    Parsing of Time in HTTP POST ?
    13 Posts 3 Posters 8.6k Views 2 Watching
      Hi Pascal,
      I've never tried it this way but dates in Mango are generally milliseconds so like 1231233112000 would be the way to represent a Unix type timestamp in Mango.
        pascal
        It doesn't work that way.
        Mango is replacing the timestamp with the server one as if there were no timestamp in the POST.
        When publisher sends data out it looks like the timestamp is like "123245654.1123" with a decimal point (I see that on the
        This is what I do in the Gateway :
        Format the number of seconds since Epoch, adding 3 x '0' at the end. :
        snprintf(WorkBuffer, sizeof(WorkBuffer), "%ld000;", ModbusTimestamp);
        This the resulting POST contents :
        POST /httpds HTTP/1.1
        HOST: mangolocal.pgpsmartsensing.be
        Content-Type: application/x-www-form-urlencoded
        Content-Length: 438
        __device=PGP_001EC01EF773&__time=1441120275000&__meter=14100021&VoltagePhA=234.200&VoltagePhB=0.000&VoltagePhC=0.000&Frequency=50.010&WattPhA=1.720&WattPhB=0.000&WattPhC=0.000&FactorTotal=0.980&FactorPhA=0.980&FactorPhB=0.000&FactorPhC=0.000&IndexConsoTf1=29.840&IndexConsoTf2=0.000&IndexConsoPhA=29.840&IndexConsoPhB=0.000&IndexConsoPhC=0.000&IndexProdTf1=0.890&IndexProdTf2=0.000&IndexProdPhA=0.890&IndexProdPhB=0.000&IndexProdPhC=0.000
        This is what is decoded by Mango :
        Source: 81.243.242.216
        Device ID: PGP_001EC01EF773
        Time: 1441/12/15
        FactorPhB=0.000
        FactorPhA=0.980
        FactorTotal=0.980
        FactorPhC=0.000
        WattPhC=0.000
        WattPhB=0.000
        VoltagePhA=234.500
        IndexConsoTf1=29.960
        IndexConsoTf2=0.000
        VoltagePhC=0.000
        VoltagePhB=0.000
        WattPhA=1.740
        IndexConsoPhC=0.000
        IndexConsoPhB=0.000
        IndexConsoPhA=29.960
        __meter=14100021
        IndexProdPhC=0.000
        IndexProdTf2=0.000
        IndexProdPhB=0.000
          pascal
          In this case Mango hase tried to interpret the timestamp creating a date with 1441 as the year.
            It sounds like the HTTP receiver is not designed to use a Unix style time. We can look at this and see if it's something we can add.
              pascal
              I tried also adding a decimal point :
              This is the result (The time displayed is the server time because the 4 successive POSTs sent are "dated" with 1 second delay between each of them instead of 15" as the timestamp sent be the Gateway specifies) :
              Time: 17:19:23
              FactorPhB=0.000
              FactorPhA=0.980
              FactorTotal=0.980
              FactorPhC=0.000
              WattPhC=0.000
              WattPhB=0.000
              VoltagePhA=234.000
              IndexConsoTf1=30.110
              IndexConsoTf2=0.000
              VoltagePhC=0.000
              VoltagePhB=0.000
              WattPhA=1.720
              IndexConsoPhC=0.000
              IndexConsoPhB=0.000
              IndexConsoPhA=30.110
              __meter=14100021
              IndexProdPhC=0.000
              IndexProdTf2=0.000
              IndexProdPhB=0.000
              IndexProdTf1=0.890
              IndexProdPhA=0.890
                pascal,
                You were using the correct format in your example post: __time=1441120275000
                I just ran a few tests and did some debugging. I found a bug where the code was first converting the __time parameter via the 'yyyyMMddHHmmss' format, since the timestamp actually does translate into a valid date it was returning this.
                I have fixed this bug in the 2.6.0 Core and just pushed out a new version of this module for the 2.5.2 core, the new module version is 1.4.8 and you should be able to do an automatic upgrade from the modules page if you are on Core 2.5.2 or later.
                The new logic will first convert the value using the 'yyyyMMddHHmmss' format and then compare the date. If the data is before Jan 1 1970 then it will try the other formats. In your case the proper time is then used.
                  pascal
                  Thank you !
                    pascal
                    Keep in mind that in 2032 the timestamp will start with 1970.... and the decoded year will be > 1970.
                      pascal
                      After testing the updated version, it looks like there is a difference of 1 hour between the time decoded by Mango from "YYYYMMDDHHMMSS" and the UTC timestamp.
                      The first one is correct and the seconde one is 1 hour later ?
                      I have tried both and it is not correct.
                      Any clue ?
                        pascal,
                        Thanks for the note on the 2032 problem, if you are still using this module in 2032 I'll give you a free enterprise license to Mango with an upgraded module!
                        As for the 1 hour off problem, could it be a timezone problem? Is there a 1hr time difference between where your Mango server is vs where the http request is coming from? Mango will parse the UTC timestamp into a date using its local timezone. Then of course there is the User's timezone that will re-convert the timestamps into a Date when viewed through Mango.
                        One way to confirm this would be to check the ts column for the data point in the pointValues table. It should match exactly what you are sending through.
                          pascal
                          I will check but what looks strange to me is that I tried sending the same date+time in the 2 formats and one was correctly received the other one, with a difference of 1 hour.
                            If you still can't make sense of it just send me the strings you used for both formats, I can check them against my test Mango.
