    Failure to start/restart Mango - thread exception
    4 Posts 3 Posters 2.3k Views 2 Watching
      mlavelle42
      I'm running Mango 2.7.10 on the Raspberry Pi version 4.1.18-v7+. I originally had a startup problem about a month ago but after that the system ran OK - until yesterday.
      Yesterday it became non-responsive. Restarting Mango was not successful. I also restarted Linux several times - to no avail. Mango is set to auto-start on bootup too - and, of course, it didn't.
      I see the following in my command window after startup.
      INFO 2016-04-20 13:33:59,593 (com.serotonin.m2m2.Lifecycle.terminate:344) - Mango Lifecycle terminating...
      Exception in thread "high-pool-1-thread-2" java.lang.NullPointerException
      at com.serotonin.m2m2.CoreLicenseDefinition$2.run(CoreLicenseDefinition.java:149)
      at com.serotonin.timer.sync.Synchronizer$TaskWrapper.run(Synchronizer.java:155)
      INFO 2016-04-20 13:33:59,726 (com.serotonin.m2m2.Lifecycle.terminate:446) - Mango Lifecycle terminated.
      INFO 2016-04-20 13:33:59,731 (com.serotonin.m2m2.Lifecycle.terminate:344) - Mango Lifecycle terminating...
      ma-start: MA done
      The ma.log file now shows this...
      at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:199)
      at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
      at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
      ... 12 more
      Earlier the startup process showed this...
      ma-start: MA done
      I was suspicious of the "high-pool-1-thread-2" exception. Just before it would not run properly I noticed a total Exceptions of about 27,000 - which seemed like a huge number.
      Meanwhile the H2 database is up to 593 MB, which I assume is partly because of the alerts (alerts may be the wrong word - maybe "exceptions") logged within.
      Questions:
      • Any comment on the "high-pool..." exception? Could it be caused by the large number of alerts?
      • Is there any way to clean out the alerts manually?
      Any suggestions to fix this problem?
        @mlavelle42 said in Failure to start/restart Mango - thread exception:
        This is probably some sympathetic exception message the real problem must be earlier in the log file. Mango has chosen to shut down and is having issues because it was not fully initialized.
        Yes there is a shell script at bin/h2-web-console.sh that will open up a port that you can connect to via a web browser. Read the script first before executing it. This will provide you with an SQL console that you can explore and modify the database. Use at your own risk.
          mlavelle42
          I was able to access the database using H2 db tools. However I'm unable to see the data tables. Below is a snapshot of my connection.
          ![alt text](0_1461269857704_Screen Shot 2016-04-21 at 4.10.26 PM.png image url)
          Here's what I see after connecting:
          What am I missing? Why don't the data tables show up as in your example?
            This should help: http://help.infiniteautomation.com/m/55730/l/519384-about-the-h2-database
