    HS_ERR_PID###.log file
    4 Posts 3 Posters 1.9k Views 3 Watching
    • S Offline
      sky_watcher
      Hello,
      On one of my MangoES that is installed into the customer site I'm getting a lot of the files named "hs_err_pid###.log". When I open them I see that is a memory issue.
      Can somebody help me with this problem?
      Thanks.
      • CraigWebC Offline
        CraigWeb
        Hi @sky_watcher
        When java crashes it will create a log file like that. Can't really give any more info without the log file. Are you running v3.7 you may need to upgrade you java.
          I have the same error:
          # There is insufficient memory for the Java Runtime Environment to continue.
          # Native memory allocation (mmap) failed to map 16106127360 bytes for committing reserved memory.
          # Possible reasons:
          #   The system is out of physical RAM or swap space
          #   The process is running with CompressedOops enabled, and the Java Heap may be blocking the growth of the native heap
          # Possible solutions:
          #   Reduce memory load on the system
          #   Increase physical memory or swap space
          #   Check if swap backing store is full
          #   Decrease Java heap size (-Xmx/-Xms)
          #   Decrease number of Java threads
          #   Decrease Java thread stack sizes (-Xss)
          #   Set larger code cache with -XX:ReservedCodeCacheSize=
          #   JVM is running with Zero Based Compressed Oops mode in which the Java heap is
          #     placed in the first 32GB address space. The Java Heap base address is the
          #     maximum limit for the native heap growth. Please use -XX:HeapBaseMinAddress
          #     to set the Java Heap base and to place the Java Heap above 32GB virtual address.
          # This output file may be truncated or incomplete.
          #  Out of Memory Error (os_linux.cpp:2908), pid=10007, tid=10008
          # JRE version:  (14.0.1+7) (build )
          # Java VM: OpenJDK 64-Bit Server VM (14.0.1+7, mixed mode, sharing, tiered, compressed oops, g1 gc, linux-amd64)
          # No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
          ---------------  S U M M A R Y ------------
          Command Line: -Xms15g -Xmx15g --add-modules=java.activation,java.xml.bind -Dlog4j.configurationFile=file:/opt/mango/classes/log4j2.xml -Dma.home=/opt/mango com.serotonin.m2m2.Main
          Host: Intel(R) Xeon(R) CPU, 6 cores, 21G, Debian GNU/Linux 9 (stretch)
          Time: Wed Sep 16 15:54:24 2020 NZST elapsed time: 0 seconds (0d 0h 0m 0s)
          ---------------  T H R E A D  ---------------
          Current thread (0x00007f934002b800):  JavaThread "Unknown thread" [_thread_in_vm, id=10008, stack(0x00007f9349869000,0x00007f934996a000)]
          Stack: [0x00007f9349869000,0x00007f934996a000],  sp=0x00007f9349968380,  free space=1020k
          Native frames: (J=compiled Java code, A=aot compiled Java code, j=interpreted, Vv=VM code, C=native code)
          V  [libjvm.so+0xf1cf46]  VMError::report_and_die(int, char const*, char const*, __va_list_tag*, Thread*, unsigned char*, void*, void*, char const*, int, unsigned long)+0x396
          V  [libjvm.so+0xf1db0b]  VMError::report_and_die(Thread*, char const*, int, unsigned long, VMErrorType, char const*, __va_list_tag*)+0x2b
          V  [libjvm.so+0x5bf1e5]  report_vm_out_of_memory(char const*, int, unsigned long, VMErrorType, char const*, ...)+0xd5
          V  [libjvm.so+0xbc5358]  os::pd_commit_memory_or_exit(char*, unsigned long, unsigned long, bool, char const*)+0x108
          V  [libjvm.so+0xbbc68d]  os::commit_memory_or_exit(char*, unsigned long, unsigned long, bool, char const*)+0x1d
          V  [libjvm.so+0x6fc53c]  G1PageBasedVirtualSpace::commit_preferred_pages(unsigned long, unsigned long)+0x6c
          V  [libjvm.so+0x6fc8c4]  G1PageBasedVirtualSpace::commit(unsigned long, unsigned long)+0x144
          V  [libjvm.so+0x70c782]  G1RegionsLargerThanCommitSizeMapper::commit_regions(unsigned int, unsigned long, WorkGang*)+0x52
          V  [libjvm.so+0x795020]  HeapRegionManager::commit_regions(unsigned int, unsigned long, WorkGang*)+0x80
          V  [libjvm.so+0x796422]  HeapRegionManager::make_regions_available(unsigned int, unsigned int, WorkGang*)+0x42
          V  [libjvm.so+0x796979]  HeapRegionManager::expand_at(unsigned int, unsigned int, WorkGang*)+0x119
          V  [libjvm.so+0x6abf00]  G1CollectedHeap::expand(unsigned long, WorkGang*, double*)+0xe0
          V  [libjvm.so+0x6ac637]  G1CollectedHeap::initialize()+0x6b7
          V  [libjvm.so+0xedd664]  universe_init()+0x94
          V  [libjvm.so+0x7bbdb2]  init_globals()+0x52
          V  [libjvm.so+0xeb467f]  Threads::create_vm(JavaVMInitArgs*, bool*)+0x34f
          V  [libjvm.so+0x870c12]  JNI_CreateJavaVM+0x52
          C  [libjli.so+0x4b36]  JavaMain+0x86
          C  [libjli.so+0x9019]  ThreadJavaMain+0x9
          ---------------  P R O C E S S  ---------------
          Threads class SMR info:
          _java_thread_list=0x00007f9348b5ccc0, length=0, elements={
          Java Threads: ( => current thread )
          Other Threads:
