    Parsing of Time in HTTP POST ?
    13 Posts 3 Posters 5.8k Views 2 Watching
      pascal
      I have been using "YYYYMMDDhhmmss" format for date without any problem.
      Now because the same device should send data to two different Host I have to move to the UTC format (millis seconds from 1, 1, 1970).
      I experienced bad parsing of the timestamp while the same string is correctly parsed by a Web UTC -> Date string application.
      Can anyone explain exactly how such timestamp should be formatted for Mango :
      • 1231233112
      • 1231233112. (decimal point)
      • 1231233112.000
      • 1231233112.0000
      • 1231233112000 (no decimal point)
      Thanks in advance for your assistance.
      Pascal
        Hi Pascal,
        I've never tried it this way but dates in Mango are generally milliseconds so like 1231233112000 would be the way to represent a Unix type timestamp in Mango.
          pascal
          It doesn't work that way.
          Mango is replacing the timestamp with the server one as if there were no timestamp in the POST.
          When publisher sends data out it looks like the timestamp is like "123245654.1123" with a decimal point (I see that on the
          This is what I do in the Gateway :
          Format the number of seconds since Epoch, adding 3 x '0' at the end. :
          snprintf(WorkBuffer, sizeof(WorkBuffer), "%ld000;", ModbusTimestamp);
          This the resulting POST contents :
          POST /httpds HTTP/1.1
          HOST: mangolocal.pgpsmartsensing.be
          Content-Type: application/x-www-form-urlencoded
          Content-Length: 438
          __device=PGP_001EC01EF773&__time=1441120275000&__meter=14100021&VoltagePhA=234.200&VoltagePhB=0.000&VoltagePhC=0.000&Frequency=50.010&WattPhA=1.720&WattPhB=0.000&WattPhC=0.000&FactorTotal=0.980&FactorPhA=0.980&FactorPhB=0.000&FactorPhC=0.000&IndexConsoTf1=29.840&IndexConsoTf2=0.000&IndexConsoPhA=29.840&IndexConsoPhB=0.000&IndexConsoPhC=0.000&IndexProdTf1=0.890&IndexProdTf2=0.000&IndexProdPhA=0.890&IndexProdPhB=0.000&IndexProdPhC=0.000
          This is what is decoded by Mango :
          Source: 81.243.242.216
          Device ID: PGP_001EC01EF773
          Time: 1441/12/15
          FactorPhB=0.000
          FactorPhA=0.980
          FactorTotal=0.980
          FactorPhC=0.000
          WattPhC=0.000
          WattPhB=0.000
          VoltagePhA=234.500
          IndexConsoTf1=29.960
          IndexConsoTf2=0.000
          VoltagePhC=0.000
          VoltagePhB=0.000
          WattPhA=1.740
          IndexConsoPhC=0.000
          IndexConsoPhB=0.000
          IndexConsoPhA=29.960
          __meter=14100021
          IndexProdPhC=0.000
          IndexProdTf2=0.000
          IndexProdPhB=0.000
            pascal
            In this case Mango hase tried to interpret the timestamp creating a date with 1441 as the year.
              It sounds like the HTTP receiver is not designed to use a Unix style time. We can look at this and see if it's something we can add.
                pascal
                I tried also adding a decimal point :
                This is the result (The time displayed is the server time because the 4 successive POSTs sent are "dated" with 1 second delay between each of them instead of 15" as the timestamp sent be the Gateway specifies) :
                Time: 17:19:23
                FactorPhB=0.000
                FactorPhA=0.980
                FactorTotal=0.980
                FactorPhC=0.000
                WattPhC=0.000
                WattPhB=0.000
                VoltagePhA=234.000
                IndexConsoTf1=30.110
                IndexConsoTf2=0.000
                VoltagePhC=0.000
                VoltagePhB=0.000
                WattPhA=1.720
                IndexConsoPhC=0.000
                IndexConsoPhB=0.000
                IndexConsoPhA=30.110
                __meter=14100021
                IndexProdPhC=0.000
                IndexProdTf2=0.000
                IndexProdPhB=0.000
                IndexProdTf1=0.890
                IndexProdPhA=0.890
                  pascal,
                  You were using the correct format in your example post: __time=1441120275000
                  I just ran a few tests and did some debugging. I found a bug where the code was first converting the __time parameter via the 'yyyyMMddHHmmss' format, since the timestamp actually does translate into a valid date it was returning this.
                  I have fixed this bug in the 2.6.0 Core and just pushed out a new version of this module for the 2.5.2 core, the new module version is 1.4.8 and you should be able to do an automatic upgrade from the modules page if you are on Core 2.5.2 or later.
                  The new logic will first convert the value using the 'yyyyMMddHHmmss' format and then compare the date. If the data is before Jan 1 1970 then it will try the other formats. In your case the proper time is then used.
                    pascal
                    Thank you !
                      pascal
                      Keep in mind that in 2032 the timestamp will start with 1970.... and the decoded year will be > 1970.
                        pascal
                        After testing the updated version, it looks like there is a difference of 1 hour between the time decoded by Mango from "YYYYMMDDHHMMSS" and the UTC timestamp.
                        The first one is correct and the seconde one is 1 hour later ?
                        I have tried both and it is not correct.
                        Any clue ?
                          pascal,
                          Thanks for the note on the 2032 problem, if you are still using this module in 2032 I'll give you a free enterprise license to Mango with an upgraded module!
                          As for the 1 hour off problem, could it be a timezone problem? Is there a 1hr time difference between where your Mango server is vs where the http request is coming from? Mango will parse the UTC timestamp into a date using its local timezone. Then of course there is the User's timezone that will re-convert the timestamps into a Date when viewed through Mango.
                          One way to confirm this would be to check the ts column for the data point in the pointValues table. It should match exactly what you are sending through.
                            pascal
                            I will check but what looks strange to me is that I tried sending the same date+time in the 2 formats and one was correctly received the other one, with a difference of 1 hour.
                              If you still can't make sense of it just send me the strings you used for both formats, I can check them against my test Mango.
