    Data units in DGlux
    6 Posts 3 Posters 3.7k Views 2 Watching
      Chromeaccent
      Hi all, I have noticed that the displayed values in DGLux for some of the data points I am reading have a question mark ( ?)beside the values even though they display correctly in Mango on the watch lists. Not all values are affected only the temperature values. How do I correct this?
        Hi Chromeaccent,
        What unit do you have your temperature points set to? What sort of text renderer options do they have?
          Chromeaccent
          Hi Philip,
          The temperature points are set to deg C. I have Type set to Analog,
          Use unit symbol as suffix is checked and format as 0.0.
            I would check to make sure you don't have a "/" in the name or a space at the end of the name. If you can't figure it out, post the JSON of your datapoint so we can look.
              Hi Chromeaccent,
              I believe that's caused by DGLux not supporting the C character used by the Units library. If you take a close look at that C, it's pretty fancy, it's a ℃ as opposed to a °C and DGLux 2.5 simply doesn't support that character.
              To fix, you can use the °C version in the text renderer's suffix, after you uncheck the 'use unit as suffix' box of the text renderer.
                Chromeaccent
                Thanks, the change of the type of C worked.