            0x00007f9340074800 GCTaskThread "GC Thread#0" [stack: 0x00007f9345855000,0x00007f9345955000] [id=10009]
            0x00007f9340094800 ConcurrentGCThread "G1 Main Marker" [stack: 0x00007f9345754000,0x00007f9345854000] [id=10010]
            0x00007f9340096000 ConcurrentGCThread "G1 Conc#0" [stack: 0x00007f9345653000,0x00007f9345753000] [id=10011]
          [error occurred during error reporting (printing all threads), id 0xb, SIGSEGV (0xb) at pc=0x00007f9347c83860]
          VM state:not at safepoint (not fully initialized)
          VM Mutex/Monitor currently owned by a thread:  ([mutex/lock_event])
          [0x00007f9340026750] Heap_lock - owner thread: 0x00007f934002b800
          Heap address: 0x0000000440000000, size: 15360 MB, Compressed Oops mode: Zero based, Oop shift amount: 3
          Narrow klass base: 0x0000000000000000, Narrow klass shift: 0
          GC Heap History (0 events):
          No events
          Deoptimization events (0 events):
          No events
          Classes unloaded (0 events):
          No events
          Classes redefined (0 events):
          No events
          Internal exceptions (0 events):
          No events
          Events (3 events):
          Event: 0.001 Protecting memory [0x00007f9349869000,0x00007f934986d000] with protection modes 0
          Event: 0.001 Loaded shared library /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjava.so
          Event: 0.001 Loaded shared library /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libzip.so
          Dynamic libraries:
          55e536348000-55e536349000 r-xp 00000000 08:01 925353                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/bin/java
          55e536549000-55e53654a000 r--p 00001000 08:01 925353                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/bin/java
          55e53654a000-55e53654b000 rw-p 00002000 08:01 925353                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/bin/java
          55e536684000-55e5366a5000 rw-p 00000000 00:00 0                          [heap]
          7f92f6000000-7f92f8000000 rw-p 00000000 00:00 0
          7f92f8000000-7f92f8021000 rw-p 00000000 00:00 0
          7f92f8021000-7f92fc000000 ---p 00000000 00:00 0
          7f92fc000000-7f92fc021000 rw-p 00000000 00:00 0
          7f92fc021000-7f9300000000 ---p 00000000 00:00 0
          7f9300000000-7f9300021000 rw-p 00000000 00:00 0
          7f9300021000-7f9304000000 ---p 00000000 00:00 0
          7f93041e9000-7f9327be9000 ---p 00000000 00:00 0
          7f9327be9000-7f9327e59000 rwxp 00000000 00:00 0
          7f9327e59000-7f932817a000 ---p 00000000 00:00 0
          7f932817a000-7f93283ea000 rwxp 00000000 00:00 0
          7f93283ea000-7f932f6b1000 ---p 00000000 00:00 0
          7f932f6b1000-7f932f921000 rwxp 00000000 00:00 0
          7f932f921000-7f9336be9000 ---p 00000000 00:00 0
          7f9336be9000-7f9340000000 r--s 00000000 08:01 925278                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/modules
          7f9340000000-7f93400bc000 rw-p 00000000 00:00 0
          7f93400bc000-7f9344000000 ---p 00000000 00:00 0
          7f9344c92000-7f9345652000 rw-p 00000000 00:00 0
          7f9345652000-7f9345653000 ---p 00000000 00:00 0
          7f9345653000-7f9345753000 rw-p 00000000 00:00 0
          7f9345753000-7f9345754000 ---p 00000000 00:00 0
          7f9345754000-7f9345854000 rw-p 00000000 00:00 0
          7f9345854000-7f9345855000 ---p 00000000 00:00 0
          7f9345855000-7f9345955000 rw-p 00000000 00:00 0
          7f9345955000-7f9345a4d000 rw-p 00000000 00:00 0
          7f9345a4d000-7f9346053000 rw-p 00000000 00:00 0
          7f9346053000-7f9346058000 rw-p 00000000 00:00 0
          7f9346058000-7f934613e000 ---p 00000000 00:00 0
          7f934613e000-7f9346143000 rw-p 00000000 00:00 0
          7f9346143000-7f9346229000 ---p 00000000 00:00 0
          7f9346229000-7f9346230000 r-xp 00000000 08:01 925265                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libzip.so
          7f9346230000-7f934642f000 ---p 00007000 08:01 925265                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libzip.so
          7f934642f000-7f9346430000 r--p 00006000 08:01 925265                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libzip.so
          7f9346430000-7f9346431000 rw-p 00007000 08:01 925265                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libzip.so
          7f9346431000-7f9346455000 r-xp 00000000 08:01 925315                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjava.so
          7f9346455000-7f9346654000 ---p 00024000 08:01 925315                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjava.so
          7f9346654000-7f9346655000 r--p 00023000 08:01 925315                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjava.so
          7f9346655000-7f9346657000 rw-p 00024000 08:01 925315                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjava.so
          7f9346657000-7f9346661000 r-xp 00000000 08:01 525055                     /lib/x86_64-linux-gnu/libnss_files-2.24.so
