    Mango Installation Stuck at Starting Mango (Windows)
    25 Posts 6 Posters 23.3k Views 5 Watching
      mmmmmt
      It's just stuck there with no error message.
      Log below in case of the screenshot not showing.
      Using E:\TestProject\free-m2m2-core-3.2.0 as MA_HOME
      E:\TestProject\free-m2m2-core-3.2.0\overrides\classes;E:\TestProject\free-m2m2-c
      ore-3.2.0\classes;E:\TestProject\free-m2m2-core-3.2.0\overrides\properties;E:\Te
      stProject\free-m2m2-core-3.2.0\overrides\lib*;E:\TestProject\free-m2m2-core-3.2
      .0\lib*
      Using Java at java
      INFO 2017-08-17T11:10:00,481 (com.serotonin.m2m2.Main.main:90) - Starting Mango
      3.2.0+20170807191436 with Schema Version: 17
        Hi mmmmmt,
        I wonder, what is the size of your H2 database? E:\TestProject\free-m2m2-core-3.2.0\databases\mah2.h2.db (unless you're usl MySQL?) How long have you given it?
        Almost certainly if you rename your E:\TestProject\free-m2m2-core-3.2.0\databases directory it will start on a fresh instance. You can restore either database or configuration backups (which likely would exist if you left it on over night) on the system settings page.
        Another option is using the h2-web-console.bat script in Mango\bin\ to access the database.
        The free download bundle comes without the NoSQL module, which can lead to a much larger H2 database. Perhaps allocating more memory by putting a script like one of those in bin\ext-available into ext-enabled\ will help.
          mmmmmt
          The databases folder is empty. I left it there like half an hour.
            Huh. Are you launching it at the command line?
            cd E:\TestProject\free-m2m2-core-3.2.0\bin
            ma-start.bat
            The only other thing that comes to mind in this moment is that you can freeze command prompt's output with clicking and dragging (you may need quick editing enabled for that to happen, and maybe other things). You can usually click in the command prompt and hit enter to continue.
              mmmmmt
              Yes, and I did not have quick edit mode enabled.
                For some reason I thought it was later in the boot process. It's at installing/loading modules. Does your Mango/web/modules/ directory still have zip files in it? You mean need to redownload one or more modules. See if things go better with an empty Mango/web/modules/ directory.
                  mmmmmt
                  The directory doesn't have any zip file. I tried to run with an empty modules folder, still nothing.
                    Bizarre. I almost think you should redownload everything. But, that seems like it would error somehow if the files were wrong. I tested the free core download after your post, it worked for me.
                    I wonder,
                    1. What's your java -version on the command line?
                    2. Could it be some self righteous antivirus software you've installed?
                      mmmmmt
                      java version "1.8.0_144"
                      Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
                      Java HotSpot(TM) 64-Bit Server VM (build 25.144-b01, mixed mode)
                      I don't have any antivirus software running on my system.
                      I tried to install version 2.8.8, it worked.
                        mmmmmt
                        I can't quit running by pressing ctrl+c. It seems like nothing works but ctrl+break. When I press ctrl+break, it shows these:
                        Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode):
                        "SIGINT handler" #15 daemon prio=9 os_prio=2 tid=0x000000005c01f000 nid=0x1ea8 w
                        aiting for monitor entry [0x00000000579ff000]
                        java.lang.Thread.State: BLOCKED (on object monitor)
                        at java.lang.Shutdown.exit(Unknown Source)
                        - waiting to lock <0x00000000a3ee4f08> (a java.lang.Class for java.lang.
                        Shutdown)
                        at java.lang.Terminator$1.handle(Unknown Source)
                        at sun.misc.Signal$1.run(Unknown Source)
                        "pool-1-thread-1" #10 prio=5 os_prio=0 tid=0x000000005c020000 nid=0x2118 in Obje
                        ct.wait() [0x000000005fb4e000]
                        java.lang.Thread.State: WAITING (on object monitor)
                        at java.lang.Object.wait(Native Method)
                        - waiting on <0x00000000ee3efd80> (a org.apache.logging.log4j.core.appen
                        der.AsyncAppender$AsyncThread)
                        at java.lang.Thread.join(Unknown Source)
                        - locked <0x00000000ee3efd80> (a org.apache.logging.log4j.core.appender.
