    Force read SNMP
    10 Posts 2 Posters 5.4k Views 2 Watching
    • J Offline
      jcaballeroa
      I am trying to force reading multiple SNMP type DataPoints via button in "Data Point Details" window and also via script using RuntimeManager.refreshDataPoint (XID) function.
      But in both ways I get a binding error with the equipment and the acquisition of the OID information does not work. I have tried it with SNMP peripherals of different types and it happens to me with all.
      Is it not possible to do the immediate acquisition of the datapoint in this way? Do I need to additionally configure anything to use this method?
      • J Offline
        jcaballeroa
        Any idea????
        I have been able to see through wireshark captures that the difference between a polling and forcing the reading of the SNMP datapoint is that through the forced reading, Mango does not send the requested oid in the UDP datagram. It's a bug?
        • CraigWebC Offline
          CraigWeb
          HI @jcaballeroa
          The force read command does a batch poll then only updates that point. Is the point perhaps a Trap point only ?
          • J Offline
            jcaballeroa
            @craigweb said in Force read SNMP:
            Hi @CraigWeb, thanks for your answer.
            I have only two options to configure this DataPoint: "Poll and trap" or "Trap only".
            My configuration is "Poll and trap" and the force read command not work properly or i am made something bad.
            • CraigWebC Offline
              CraigWeb
              You cannot force read Trap only.
              There is a . in the first char of the OID. Are you sure that is correct?
              • J Offline
                jcaballeroa @CraigWeb
                @craigweb
                Yes, I'm pretty sure it's correct.
                In fact, the usual polling of the datasource does work correctly. If I configure it for example every 10 minutes, I get the value without problem. The problem is if I need to force the value at a given moment before those 10 minutes, I have tried to force the reading and that is when it gives the error. The difference between both requests is the capture of the wireshark that I put in a previous post, by means of polling the datasource the oid is included in the datagram, but if I make a forced request the oid does not appear in the datagram.
                • CraigWebC Offline
                  CraigWeb
                  ok, give me a little time I have an snmp modem I can test with, I will see if I can replicate the error.
                  • J Offline
                    jcaballeroa
                    Of course, the time you need. Thank you very much for the feedback.
                    • J Offline
                      jcaballeroa
                      @CraigWeb Do you have any choice?
                      • CraigWebC Offline
                        CraigWeb
                        @jcaballeroa I was able to replicate it, there is a bug. Once the bug is fixed it will be announced in the forum.