          7f9346661000-7f9346861000 ---p 0000a000 08:01 525055                     /lib/x86_64-linux-gnu/libnss_files-2.24.so
          7f9346861000-7f9346862000 r--p 0000a000 08:01 525055                     /lib/x86_64-linux-gnu/libnss_files-2.24.so
          7f9346862000-7f9346863000 rw-p 0000b000 08:01 525055                     /lib/x86_64-linux-gnu/libnss_files-2.24.so
          7f9346863000-7f9346869000 rw-p 00000000 00:00 0
          7f9346869000-7f9346874000 r-xp 00000000 08:01 525057                     /lib/x86_64-linux-gnu/libnss_nis-2.24.so
          7f9346874000-7f9346a73000 ---p 0000b000 08:01 525057                     /lib/x86_64-linux-gnu/libnss_nis-2.24.so
          7f9346a73000-7f9346a74000 r--p 0000a000 08:01 525057                     /lib/x86_64-linux-gnu/libnss_nis-2.24.so
          7f9346a74000-7f9346a75000 rw-p 0000b000 08:01 525057                     /lib/x86_64-linux-gnu/libnss_nis-2.24.so
          7f9346a75000-7f9346a89000 r-xp 00000000 08:01 525052                     /lib/x86_64-linux-gnu/libnsl-2.24.so
          7f9346a89000-7f9346c89000 ---p 00014000 08:01 525052                     /lib/x86_64-linux-gnu/libnsl-2.24.so
          7f9346c89000-7f9346c8a000 r--p 00014000 08:01 525052                     /lib/x86_64-linux-gnu/libnsl-2.24.so
          7f9346c8a000-7f9346c8b000 rw-p 00015000 08:01 525052                     /lib/x86_64-linux-gnu/libnsl-2.24.so
          7f9346c8b000-7f9346c8d000 rw-p 00000000 00:00 0
          7f9346c8d000-7f9346c94000 r-xp 00000000 08:01 525053                     /lib/x86_64-linux-gnu/libnss_compat-2.24.so
          7f9346c94000-7f9346e93000 ---p 00007000 08:01 525053                     /lib/x86_64-linux-gnu/libnss_compat-2.24.so
          7f9346e93000-7f9346e94000 r--p 00006000 08:01 525053                     /lib/x86_64-linux-gnu/libnss_compat-2.24.so
          7f9346e94000-7f9346e95000 rw-p 00007000 08:01 525053                     /lib/x86_64-linux-gnu/libnss_compat-2.24.so
          7f9346e95000-7f9346eb0000 r-xp 00000000 08:01 925292                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjimage.so
          7f9346eb0000-7f93470af000 ---p 0001b000 08:01 925292                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjimage.so
          7f93470af000-7f93470b1000 r--p 0001a000 08:01 925292                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjimage.so
          7f93470b1000-7f93470b2000 rw-p 0001c000 08:01 925292                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjimage.so
          7f93470b2000-7f93470b9000 r-xp 00000000 08:01 525062                     /lib/x86_64-linux-gnu/librt-2.24.so
          7f93470b9000-7f93472b8000 ---p 00007000 08:01 525062                     /lib/x86_64-linux-gnu/librt-2.24.so
          7f93472b8000-7f93472b9000 r--p 00006000 08:01 525062                     /lib/x86_64-linux-gnu/librt-2.24.so
          7f93472b9000-7f93472ba000 rw-p 00007000 08:01 525062                     /lib/x86_64-linux-gnu/librt-2.24.so
          7f93472ba000-7f93473bd000 r-xp 00000000 08:01 525049                     /lib/x86_64-linux-gnu/libm-2.24.so
          7f93473bd000-7f93475bc000 ---p 00103000 08:01 525049                     /lib/x86_64-linux-gnu/libm-2.24.so
          7f93475bc000-7f93475bd000 r--p 00102000 08:01 525049                     /lib/x86_64-linux-gnu/libm-2.24.so
          7f93475bd000-7f93475be000 rw-p 00103000 08:01 525049                     /lib/x86_64-linux-gnu/libm-2.24.so
          7f93475be000-7f9348806000 r-xp 00000000 08:01 925288                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/server/libjvm.so
          7f9348806000-7f9348a06000 ---p 01248000 08:01 925288                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/server/libjvm.so
          7f9348a06000-7f9348aae000 r--p 01248000 08:01 925288                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/server/libjvm.so
          7f9348aae000-7f9348ae8000 rw-p 012f0000 08:01 925288                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/server/libjvm.so
          7f9348ae8000-7f9348b69000 rw-p 00000000 00:00 0
          7f9348b69000-7f9348cfe000 r-xp 00000000 08:01 525045                     /lib/x86_64-linux-gnu/libc-2.24.so
          7f9348cfe000-7f9348efe000 ---p 00195000 08:01 525045                     /lib/x86_64-linux-gnu/libc-2.24.so
          7f9348efe000-7f9348f02000 r--p 00195000 08:01 525045                     /lib/x86_64-linux-gnu/libc-2.24.so
          7f9348f02000-7f9348f04000 rw-p 00199000 08:01 525045                     /lib/x86_64-linux-gnu/libc-2.24.so
          7f9348f04000-7f9348f08000 rw-p 00000000 00:00 0
          7f9348f08000-7f9348f0b000 r-xp 00000000 08:01 525048                     /lib/x86_64-linux-gnu/libdl-2.24.so
          7f9348f0b000-7f934910a000 ---p 00003000 08:01 525048                     /lib/x86_64-linux-gnu/libdl-2.24.so
          7f934910a000-7f934910b000 r--p 00002000 08:01 525048                     /lib/x86_64-linux-gnu/libdl-2.24.so
          7f934910b000-7f934910c000 rw-p 00003000 08:01 525048                     /lib/x86_64-linux-gnu/libdl-2.24.so
