    Can not login after activating sessionCookie.secure=true
    5 Posts 2 Posters 1.3k Views 2 Watching
      Malaguena
      Hi all,
      I have uncommented sessionCookie.secure=true on env.propertites file and restarted Mango v4.0.0.beta5. Then, when I try to login, my credentials does not accepted and get an error "Login failed — Bad credentials".
      What could be the possible cause for that?
      I that enough to just activate sessionCookie.secure=true, in order to add secure flag to session?
      Thanks in advance!
        Its likely used in conjuction with the ssl settings Id imagine, going off of the name of the property
          Malaguena
          Hi @MattFox ,
          You mean that in order to add secure flag to session first we should configure ssl settings on env.properties file? Then activate sessionCookie.secure=true.
          Am I right?
            I believe that is the case, yes.
            Sorry I have not looked at the help docs to give you a better answer
              I was a bit off the mark.
              It relates to using the cloud connect module:
              https://docs-v3.mango-os.com/cloud-connect?rq=sessioncookie
              if you want a secure flag on your browser, set up SSL or a reverse proxy with ssl at the front.
