    How to simulate presetPicker change with buttons?
    13 Posts 6 Posters 8.2k Views 5 Watching
      What version JavaScript library are you using? We just released version 3.0 of the Custom Dashboards module with the AngularJS library. This should be pretty easy to do in the Angular code.
      • N Offline
        nyoa
        Thank you for the suggestion. I updated to 3.0 just today. However, this is my first project with javascript so I'm quite unfamiliar with AngularJS.
        I'll check out the online documentation. It's a shame that the documentation in mango custom dashboards page isn't working for me. The page loads but none of the links work
        When opening the page I'm getting a lot of 404 errors to html GET messages, such as:
        GET http://localhost:8080/modules/dashboards/web/vendor/angular/angular.min.js.map [HTTP/1.1 404 Not Found 30ms]
        GET http://localhost:8080/resources/angular-resource.min.js.map [HTTP/1.1 404 Not Found 10ms]
        GET http://localhost:8080/modules/dashboards/web/vendor/angular-messages/angular-messages.min.js.map [HTTP/1.1 404 Not Found 28ms]
        GET http://localhost:8080/modules/dashboards/web/vendor/angular-animate/angular-animate.min.js.map [HTTP/1.1 404 Not Found 7ms]
          Try clearing your browser cache and see if that resolves it?
            nyoa, check you are being directed to /modules/dashboards/web/mdAdmin/ and not sbAdmin when you click the dashboards link on the menu. If not change the "Icon link destination" under "Dashboard settings" in system settings.
            Don't worry about the 404 on the .map files, its the chrome debugger trying to find source maps for the minified Javascript files.
              craig
              I also want to change the dateRangerPicker preset from a button so clicking one button updates all the pointvalues for a serial chart.
              I would like to have a series of buttons with labels "5 Minutes", "1 hour", "1 day", "1 week", "1 month" and clicking these buttons will change the preset of the date picker. I also want the buttons to change the update-interval on the ma-date-range-picker and the rollup-interval on the ma-point-values directives.
              can anyone provide an example of how this would be done?
              • Woody BeverleyW Offline
                Woody Beverley
                @Noya
                If you accomplished your presetPicker change with buttons, can you share a code snippit to help the community?
                @Craig
                I would look into using a button tag <button> with a ng-click. Give it a try in the custom dashboards play area. If you get stuck post your code here and we can help you.
                -WoodyB
                  craig
                  I don't understand how preset is different from to and from. Well to and from are date strings or possibly objects that when printed render as date string. preset seems to be a ng-model object that makes a select box, but I am not sure how to refer to preset to set it programmatically.
                  <html lang="en" ma-app="maMaterialDashboards">
                  <head>
                      <meta charset="utf-8">
                      <title>dash</title>
                      <link rel="stylesheet" href="/resources/angular-csp.css"></link>
                      <link rel="stylesheet" href="../vendor/angular-material/angular-material.css">
                      <link rel="stylesheet" href="../vendor/material-design-icons/iconfont/material-icons.css">
                      <link rel="stylesheet" href="../vendor/mdPickers/mdPickers.css">
                  </head>
                  <body layout="row" style="background-color: #141414; color: #D8D9DA;     font-family: "Helvetica Neue",Helvetica,Arial,sans-serif;
                      font-size: 1rem;
                      line-height: 1.5">
                      <div ng-if="appLoading">
                          <span>App is loading..</span>
                  <div ng-cloak layout="column" style="width: 100%">
                    <div style="background-color: #1f1d1d;">
                  	<ma-point-values point-xid="DP_923401" point="Plant_Flow" values="Plant_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"> </ma-point-values>
                  	<ma-point-values point-xid="DP_299411" point="U1_Flow" values="U1_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"> </ma-point-values>
                  	<ma-point-values point-xid="DP_777475" point="U2_Flow" values="U2_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"> </ma-point-values>
                  	<ma-point-values point-xid="DP_030020" point="HPL_PV" values="HPL_PVValues" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"> </ma-point-values>
                  	<ma-serial-chart style="height: 300px; width: 100%"
                  		series-1-values="Plant_FlowValues" series-1-point="Plant_Flow" series-1-color="green" series-1-title="Plant Flow"
                  		series-2-values="U1_FlowValues" series-2-point="U1_Flow" series-2-color="white" series-2-title="U1 Flow"
                  		series-3-values="U2_FlowValues" series-3-point="U2_Flow" series-3-color="pink" series-3-title="U2 Flow"
                  		series-4-values="HPL_PVValues" series-4-point="HPL_PV" series-4-color="blue" series-4-title="Headpond Level" series-4-axis="right"
                  		options="{
                  				legend:{spacing:0, fontSize:10, valueWidth:32,  color:'#D8D9DA'},
                  				color:'#D8D9DA',
                  				titles:[{text:'Flow and Level'}],
                  				valueAxes:[{title:'Flow (m³/s)', gridColor:'#444343', axisColor:'#444343'},
                  					{title:'Level (m ASL)', gridColor:'#444343', axisColor:'#444343'}],
                  				categoryAxis:{gridColor:'#444343', axisColor:'#444343'}
                  	</ma-serial-chart>
                      <ma-date-range-picker from="from" to="to" preset="LAST_1_DAYS" update-interval="5 seconds"> </ma-date-range-picker>
                      <md-button class="md-raised" ng-click="preset='LAST_12_HOURS'">12 hr</md-button>
                  To: {{to}}
                  Preset: {{preset}}
                      <script src="/resources/require.js"></script>
                      <script src="/resources/loaderConfig.js"></script>
                      <script src="../js/loaderConfig.js"></script>
                  	<script type="text/javascript">require(['dashboards/templates/extendApp']);</script>
                  </body>
                  </html>
                    Woody Beverley
                    This is a great post Craig thank you for all the details and code. It's posts like these that can really benefit the whole community.