          7f934910c000-7f9349124000 r-xp 00000000 08:01 525060                     /lib/x86_64-linux-gnu/libpthread-2.24.so
          7f9349124000-7f9349323000 ---p 00018000 08:01 525060                     /lib/x86_64-linux-gnu/libpthread-2.24.so
          7f9349323000-7f9349324000 r--p 00017000 08:01 525060                     /lib/x86_64-linux-gnu/libpthread-2.24.so
          7f9349324000-7f9349325000 rw-p 00018000 08:01 525060                     /lib/x86_64-linux-gnu/libpthread-2.24.so
          7f9349325000-7f9349329000 rw-p 00000000 00:00 0
          7f9349329000-7f9349338000 r-xp 00000000 08:01 925303                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjli.so
          7f9349338000-7f9349538000 ---p 0000f000 08:01 925303                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjli.so
          7f9349538000-7f9349539000 r--p 0000f000 08:01 925303                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjli.so
          7f9349539000-7f934953a000 rw-p 00010000 08:01 925303                     /usr/lib/jvm/adoptopenjdk-14-hotspot-amd64/lib/libjli.so
          7f934953a000-7f9349553000 r-xp 00000000 08:01 537723                     /lib/x86_64-linux-gnu/libz.so.1.2.8
          7f9349553000-7f9349752000 ---p 00019000 08:01 537723                     /lib/x86_64-linux-gnu/libz.so.1.2.8
          7f9349752000-7f9349753000 r--p 00018000 08:01 537723                     /lib/x86_64-linux-gnu/libz.so.1.2.8
          7f9349753000-7f9349754000 rw-p 00019000 08:01 537723                     /lib/x86_64-linux-gnu/libz.so.1.2.8
          7f9349754000-7f9349777000 r-xp 00000000 08:01 525041                     /lib/x86_64-linux-gnu/ld-2.24.so
          7f93497dc000-7f9349855000 rw-p 00000000 00:00 0
          7f9349855000-7f934985a000 rw-p 00000000 00:00 0
          7f934985a000-7f9349861000 ---p 00000000 00:00 0
          7f9349861000-7f9349869000 rw-s 00000000 08:01 1313699                    /tmp/hsperfdata_root/10007
          7f9349869000-7f934986d000 ---p 00000000 00:00 0
          7f934986d000-7f934996c000 rw-p 00000000 00:00 0
          7f9349971000-7f9349972000 ---p 00000000 00:00 0
          7f9349972000-7f9349973000 r--p 00000000 00:00 0
          7f9349973000-7f9349974000 ---p 00000000 00:00 0
          7f9349974000-7f9349977000 rw-p 00000000 00:00 0
          7f9349977000-7f9349978000 r--p 00023000 08:01 525041                     /lib/x86_64-linux-gnu/ld-2.24.so
          7f9349978000-7f9349979000 rw-p 00024000 08:01 525041                     /lib/x86_64-linux-gnu/ld-2.24.so
          7f9349979000-7f934997a000 rw-p 00000000 00:00 0
          7fff9f358000-7fff9f379000 rw-p 00000000 00:00 0                          [stack]
          7fff9f3ba000-7fff9f3bc000 r--p 00000000 00:00 0                          [vvar]
          7fff9f3bc000-7fff9f3be000 r-xp 00000000 00:00 0                          [vdso]
          ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
          VM Arguments:
          jvm_args: -Xms15g -Xmx15g --add-modules=java.activation,java.xml.bind -Dlog4j.configurationFile=file:/opt/mango/classes/log4j2.xml -Dma.home=/opt/mango
          java_command: com.serotonin.m2m2.Main
          java_class_path (initial): /opt/mango/overrides/classes:/opt/mango/classes:/opt/mango/overrides/properties:/opt/mango/overrides/lib/*:/opt/mango/lib/commons-io-2.6.jar:/opt/mango/lib/spring-security-config-5.1.5.RELEASE.jar:/opt/mango/lib/h2-1.4.199.jar:/opt/mango/lib/jetty-io-9.4.23.v20191118.jar:/opt/mango/lib/commons-math3-3.6.1.jar:/opt/mango/lib/taglibs-standard-impl-1.2.5.jar:/opt/mango/lib/taglibs-standard-spec-1.2.5.jar:/opt/mango/lib/jetty-plus-9.4.23.v20191118.jar:/opt/mango/lib/jetty-http-9.4.23.v20191118.jar:/opt/mango/lib/mysql-connector-java-5.1.46.jar:/opt/mango/lib/reflections-0.9.10.jar:/opt/mango/lib/jdom-1.1.3.jar:/opt/mango/lib/jetty-alpn-openjdk8-client-9.4.23.v20191118.jar:/opt/mango/lib/hibernate-core-3.3.0.GA.jar:/opt/mango/lib/jscience-4.3.1.jar:/opt/mango/lib/spring-tx-5.1.7.RELEASE.jar:/opt/mango/lib/jetty-schemas-3.1.2.jar:/opt/mango/lib/checker-compat-qual-2.0.0.jar:/opt/mango/lib/ognl-2.6.11.jar:/opt/mango/lib/spring-jcl-5.1.7.RELEASE.jar:/opt/mango/lib/commons-fileupload-1.3.3.jar:/opt/mango/lib/jackson-core-2.9.10.jar:/opt/mango/lib/commons-collections4-4.2.jar:/opt/mango/lib/bcpg-jdk15on-1.62.jar:/opt/mango/lib/spring-websocket-5.1.7.RELEASE.jar:/opt/mango/lib/springfox-core-2.9.2.jar:/opt/mango/lib/istack-commons-tools-3.0.8.jar:/opt/mango/lib/httpclient-cache-4.5.5.jar:/opt/mango/lib/disruptor-3.3.11.jar:/opt/mango/lib/ant-launcher-1.10.5.jar:/opt/mango/lib/byte-buddy-1.8.12.jar:/opt/mango/lib/spring-webmvc-5.1.7.RELEASE.jar:/opt/mango/lib/ant-1.10.5.jar:/opt/mango/lib/jetty-util-9.4.23.v20191118.jar:/opt/mango/lib/commons-collections-3.2.2.jar:/opt/mango/lib/apache-jsp-8.5.40.jar:/opt/mango/lib/ma-priv-3.7.7.jar:/opt/mango/lib/websocket-api-9.4.23.v20191118.jar:/opt/mango/lib/commons-digester-1.6.jar:/opt/mango/lib/javax.mail-1.6.2.jar:/opt/mango/lib/http2-common-9.4.23.v20191118.jar:/opt/mango/lib/swagger-annotations-1.5.20.jar:/opt/mango/lib/log-1.0.jar:/opt/mango/lib/springfox-spi-2.9.2.jar:/opt/mango/lib/commons-beanutils-1.