                        at org.apache.logging.log4j.core.appender.AsyncAppender.stop(AsyncAppend
                        er.java:135)
                        at org.apache.logging.log4j.core.config.AbstractConfiguration.stop(Abstr
                        actConfiguration.java:336)
                        at org.apache.logging.log4j.core.LoggerContext.stop(LoggerContext.java:3
                        51)
                        at org.apache.logging.log4j.core.LoggerContext$1.run(LoggerContext.java:
                        279)
                        at org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry$Re
                        gisteredCancellable.run(DefaultShutdownCallbackRegistry.java:109)
                        at org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry.ru
                        n(DefaultShutdownCallbackRegistry.java:74)
                        "SIGINT handler" #14 daemon prio=9 os_prio=2 tid=0x000000005c01e800 nid=0x1fa8 i
                        n Object.wait() [0x000000005f8ef000]
                        - waiting on <0x00000000a2920338> (a java.lang.Thread)
                        - locked <0x00000000a2920338> (a java.lang.Thread)
                        at java.lang.ApplicationShutdownHooks.runHooks(Unknown Source)
                        at java.lang.ApplicationShutdownHooks$1.run(Unknown Source)
                        at java.lang.Shutdown.runHooks(Unknown Source)
                        at java.lang.Shutdown.sequence(Unknown Source)
                        - locked <0x00000000a3ee4f08> (a java.lang.Class for java.lang.Shutdown)
                        "AsyncAppender-async" #11 daemon prio=5 os_prio=0 tid=0x00000000589d7000 nid=0x2
                        1fc runnable [0x0000000057e6e000]
                        java.lang.Thread.State: RUNNABLE
                        at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(Unknown Source
                        - locked <0x00000000ee47c720> (a java.util.concurrent.ConcurrentHashMap$
                        ReservationNode)
                        at com.serotonin.m2m2.i18n.Translations.getTranslations(Translations.jav
                        a:35)
                        at com.serotonin.m2m2.i18n.Translations.<init>(Translations.java:104)
                        at com.serotonin.m2m2.i18n.Translations.lambda$getTranslations$0(Transla
                        tions.java:37)
                        at com.serotonin.m2m2.i18n.Translations$$Lambda$1/630489928.apply(Unknow
                        n Source)
                        - locked <0x00000000ee47c6b0> (a java.util.concurrent.ConcurrentHashMap$
                        ReservationNode)
                        a:35)
                        tions.java:37)
                        n Source)
                        ReservationNode)
                        a:35)
                        a:31)
                        at com.serotonin.m2m2.rt.console.LoggingConsoleRT.<init>(LoggingConsoleR
                        T.java:34)
                        at com.serotonin.m2m2.rt.console.LoggingConsoleRT.<clinit>(LoggingConsol
                        eRT.java:26)
                        at com.serotonin.m2m2.rt.console.MangoFrontendAppender.append(MangoFront
                        endAppender.java:70)
                        at org.apache.logging.log4j.core.config.AppenderControl.tryCallAppender(
                        AppenderControl.java:156)
                        at org.apache.logging.log4j.core.config.AppenderControl.callAppender0(Ap
                        penderControl.java:129)
                        at org.apache.logging.log4j.core.config.AppenderControl.callAppenderPrev
                        entRecursion(AppenderControl.java:120)
                        at org.apache.logging.log4j.core.config.AppenderControl.callAppender(App
                        enderControl.java:84)
                        at org.apache.logging.log4j.core.appender.AsyncAppender$AsyncThread.call
                        Appenders(AsyncAppender.java:459)
                        at org.apache.logging.log4j.core.appender.AsyncAppender$AsyncThread.run(
                        AsyncAppender.java:412)
                        "Service Thread" #9 daemon prio=9 os_prio=0 tid=0x00000000571ba800 nid=0x19ac ru
                        nnable [0x0000000000000000]
                        "C1 CompilerThread2" #8 daemon prio=9 os_prio=2 tid=0x0000000057132000 nid=0xf74
                        waiting on condition [0x0000000000000000]
                        "C2 CompilerThread1" #7 daemon prio=9 os_prio=2 tid=0x0000000057131800 nid=0x22e
                        c waiting on condition [0x0000000000000000]
                        "C2 CompilerThread0" #6 daemon prio=9 os_prio=2 tid=0x000000005712c000 nid=0x229
                        4 waiting on condition [0x0000000000000000]
                        "Attach Listener" #5 daemon prio=5 os_prio=2 tid=0x0000000057124000 nid=0x21d4 r
                        unnable [0x0000000000000000]
                        "Signal Dispatcher" #4 daemon prio=9 os_prio=2 tid=0x0000000057123000 nid=0x120c
                        "Finalizer" #3 daemon prio=8 os_prio=1 tid=0x0000000055d1f000 nid=0x22cc in Obje
                        ct.wait() [0x000000005710e000]
                        - waiting on <0x00000000ee350db0> (a java.lang.ref.ReferenceQueue$Lock)
                        at java.lang.ref.ReferenceQueue.remove(Unknown Source)
                        - locked <0x00000000ee350db0> (a java.lang.ref.ReferenceQueue$Lock)
                        at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
                        "Reference Handler" #2 daemon prio=10 os_prio=2 tid=0x0000000055cd7800 nid=0x1c8
                        8 in Object.wait() [0x0000000056e3e000]
