<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multiple Watch List Charts]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">How to configure multiple Watch List Charts to get data based on different Watch Lists sources on the same page?</p>
<p dir="auto">I'm using the dashboard designer.</p>
<p dir="auto">Thanks<br />
Budi</p>
]]></description><link>https://forum.mango-os.com/topic/2896/multiple-watch-list-charts</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 08:29:17 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2896.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Aug 2017 10:08:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multiple Watch List Charts on Fri, 18 Aug 2017 15:12:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/budilmk" aria-label="Profile: budilmk">@<bdi>budilmk</bdi></a> said in <a href="/post/15247">Multiple Watch List Charts</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: jared-wiltshire">@<bdi>jared-wiltshire</bdi></a>  Oh yes, I want it to be viewable on mobile.</p>
<p dir="auto">Unfortunately using <code>ma-scale-to="window"</code> will do just that, enlarge everything so it fits to the whole window. This means if you use it inside the UI things will be scaled too big. It only works with the menu and toolbar hidden (add a menu item then choose the parent to be root).</p>
<p dir="auto">We will be improving this feature in an upcoming release.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/budilmk" aria-label="Profile: budilmk">@<bdi>budilmk</bdi></a> said in <a href="/post/15248">Multiple Watch List Charts</a>:</p>
<p dir="auto">And also, could you include the edit menu setting on home, prob under system setting.<br />
This is because I accidentally disabled the administration menu on the sidebar via the edit menu setting and it took me quite a while to get it back.</p>
<p dir="auto">There is an "Edit menu" link under administration. If you ever hide it by accident you can access it by navigating to <code>/ui/administration/edit-menu</code></p>
]]></description><link>https://forum.mango-os.com/post/15250</link><guid isPermaLink="true">https://forum.mango-os.com/post/15250</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Fri, 18 Aug 2017 15:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Fri, 18 Aug 2017 02:18:39 GMT]]></title><description><![CDATA[<p dir="auto">And also, could you include the edit menu setting on home, prob under system setting.</p>
<p dir="auto">This is because I accidentally disabled the administration menu on the sidebar via the edit menu setting and it took me quite a while to get it back.</p>
]]></description><link>https://forum.mango-os.com/post/15248</link><guid isPermaLink="true">https://forum.mango-os.com/post/15248</guid><dc:creator><![CDATA[budilmk]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:18:39 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Fri, 18 Aug 2017 02:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: jared-wiltshire">@<bdi>jared-wiltshire</bdi></a>  Oh yes, I want it to be viewable on mobile.</p>
<pre><code>&lt;div class="ma-designer-root" id="effb4da9-3871-4f92-ac67-a4a1c1327fce" style="width: 1265px; height: 944px; position: relative; box-sizing: inherit; max-width: inherit; min-width: inherit;" ma-scale-to="window" ma-maintain-ratio="to-width" ma-center="false"&gt;
]]></description><link>https://forum.mango-os.com/post/15247</link><guid isPermaLink="true">https://forum.mango-os.com/post/15247</guid><dc:creator><![CDATA[budilmk]]></dc:creator><pubDate>Fri, 18 Aug 2017 02:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Thu, 17 Aug 2017 15:13:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/budilmk" aria-label="Profile: budilmk">@<bdi>budilmk</bdi></a> Are you using <code>ma-scale-to</code> on the root element?</p>
]]></description><link>https://forum.mango-os.com/post/15238</link><guid isPermaLink="true">https://forum.mango-os.com/post/15238</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 17 Aug 2017 15:13:38 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Thu, 17 Aug 2017 14:50:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/budilmk" aria-label="Profile: budilmk">@<bdi>budilmk</bdi></a> can you post a screenshot please.</p>
]]></description><link>https://forum.mango-os.com/post/15236</link><guid isPermaLink="true">https://forum.mango-os.com/post/15236</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 17 Aug 2017 14:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Thu, 17 Aug 2017 02:43:01 GMT]]></title><description><![CDATA[<p dir="auto">Looks like there might be a bug with the footer.  We'll look into a solution and get back to you.  Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/15221</link><guid isPermaLink="true">https://forum.mango-os.com/post/15221</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 17 Aug 2017 02:43:01 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Thu, 17 Aug 2017 02:07:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Thanks for the solution. How to adjust the footer "Powered by Mango Automation ..." to the bottom of the page? Currently, it is cutting through the middle of the second chart.</p>
<p dir="auto">Budi</p>
]]></description><link>https://forum.mango-os.com/post/15220</link><guid isPermaLink="true">https://forum.mango-os.com/post/15220</guid><dc:creator><![CDATA[budilmk]]></dc:creator><pubDate>Thu, 17 Aug 2017 02:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple Watch List Charts on Tue, 15 Aug 2017 15:34:51 GMT]]></title><description><![CDATA[<p dir="auto">This can be done but you will need to dive into the markup a little.</p>
<p dir="auto">Start by creating a dashboard, linking it to a watch list then add two watch list charts. Then toggle the "Edit markup" view. You should see something like this.</p>
<pre><code>&lt;ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_ac76beaa-10f4-40f0-b714-d0fda1c1e801"&gt;&lt;/ma-watch-list-get&gt;
&lt;div class="ma-designer-root" id="413a042a-e638-453f-97ea-b2cc88e5f1c3" style="width: 1024px; height: 768px; position: relative;"&gt;
    &lt;ma-watch-list-chart id="15ca09c3-30ae-4b29-8e08-74043399c95c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 35px;"&gt;&lt;/ma-watch-list-chart&gt;
    &lt;ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"&gt;&lt;/ma-watch-list-chart&gt;
&lt;/div&gt;
<p dir="auto">What you need to do is duplicate the <code>ma-watch-list-get</code> element and change its <code>ng-model</code>, <code>parameters</code>, and <code>on-points-change</code> attributes, I just added a 2 to the end. Also set <code>watch-list-xid</code> to the second watchlist's XID.</p>
<p dir="auto">Then modify one of the <code>ma-watch-list-chart</code> elements to reference the second watch list and points (change its <code>watch-list</code> and <code>points</code> attributes).</p>
&lt;ma-watch-list-get ng-model="designer.watchList2" parameters="designer.parameters2" on-points-change="designer.points2 = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_c94d8ac7-1936-4667-804d-5c0fba7f86cd"&gt;&lt;/ma-watch-list-get&gt;
    &lt;ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList2" points="designer.points2" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"&gt;&lt;/ma-watch-list-chart&gt;
&lt;/div&gt;
]]></description><link>https://forum.mango-os.com/post/15208</link><guid isPermaLink="true">https://forum.mango-os.com/post/15208</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 15 Aug 2017 15:34:51 GMT</pubDate></item></channel></rss>
