    Multiple Watch List Charts
    Scheduled Pinned Locked Moved Solved Dashboard Designer & Custom AngularJS Pages
    9 Posts 3 Posters 5.8k Views 2 Watching
    • B Offline
      budilmk
      How to configure multiple Watch List Charts to get data based on different Watch Lists sources on the same page?
      I'm using the dashboard designer.
      Budi
        This can be done but you will need to dive into the markup a little.
        Start by creating a dashboard, linking it to a watch list then add two watch list charts. Then toggle the "Edit markup" view. You should see something like this.
        <ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_ac76beaa-10f4-40f0-b714-d0fda1c1e801"></ma-watch-list-get>
        <div class="ma-designer-root" id="413a042a-e638-453f-97ea-b2cc88e5f1c3" style="width: 1024px; height: 768px; position: relative;">
            <ma-watch-list-chart id="15ca09c3-30ae-4b29-8e08-74043399c95c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 35px;"></ma-watch-list-chart>
            <ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList" points="designer.points" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"></ma-watch-list-chart>
        What you need to do is duplicate the ma-watch-list-get element and change its ng-model, parameters, and on-points-change attributes, I just added a 2 to the end. Also set watch-list-xid to the second watchlist's XID.
        Then modify one of the ma-watch-list-chart elements to reference the second watch list and points (change its watch-list and points attributes).
        <ma-watch-list-get ng-model="designer.watchList2" parameters="designer.parameters2" on-points-change="designer.points2 = $points" id="fa100ec2-ebc2-459a-aaba-ce5d9c0b27c7" watch-list-xid="WL_c94d8ac7-1936-4667-804d-5c0fba7f86cd"></ma-watch-list-get>
            <ma-watch-list-chart id="5d407e94-3820-4e74-abd2-66e8df46fe3c" watch-list="designer.watchList2" points="designer.points2" from="dateBar.from" to="dateBar.to" rollup-type="dateBar.rollupType" rollup-intervals="dateBar.rollupIntervals" rollup-interval-period="dateBar.rollupIntervalPeriod" style="position: absolute; width: 400px; height: 200px; left: 79px; top: 265px;"></ma-watch-list-chart>
        • B Offline
          budilmk
          Thanks for the solution. How to adjust the footer "Powered by Mango Automation ..." to the bottom of the page? Currently, it is cutting through the middle of the second chart.
          Budi
          Jared WiltshireJ 2 Replies Last reply Reply Quote 0
            Looks like there might be a bug with the footer. We'll look into a solution and get back to you. Thanks.
              Jared Wiltshire @budilmk
              @budilmk can you post a screenshot please.
                @budilmk Are you using ma-scale-to on the root element?
                • B Offline
                  budilmk @Jared Wiltshire
                  @jared-wiltshire Oh yes, I want it to be viewable on mobile.
                  <div class="ma-designer-root" id="effb4da9-3871-4f92-ac67-a4a1c1327fce" style="width: 1265px; height: 944px; position: relative; box-sizing: inherit; max-width: inherit; min-width: inherit;" ma-scale-to="window" ma-maintain-ratio="to-width" ma-center="false">
                  • B Offline
                    budilmk
                    And also, could you include the edit menu setting on home, prob under system setting.
                    This is because I accidentally disabled the administration menu on the sidebar via the edit menu setting and it took me quite a while to get it back.
                      @budilmk said in Multiple Watch List Charts:
                      Unfortunately using ma-scale-to="window" will do just that, enlarge everything so it fits to the whole window. This means if you use it inside the UI things will be scaled too big. It only works with the menu and toolbar hidden (add a menu item then choose the parent to be root).
                      We will be improving this feature in an upcoming release.
                      There is an "Edit menu" link under administration. If you ever hide it by accident you can access it by navigating to /ui/administration/edit-menu