                        - waiting on <0x00000000ee5416d8> (a java.lang.ref.Reference$Lock)
                        at java.lang.Object.wait(Unknown Source)
                        at java.lang.ref.Reference.tryHandlePending(Unknown Source)
                        - locked <0x00000000ee5416d8> (a java.lang.ref.Reference$Lock)
                        at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
                        "main" #1 prio=5 os_prio=0 tid=0x000000000203b800 nid=0x20f4 waiting for monitor
                        entry [0x000000000238f000]
                        at java.util.concurrent.ConcurrentHashMap.clear(Unknown Source)
                        - waiting to lock <0x00000000ee47c720> (a java.util.concurrent.Concurren
                        tHashMap$ReservationNode)
                        at com.serotonin.m2m2.i18n.Translations.clearCache(Translations.java:46)
                            at com.serotonin.m2m2.Main.main(Main.java:110)
                        "VM Thread" os_prio=2 tid=0x0000000055cd0000 nid=0xca8 runnable
                        "GC task thread#0 (ParallelGC)" os_prio=0 tid=0x0000000002052000 nid=0x218c runn
                        able
                        "GC task thread#1 (ParallelGC)" os_prio=0 tid=0x0000000002053800 nid=0x142c runn
                        able
                        "GC task thread#2 (ParallelGC)" os_prio=0 tid=0x0000000002055000 nid=0x23c4 runn
                        able
                        "GC task thread#3 (ParallelGC)" os_prio=0 tid=0x0000000002058800 nid=0x23e4 runn
                        able
                        "VM Periodic Task Thread" os_prio=2 tid=0x0000000057223800 nid=0x145c waiting on
                        condition
                        JNI global references: 230
                        Heap
                        PSYoungGen total 218624K, used 67668K [0x00000000e0b80000, 0x00000000ef880
                        000, 0x0000000100000000)
                        eden space 196608K, 31% used [0x00000000e0b80000,0x00000000e4858fd0,0x00000000
                        ecb80000)
                        from space 22016K, 24% used [0x00000000ee300000,0x00000000ee83c1c0,0x00000000e
                        f880000)
                        to space 23040K, 0% used [0x00000000ecb80000,0x00000000ecb80000,0x00000000ee
                        200000)
                        ParOldGen total 64512K, used 32265K [0x00000000a2200000, 0x00000000a61000
                        00, 0x00000000e0b80000)
                        object space 64512K, 50% used [0x00000000a2200000,0x00000000a41825a8,0x0000000
                        0a6100000)
                        Metaspace used 18047K, capacity 18322K, committed 18688K, reserved 106496
                        0K
                        class space used 2408K, capacity 2489K, committed 2560K, reserved 1048576K
                          Is it possible you only have the jre installed and not the jdk? What is the result of "echo $JAVA_HOME"
                            Hi mmmmmt,
                            What are your computer's timezone and language settings?
                            If you can, can you post the results of the hard kill on a startup without modules?
                              susana
                              Hi, I have the same problem with the new version 3.2.0. when I try to boot the ma-start in windows and in Linux, it does not work. I did other way too, in the modules folder, I download the zip modules with every dependency module and restart too but it does not work either. Now, I have installed the version 3.0 and I want to upgrade because I need to use the SVG object like "ma-svg" because of the version 3.0 does not exist. I have Java 8 installed and the version 3.0 is working, then I don't know if the specification have changed or it is a bug in the new version.
                              Could you tell me what is wrong and how to resolve it?
                              Thank you in advance.
                                Hi mmmmt and susana,
                                I have sent you both an email with a possible solution. Please try it and let me know if it solves the issue!
                                  mmmmmt
                                  Issue fixed, thanks.
                                    Thanks for getting us that console output!
                                      stensma @phildunlap
                                      @phildunlap It looks like the same issue i have posted on my mini mac
                                      I got the java to hang.
                                      Please provide the same info and post a answer on the forum what happens
                                        Hi stensma,
                                        We'll be releasing the fix in 3.2.1 on Monday most likely. I will go ahead and email you the fix too, but you'll want to delete it next time you update.
                                        That sentence is an imperative! You can consult github if you like, but it's a bug. mmmmmt's thread dump is what happens.
                                          3.2.1 was released with this fix and a few other updates.
                                          • B Offline
                                            bux236
                                            I'm getting the following msg when Starting after performing an upgrade,
                                            "Core upgrade found...
                                            No Jar utility found to extract upgrade, Please manually unzip core upgrade and
                                            restart Mango..."
                                            How do I rectify this please?