                    I understand the problem but I don't have a solution. Perhaps some others will jump in soon and help out. I think the best place to look for clues is in the directive code scripts to see how this all comes together.
                    Here's the path <Mango Root>/web/modules/dashboards/web/js/mango-3.0/directives
                    I'll keep looking to this as I have time. I'm sure there's a solution right around the corner.
                    -WoodyB
                    • Will GellerW Offline
                      Will Geller
                      Preset on <md-date-range-picker> takes a string as well and therefore you could use angular variables to dynamically set it. Here are the possible options for the preset:
                      LAST_5_MINUTES
                      LAST_15_MINUTES
                      LAST_30_MINUTES
                      LAST_1_HOURS
                      LAST_3_HOURS
                      LAST_6_HOURS
                      LAST_12_HOURS
                      LAST_1_DAYS
                      LAST_1_WEEKS
                      LAST_2_WEEKS
                      LAST_1_MONTHS
                      LAST_3_MONTHS
                      LAST_6_MONTHS
                      LAST_1_YEARS
                      LAST_2_YEARS
                      DAY_SO_FAR
                      WEEK_SO_FAR
                      MONTH_SO_FAR
                      YEAR_SO_FAR
                      PREVIOUS_DAY
                      PREVIOUS_WEEK
                      PREVIOUS_MONTH
                      PREVIOUS_YEAR
                      Here is some code that may work to set the default to last 30 min, make the date picker hidden, and have a button that will set the preset to last 12 hours ( I have not tested yet though I will update if needed)
                      <div ng-init="myPreset='LAST_30_MINUTES'">
                           <ma-date-range-picker from="from" to="to" preset="{{myPreset}}" update-interval="5 seconds" style="display:none;"> </ma-date-range-picker>
                           <md-button class="md-raised" ng-click="myPreset ='LAST_12_HOURS'">12 hr</md-button>
                        craig
                        right, works now:
                        <ma-point-values point-xid="DP_923401" point="Plant_Flow" values="Plant_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                        	<ma-point-values point-xid="DP_299411" point="U1_Flow" values="U1_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                        	<ma-point-values point-xid="DP_777475" point="U2_Flow" values="U2_FlowValues" from="from" to="to" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                        	<ma-point-values point-xid="DP_030020" point="HPL_PV" values="HPL_PVValues" from="from" to="to" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                        		options="{
                        				color:'#D8D9DA',
                        				categoryAxis:{gridColor:'#444343', axisColor:'#444343', startEffect:'elastic'}
                        	</ma-serial-chart>
                            <ma-date-range-picker from="from" to="to" preset="{{presetPeriod}}" update-interval="{{updateInterval}}" style="display: none"> </ma-date-range-picker>
                            <md-button class="md-raised" ng-click="presetPeriod='LAST_15_MINUTES';rollupInterval='1 seconds'; updateInterval='5 seconds'">15 min</md-button>
                            <md-button class="md-raised" ng-click="presetPeriod='LAST_1_HOURS'; rollupInterval='1 seconds'; updateInterval='10 seconds'">1 hour</md-button>
                            <md-button class="md-raised" ng-click="presetPeriod='LAST_1_DAYS'; rollupInterval='1 minutes'; updateInterval='1 minutes'">1 day</md-button>
                            <md-button class="md-raised" ng-click="presetPeriod='LAST_1_WEEKS'; rollupInterval='5 minutes'; updateInterval='15 minutes'">1 week</md-button>
                            <md-button class="md-raised" ng-click="presetPeriod='LAST_1_MONTHS'; rollupInterval='15 minutes'; updateInterval='15 minutes'">1 month</md-button>
                          Will Geller
                          Yep looks like you got the hang of it
                            Hi Craig, this is an alternative aproach you may be interested in. It is more flexible in that you can use whatever periods you desire and you don't need to use <ma-date-range-picker>.
                            <md-button class="md-raised" ng-click="subtractX=15;subtractUnit='minute';rollupInterval='1 seconds'; updateInterval='5 seconds'">15 min</md-button>
                            <md-button class="md-raised" ng-click="subtractX=1;subtractUnit='hour'; rollupInterval='1 seconds'; updateInterval='10 seconds'">1 hour</md-button>
                            <md-button class="md-raised" ng-click="subtractX=1;subtractUnit='day'; rollupInterval='1 minutes'; updateInterval='1 minutes'">1 day</md-button>
                            <md-button class="md-raised" ng-click="subtractX=1;subtractUnit='week'; rollupInterval='5 minutes'; updateInterval='15 minutes'">1 week</md-button>
                            <md-button class="md-raised" ng-click="subtractX=1;subtractUnit='month'; rollupInterval='15 minutes'; updateInterval='15 minutes'">1 month</md-button>
                            <ma-now update-interval="{{updateInterval}}" output="now"></ma-now>
                            <ma-calc input="now | moment:'subtract':subtractX:subtractUnit" output="from"></ma-calc>
                            <ma-point-values point-xid="DP_923401" point="Plant_Flow" values="Plant_FlowValues" from="from" to="now" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                            <ma-point-values point-xid="DP_299411" point="U1_Flow" values="U1_FlowValues" from="from" to="now" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                            <ma-point-values point-xid="DP_777475" point="U2_Flow" values="U2_FlowValues" from="from" to="now" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
                            <ma-point-values point-xid="DP_030020" point="HPL_PV" values="HPL_PVValues" from="from" to="now" rollup="AVERAGE" rollup-interval="{{rollupInterval}}"> </ma-point-values>