          Launcher Type: SUN_STANDARD
          [Global flags]
               intx CICompilerCount                          = 3                                         {product} {ergonomic}
               uint ConcGCThreads                            = 2                                         {product} {ergonomic}
               uint G1ConcRefinementThreads                  = 6                                         {product} {ergonomic}
             size_t G1HeapRegionSize                         = 4194304                                   {product} {ergonomic}
              uintx GCDrainStackTargetSize                   = 64                                        {product} {ergonomic}
             size_t InitialHeapSize                          = 16106127360                               {product} {command line}
             size_t MarkStackSize                            = 4194304                                   {product} {ergonomic}
             size_t MaxHeapSize                              = 16106127360                               {product} {command line}
             size_t MinHeapDeltaBytes                        = 4194304                                   {product} {ergonomic}
             size_t MinHeapSize                              = 16106127360                               {product} {command line}
              uintx NonNMethodCodeHeapSize                   = 5832780                                {pd product} {ergonomic}
              uintx NonProfiledCodeHeapSize                  = 122912730                              {pd product} {ergonomic}
              uintx ProfiledCodeHeapSize                     = 122912730                              {pd product} {ergonomic}
              uintx ReservedCodeCacheSize                    = 251658240                              {pd product} {ergonomic}
               bool SegmentedCodeCache                       = true                                      {product} {ergonomic}
             size_t SoftMaxHeapSize                          = 16106127360                            {manageable} {ergonomic}
               bool UseCompressedClassPointers               = true                                 {lp64_product} {ergonomic}
               bool UseCompressedOops                        = true                                 {lp64_product} {ergonomic}
               bool UseG1GC                                  = true                                      {product} {ergonomic}
          Logging:
          Log output configuration:
           #0: stdout all=warning uptime,level,tags
           #1: stderr all=off uptime,level,tags
          Environment Variables:
          JAVA_HOME=/usr/lib/jvm/adoptopenjdk-14-hotspot-amd64
          CLASSPATH=/opt/mango/overrides/classes:/opt/mango/classes:/opt/mango/overrides/properties:/opt/mango/overrides/lib/*:/opt/mango/lib/*
          PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
          SHELL=/bin/sh
          Signal Handlers:
          SIGSEGV: [libjvm.so+0xf1e710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGBUS: [libjvm.so+0xf1e710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGFPE: [libjvm.so+0xf1e710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGPIPE: [libjvm.so+0xbc1060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGXFSZ: [libjvm.so+0xbc1060], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGILL: [libjvm.so+0xf1e710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
          SIGUSR2: [libjvm.so+0xbc0f00], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
          SIGHUP: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
          SIGINT: SIG_IGN, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
          SIGTERM: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
          SIGQUIT: SIG_IGN, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
          ---------------  S Y S T E M  ---------------
          OS:PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
          NAME="Debian GNU/Linux"
          VERSION_ID="9"
          VERSION="9 (stretch)"
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          uname:Linux 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64
          OS uptime: 28 days 2:58 hours
          libc:glibc 2.24 NPTL 2.24
          rlimit: STACK 8192k, CORE 0k, NPROC 88310, NOFILE 4096, AS infinity, DATA infinity, FSIZE infinity
          load average:0.04 0.13 0.11
          /proc/meminfo:
          MemTotal:       22629760 kB
          MemFree:          231144 kB
          MemAvailable:   12010268 kB
          Buffers:          812964 kB
          Cached:         11120512 kB
          SwapCached:            0 kB
          Active:         11288212 kB
          Inactive:       10413648 kB
          Active(anon):    9877684 kB
          Inactive(anon):   172604 kB
          Active(file):    1410528 kB
          Inactive(file): 10241044 kB
          Unevictable:           0 kB
          Mlocked:               0 kB
          SwapTotal:             0 kB
          SwapFree:              0 kB
          Dirty:              1292 kB
          Writeback:             0 kB
          AnonPages:       9768228 kB
          Mapped:           252704 kB
          Shmem:            281904 kB
          Slab:             550524 kB
          SReclaimable:     512928 kB
          SUnreclaim:        37596 kB
          KernelStack:        7712 kB
          PageTables:        34052 kB
          NFS_Unstable:          0 kB
          Bounce:                0 kB
          WritebackTmp:          0 kB
          CommitLimit:    11314880 kB
          Committed_AS:   18736284 kB
          VmallocTotal:   34359738367 kB
          VmallocUsed:           0 kB
          VmallocChunk:          0 kB
          HardwareCorrupted:     0 kB
          AnonHugePages:     32768 kB
          ShmemHugePages:        0 kB
          ShmemPmdMapped:        0 kB
          HugePages_Total:       0
          HugePages_Free:        0
          HugePages_Rsvd:        0
          HugePages_Surp:        0
          Hugepagesize:       2048 kB
          DirectMap4k:      155636 kB
          DirectMap2M:    16621568 kB
          DirectMap1G:     8388608 kB
          /proc/sys/kernel/threads-max (system-wide limit on the number of threads):
          176620
          /proc/sys/vm/max_map_count (maximum number of memory map areas a process may have):
          65530
          /proc/sys/kernel/pid_max (system-wide limit on number of process identifiers):
          32768
          container (cgroup) information:
          container_type: cgroupv1
          cpu_cpuset_cpus: 0-5
          cpu_memory_nodes: 0
          active_processor_count: 6
          cpu_quota: no quota
          cpu_period: 100000
          cpu_shares: no shares
          memory_limit_in_bytes: unlimited
          memory_and_swap_limit_in_bytes: not supported
          memory_soft_limit_in_bytes: unlimited
          memory_usage_in_bytes: 22222962688
          memory_max_usage_in_bytes: 1162121216
          KVM virtualization detected
          Steal ticks since vm start: 0
          Steal ticks percentage since vm start:  0.000
          CPU:total 6 (initial active 6) (3 cores per cpu, 2 threads per core) family 6 model 85 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, rtm, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx, evex, fma
          CPU Model and flags from /proc/cpuinfo:
          model name	: Intel(R) Xeon(R) CPU
          flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology nonstop_tsc pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single ssbd ibrs ibpb stibp kaiser fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx avx512f avx512dq rdseed adx smap clflushopt clwb avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves arat arch_capabilities
          Memory: 4k page, physical 22629760k(231144k free), swap 0k(0k free)
          vm_info: OpenJDK 64-Bit Server VM (14.0.1+7) for linux-amd64 JRE (14.0.1+7), built on Apr 15 2020 15:16:40 by "jenkins" with gcc 7.5.0
          END.
