></ma-watch-list-get> <div class="ma-designer-root" id="413a042a-e638-453f-97ea-b2cc88e5f1c3" style="width: 1024px; height: 768px; position: relative;"> <ma-watch-list-chart id="15ca09c3-30ae-4b29-8e08-74043399c95c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 35px;"></ma-watch-list-chart> <ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"></ma-watch-list-chart> </div>
What you need to do is duplicate the
ma-watch-list-get
element and change itsng-model
,parameters
, andon-points-change
attributes, I just added a 2 to the end. Also setwatch-list-xid
to the second watchlist's XID.Then modify one of the
ma-watch-list-chart
elements to reference the second watch list and points (change itswatch-list
andpoints
attributes).<ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_ac76beaa-10f4-40f0-b714-d0fda1c1e801"></ma-watch-list-get> <ma-watch-list-get ng-model="designer.watchList2" parameters="designer.parameters2" on-points-change="designer.points2 = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_c94d8ac7-1936-4667-804d-5c0fba7f86cd"></ma-watch-list-get> <div class="ma-designer-root" id="413a042a-e638-453f-97ea-b2cc88e5f1c3" style="width: 1024px; height: 768px; position: relative;"> <ma-watch-list-chart id="15ca09c3-30ae-4b29-8e08-74043399c95c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 35px;"></ma-watch-list-chart> <ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList2" points="designer.points2" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"></ma-watch-list-chart> </div>
Thanks for the solution. How to adjust the footer "Powered by Mango Automation ..." to the bottom of the page? Currently, it is cutting through the middle of the second chart.
Budi
Looks like there might be a bug with the footer. We'll look into a solution and get back to you. Thanks.
@budilmk can you post a screenshot please.
@budilmk Are you using
ma-scale-to
on the root element? -
@jared-wiltshire Oh yes, I want it to be viewable on mobile.
<div class="ma-designer-root" id="effb4da9-3871-4f92-ac67-a4a1c1327fce" style="width: 1265px; height: 944px; position: relative; box-sizing: inherit; max-width: inherit; min-width: inherit;" ma-scale-to="window" ma-maintain-ratio="to-width" ma-center="false">
And also, could you include the edit menu setting on home, prob under system setting.
This is because I accidentally disabled the administration menu on the sidebar via the edit menu setting and it took me quite a while to get it back.
@budilmk said in Multiple Watch List Charts:
Unfortunately using
will do just that, enlarge everything so it fits to the whole window. This means if you use it inside the UI things will be scaled too big. It only works with the menu and toolbar hidden (add a menu item then choose the parent to be root).We will be improving this feature in an upcoming release.
This is because I accidentally disabled the administration menu on the sidebar via the edit menu setting and it took me quite a while to get it back.There is an "Edit menu" link under administration. If you ever hide it by accident you can access it by navigating to
/ui/administration/edit-menu
