    Mango 5 - bugs or user non-friendly things
    2 Posts 2 Posters 1.2k Views 2 Watching
      ms_brunette
      Hello!
      I am trying to work in Mango 5 after Mango 3 and there is things that look and work differently> Please help me understand if there are bugs or what I'm doing wrong.
      Tag <ma-dialog>
      If a dialog window takes up the entire height of the page, the title of this window hides under the upper bar of Mango
      Tag <ma-bar-display>
      The bar is filled if value < 0 (even if minimum sets to 0)
      Showing of listboxes
      The width of any listbox is almost 0 (by default)
      In the data sources menu
      After trying sort data points by their tag (which don’t work) any sort or filter (even not by tag) is block until refreshing page or selecting another data source
      Menu of WatchLists
      The default parameters don’t change when the chosen WL is changed (you can see a parameter in the default parameter field which is absent in the chosen WL)
      Creating WL
      Building a WL with “WL settings” as “point query” and “parameter type” as “data point tag” and select a tag for this parameter – in the resulting list there is a choice like “No <tag_name> tag” (where <tag.name> is name of selecting parameter’s tag)
      In settings of parameter there is an opportunity to set a restriction. How should I restrict choosing tag to a few different strings? (comma separated enumeration doesn’t work)
      I have screenshots if it needs for better understanding but I can't add it because "Imgur is temporarily over capacity. Please try again later."
        MattFox @ms_brunette
        @ms_brunette happy to help, perhaps you can output your markup into some code blocks </> for me?
        Feel free to PM as well