          Thanks Fox
          EDIT: Think I found mango trying to create a second instance of itself which is what is causing this error. However, I still have the issue of a java.xml.bind module not found. I see it's been removed from Ver.11 onwards so is it really needed or can I boot mango without it?
          • S Offline
            sky_watcher @CraigWeb
            @craigweb I am running v3.5.4. Here is one of the log files:
            # Native memory allocation (mmap) failed to map 419430400 bytes for committing reserved memory.
            # Possible reasons:
            #   In 32 bit mode, the process size limit was hit
            #   Use 64 bit Java on a 64 bit OS
            #  Out of Memory Error (os_linux.cpp:2640), pid=303, tid=0xb6185460
            # JRE version:  (8.0_181-b13) (build )
            # Java VM: Java HotSpot(TM) Server VM (25.181-b13 mixed mode linux-arm )
            # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
            Current thread (0xb600b400):  JavaThread "Unknown thread" [_thread_in_vm, id=305, stack(0xb6136000,0xb6186000)]
            Stack: [0xb6136000,0xb6186000]
            Other Threads:
            =>0xb600b400 (exited) JavaThread "Unknown thread" [_thread_in_vm, id=305, stack(0xb6136000,0xb6186000)]
            VM Mutex/Monitor currently owned by a thread: None
            No events
            No events
            No events
            No events
            Events (0 events):
            No events
            Dynamic libraries:
            00008000-00009000 r-xp 00000000 b3:02 29543      /usr/lib/jvm/java-8-oracle/jre/bin/java
            00010000-00011000 rw-p 00000000 b3:02 29543      /usr/lib/jvm/java-8-oracle/jre/bin/java
            00011000-00032000 rw-p 00000000 00:00 0          [heap]
            68ba7000-68dff000 ---p 00000000 00:00 0
            68dff000-68e00000 rw-p 00000000 00:00 0
            68e00000-9ae00000 ---p 00000000 00:00 0
            b3ecd000-b3ed3000 rw-p 00000000 00:00 0
            b3ed3000-b3f4d000 ---p 00000000 00:00 0
            b3f4d000-b40cd000 rwxp 00000000 00:00 0
            b40cd000-b5f4d000 ---p 00000000 00:00 0
            b5f4d000-b5f65000 r-xp 00000000 b3:02 31484      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libzip.so
            b5f65000-b5f6c000 ---p 00018000 b3:02 31484      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libzip.so
            b5f6c000-b5f6d000 rw-p 00017000 b3:02 31484      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libzip.so
            b5f6d000-b5f75000 r-xp 00000000 b3:02 33791      /lib/arm-linux-gnueabihf/libnss_files-2.19.so
            b5f75000-b5f84000 ---p 00008000 b3:02 33791      /lib/arm-linux-gnueabihf/libnss_files-2.19.so
            b5f84000-b5f85000 r--p 00007000 b3:02 33791      /lib/arm-linux-gnueabihf/libnss_files-2.19.so
            b5f85000-b5f86000 rw-p 00008000 b3:02 33791      /lib/arm-linux-gnueabihf/libnss_files-2.19.so
            b5f86000-b5f8d000 r-xp 00000000 b3:02 33793      /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
            b5f8d000-b5f9c000 ---p 00007000 b3:02 33793      /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
            b5f9c000-b5f9d000 r--p 00006000 b3:02 33793      /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
            b5f9d000-b5f9e000 rw-p 00007000 b3:02 33793      /lib/arm-linux-gnueabihf/libnss_nis-2.19.so
            b5f9e000-b5fab000 r-xp 00000000 b3:02 33788      /lib/arm-linux-gnueabihf/libnsl-2.19.so
            b5fab000-b5fba000 ---p 0000d000 b3:02 33788      /lib/arm-linux-gnueabihf/libnsl-2.19.so
            b5fba000-b5fbb000 r--p 0000c000 b3:02 33788      /lib/arm-linux-gnueabihf/libnsl-2.19.so
            b5fbb000-b5fbc000 rw-p 0000d000 b3:02 33788      /lib/arm-linux-gnueabihf/libnsl-2.19.so
            b5fbc000-b5fbe000 rw-p 00000000 00:00 0
            b5fbe000-b5fc3000 r-xp 00000000 b3:02 33789      /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
            b5fc3000-b5fd2000 ---p 00005000 b3:02 33789      /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
            b5fd2000-b5fd3000 r--p 00004000 b3:02 33789      /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
            b5fd3000-b5fd4000 rw-p 00005000 b3:02 33789      /lib/arm-linux-gnueabihf/libnss_compat-2.19.so
            b5fd4000-b5ff7000 r-xp 00000000 b3:02 31468      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libjava.so
            b5ff7000-b5fff000 ---p 00023000 b3:02 31468      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libjava.so
            b5fff000-b6000000 rw-p 00023000 b3:02 31468      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libjava.so
            b6000000-b6021000 rw-p 00000000 00:00 0
            b6021000-b6100000 ---p 00000000 00:00 0
            b6106000-b610e000 rw-s 00000000 00:1c 49710282   /tmp/hsperfdata_mango/303
            b610e000-b6117000 r-xp 00000000 b3:02 31489      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libverify.so
