<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Data units in DGlux]]></title><description><![CDATA[<p dir="auto">Hi all, I have noticed that the displayed values in DGLux for some of the data points I am reading have a  question mark ( ?)beside the values even though they display correctly in Mango on the watch lists.  Not all values are affected only the temperature values. How do I correct this?</p>
]]></description><link>https://forum.mango-os.com/topic/2671/data-units-in-dglux</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 01:42:29 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2671.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Feb 2017 19:31:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Data units in DGlux on Fri, 17 Feb 2017 15:56:46 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, the change of the type of C worked.</p>
]]></description><link>https://forum.mango-os.com/post/13927</link><guid isPermaLink="true">https://forum.mango-os.com/post/13927</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Fri, 17 Feb 2017 15:56:46 GMT</pubDate></item><item><title><![CDATA[Reply to Data units in DGlux on Thu, 16 Feb 2017 15:38:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Chromeaccent,</p>
<p dir="auto">I believe that's caused by DGLux not supporting the C character used by the Units library. If you take a close look at that C, it's pretty fancy, it's a ℃ as opposed to a °C and DGLux 2.5 simply doesn't support that character.</p>
<p dir="auto">To fix, you can use the °C version in the text renderer's suffix, after you uncheck the 'use unit as suffix' box of the text renderer.</p>
]]></description><link>https://forum.mango-os.com/post/13916</link><guid isPermaLink="true">https://forum.mango-os.com/post/13916</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 16 Feb 2017 15:38:01 GMT</pubDate></item><item><title><![CDATA[Reply to Data units in DGlux on Thu, 16 Feb 2017 14:40:00 GMT]]></title><description><![CDATA[<p dir="auto">I would check to make sure you don't have a "/" in the name or a space at the end of the name.  If you can't figure it out, post the JSON of your datapoint so we can look.</p>
]]></description><link>https://forum.mango-os.com/post/13912</link><guid isPermaLink="true">https://forum.mango-os.com/post/13912</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 16 Feb 2017 14:40:00 GMT</pubDate></item><item><title><![CDATA[Reply to Data units in DGlux on Thu, 16 Feb 2017 14:19:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi Philip,</p>
<p dir="auto">The temperature points are set to deg C. I have Type set to Analog,<br />
Use unit symbol as suffix is checked and format as 0.0.</p>
]]></description><link>https://forum.mango-os.com/post/13910</link><guid isPermaLink="true">https://forum.mango-os.com/post/13910</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Thu, 16 Feb 2017 14:19:11 GMT</pubDate></item><item><title><![CDATA[Reply to Data units in DGlux on Wed, 15 Feb 2017 19:49:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi Chromeaccent,</p>
<p dir="auto">What unit do you have your temperature points set to? What sort of text renderer options do they have?</p>
]]></description><link>https://forum.mango-os.com/post/13904</link><guid isPermaLink="true">https://forum.mango-os.com/post/13904</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 15 Feb 2017 19:49:33 GMT</pubDate></item></channel></rss>