            b6117000-b611f000 ---p 00009000 b3:02 31489      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libverify.so
            b611f000-b6120000 rw-p 00009000 b3:02 31489      /usr/lib/jvm/java-8-oracle/jre/lib/arm/libverify.so
            b6120000-b6125000 r-xp 00000000 b3:02 33797      /lib/arm-linux-gnueabihf/librt-2.19.so
            b6125000-b6134000 ---p 00005000 b3:02 33797      /lib/arm-linux-gnueabihf/librt-2.19.so
            b6134000-b6135000 r--p 00004000 b3:02 33797      /lib/arm-linux-gnueabihf/librt-2.19.so
            b6135000-b6136000 rw-p 00005000 b3:02 33797      /lib/arm-linux-gnueabihf/librt-2.19.so
            b6136000-b6139000 ---p 00000000 00:00 0
            b6139000-b6186000 rw-p 00000000 00:00 0          [stack:305]
            b6186000-b61e9000 r-xp 00000000 b3:02 33786      /lib/arm-linux-gnueabihf/libm-2.19.so
            b61e9000-b61f8000 ---p 00063000 b3:02 33786      /lib/arm-linux-gnueabihf/libm-2.19.so
            b61f8000-b61f9000 r--p 00062000 b3:02 33786      /lib/arm-linux-gnueabihf/libm-2.19.so
            b61f9000-b61fa000 rw-p 00063000 b3:02 33786      /lib/arm-linux-gnueabihf/libm-2.19.so
            b61fa000-b69a4000 r-xp 00000000 b3:02 31497      /usr/lib/jvm/java-8-oracle/jre/lib/arm/server/libjvm.so
            b69a4000-b69ab000 ---p 007aa000 b3:02 31497      /usr/lib/jvm/java-8-oracle/jre/lib/arm/server/libjvm.so
            b69ab000-b6a01000 rw-p 007a9000 b3:02 31497      /usr/lib/jvm/java-8-oracle/jre/lib/arm/server/libjvm.so
            b6a01000-b6e2a000 rw-p 00000000 00:00 0
            b6e2a000-b6e43000 r-xp 00000000 b3:02 1151       /lib/arm-linux-gnueabihf/libgcc_s.so.1
            b6e43000-b6e52000 ---p 00019000 b3:02 1151       /lib/arm-linux-gnueabihf/libgcc_s.so.1
            b6e52000-b6e53000 rw-p 00018000 b3:02 1151       /lib/arm-linux-gnueabihf/libgcc_s.so.1
            b6e53000-b6f2e000 r-xp 00000000 b3:02 33782      /lib/arm-linux-gnueabihf/libc-2.19.so
            b6f2e000-b6f3d000 ---p 000db000 b3:02 33782      /lib/arm-linux-gnueabihf/libc-2.19.so
            b6f3d000-b6f3f000 r--p 000da000 b3:02 33782      /lib/arm-linux-gnueabihf/libc-2.19.so
            b6f3f000-b6f40000 rw-p 000dc000 b3:02 33782      /lib/arm-linux-gnueabihf/libc-2.19.so
            b6f40000-b6f43000 rw-p 00000000 00:00 0
            b6f43000-b6f45000 r-xp 00000000 b3:02 33785      /lib/arm-linux-gnueabihf/libdl-2.19.so
            b6f45000-b6f54000 ---p 00002000 b3:02 33785      /lib/arm-linux-gnueabihf/libdl-2.19.so
            b6f54000-b6f55000 r--p 00001000 b3:02 33785      /lib/arm-linux-gnueabihf/libdl-2.19.so
            b6f55000-b6f56000 rw-p 00002000 b3:02 33785      /lib/arm-linux-gnueabihf/libdl-2.19.so
            b6f56000-b6f6b000 r-xp 00000000 b3:02 31492      /usr/lib/jvm/java-8-oracle/jre/lib/arm/jli/libjli.so
            b6f6b000-b6f72000 ---p 00015000 b3:02 31492      /usr/lib/jvm/java-8-oracle/jre/lib/arm/jli/libjli.so
            b6f72000-b6f73000 rw-p 00014000 b3:02 31492      /usr/lib/jvm/java-8-oracle/jre/lib/arm/jli/libjli.so
            b6f73000-b6f83000 r-xp 00000000 b3:02 33778      /lib/arm-linux-gnueabihf/libpthread-2.19.so
            b6f83000-b6f92000 ---p 00010000 b3:02 33778      /lib/arm-linux-gnueabihf/libpthread-2.19.so
            b6f92000-b6f93000 r--p 0000f000 b3:02 33778      /lib/arm-linux-gnueabihf/libpthread-2.19.so
            b6f93000-b6f94000 rw-p 00010000 b3:02 33778      /lib/arm-linux-gnueabihf/libpthread-2.19.so
            b6f94000-b6f96000 rw-p 00000000 00:00 0
            b6f96000-b6fad000 r-xp 00000000 b3:02 33779      /lib/arm-linux-gnueabihf/ld-2.19.so
            b6fb2000-b6fb5000 rw-p 00000000 00:00 0
            b6fb9000-b6fba000 r--p 00000000 00:00 0
            b6fba000-b6fbc000 rw-p 00000000 00:00 0
            b6fbc000-b6fbd000 r-xp 00000000 00:00 0          [sigpage]
            b6fbd000-b6fbe000 r--p 00017000 b3:02 33779      /lib/arm-linux-gnueabihf/ld-2.19.so
            b6fbe000-b6fbf000 rw-p 00018000 b3:02 33779      /lib/arm-linux-gnueabihf/ld-2.19.so
            bed24000-bed45000 rw-p 00000000 00:00 0          [stack]
            ffff0000-ffff1000 r-xp 00000000 00:00 0          [vectors]
            VM Arguments:
            jvm_args: -Xms1200m -Xmx1200m -Dma.home=/opt/mango -Djava.library.path=/opt/mango/overrides/lib:/opt/mango/lib:/usr/lib/jni/:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
            java_class_path (initial): /opt/mango/overrides/classes:/opt/mango/classes:/opt/mango/overrides/properties:/opt/mango/overrides/lib/*:/opt/mango/lib/ma-priv-3.5.4.jar:/opt/mango/lib/guava-24.1.1-jre.jar:/opt/mango/lib/rql-parser-0.3.2.jar:/opt/mango/lib/mail-1.5.0-b01.jar:/opt/mango/lib/websocket-common-9.4.12.v20180830.jar:/opt/mango/lib/swagger-models-1.5.20.jar:/opt/mango/lib/annotations-2.0.1.jar:/opt/mango/lib/javolution-5.2.3.jar:/opt/mango/lib/spring-tx-5.0.10.RELEASE.jar:/opt/mango/lib/spring-websocket-5.0.10.RELEASE.jar:/opt/mango/lib/asm-6.2.jar:/opt/mango/lib/websocket-client-9.4.12.v20180830.jar:/opt/mango/lib/spring-expression-5.0.10.RELEASE.jar:/opt/mango/lib/jetty-util-ajax-9.4.12.v20180830.jar:/opt/mango/lib/jackson-databind-2.9.5.jar:/opt/mango/lib/jackson-datatype-jsr310-2.9.5.jar:/opt/mango/lib/springfox-spi-2.9.2.jar:/opt/mango/lib/commons-beanutils-1.8.3.jar:/opt/mango/lib/poi-3.17.jar:/opt/mango/lib/spring-web-5.0.10.RELEASE.jar:/opt/mango/lib/commons-codec-1.6.jar:/opt/mango/lib/passay-1.3.1.jar:/opt/mango/lib/jetty-plus-9.4.12.v20180830.jar:/opt/mango/lib/xmlbeans-2.6.0.jar:/opt/mango/lib/mapstruct-1.2.0.Final.jar:/opt/mango/lib/jetty-schemas-3.1.jar:/opt/mango/lib/caffeine-2.6.2.jar:/opt/mango/lib/log4j-core-2.10.0.jar:/opt/mango/lib/spring-security-config-5.0.9.RELEASE.jar:/opt/mango/lib/joda-time-2.9.9.jar:/opt/mango/lib/jjwt-0.9.0.jar:/opt/mango/lib/JLargeArrays-1.5.jar:/opt/mango/lib/springfox-swagger-ui-2.9.2.jar:/opt/mango/lib/log-1.0.jar:/opt/mango/lib/jackson-dataformat-csv-2.9.5.jar:/opt/mango/lib/commons-digester-1.6.jar:/opt/mango/lib/poi-ooxml-schemas-3.17.jar:/opt/mango/lib/apache-jsp-8.5.24.2.jar:/opt/mango/lib/jetty-io-9.4.12.v20180830.jar:/opt/mango/lib/stax-api-1.0.1.jar:/opt/mango/lib/jetty-webapp-9.4.12.v20180830.jar:/opt/mango/lib/junit-3.8.1.jar:/opt/mango/lib/jetty-xml-9.4.12.v20180830.jar:/opt/mango/lib/animal-sniffer-annotations-1.14.jar:/opt/mango/lib/postgresql-9.2-1002-jdbc4.jar:/opt/mango/lib/http2-common-9.4.12
            PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
            SHELL=/bin/bash
            Signal Handlers:
            SIGSEGV: [libjvm.so+0x71c154], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGBUS: [libjvm.so+0x71c154], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGFPE: [libjvm.so+0x5abb24], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGPIPE: [libjvm.so+0x5abb24], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGXFSZ: [libjvm.so+0x5abb24], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGILL: [libjvm.so+0x5abb24], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
            SIGUSR1: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
            SIGUSR2: [libjvm.so+0x5abc88], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
            OS:PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
            VERSION_ID="8"
            VERSION="8 (jessie)"
            ID=debian
            HOME_URL="http://www.debian.org/"
            SUPPORT_URL="http://www.debian.org/support"
            uname:Linux 3.10.82+ #1 SMP PREEMPT Mon Sep 7 16:31:39 MDT 2015 armv7l
            libc:glibc 2.19 NPTL 2.19
            rlimit: STACK 8192k, CORE 0k, NPROC 11925, NOFILE 65536, AS infinity
            load average:3.59 3.70 6.75
            /proc/meminfo:
            MemTotal:        2038840 kB
            MemFree:          173480 kB
            Buffers:            1292 kB
            Cached:           140968 kB
            SwapCached:            0 kB
            Active:          1523832 kB
            Inactive:         128008 kB
            Active(anon):    1515268 kB
            Inactive(anon):   119368 kB
            Active(file):       8564 kB
            Inactive(file):     8640 kB
            Unevictable:           0 kB
            Mlocked:               0 kB
            HighTotal:       1296384 kB
            HighFree:           5084 kB
            LowTotal:         742456 kB
            LowFree:          168396 kB
            SwapTotal:             0 kB
            SwapFree:              0 kB
            Dirty:              4756 kB
            Writeback:             0 kB
            AnonPages:       1509680 kB
            Mapped:            12268 kB
            Shmem:            125052 kB
            Slab:              45344 kB
            SReclaimable:      23404 kB
            SUnreclaim:        21940 kB
            KernelStack:        1672 kB
            PageTables:         3632 kB
            NFS_Unstable:          0 kB
            Bounce:                0 kB
            WritebackTmp:          0 kB
            CommitLimit:     1019420 kB
            Committed_AS:    1600740 kB
            VmallocTotal:     245760 kB
            VmallocUsed:       18812 kB
            VmallocChunk:     103580 kB
            CPU:total 8 (initial active 8) (ARMv7), vfp, vfp3-32, simd
            /proc/cpuinfo:
            processor	: 0
            model name	: ARMv7 Processor rev 3 (v7l)
            BogoMIPS	: 84.00
            Features	: swp half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt
            CPU implementer	: 0x41
            CPU architecture: 7
            CPU variant	: 0x0
            CPU part	: 0xc07
            CPU revision	: 3
            processor	: 1
            BogoMIPS	: 84.00
            CPU architecture: 7
            CPU variant	: 0x0
            CPU part	: 0xc07
            CPU revision	: 3
            processor	: 2
            BogoMIPS	: 84.00
            CPU architecture: 7
            CPU variant	: 0x0
            CPU part	: 0xc07
            CPU revision	: 3
            processor	: 3
            BogoMIPS	: 84.00
            CPU architecture: 7
            CPU variant	: 0x0
            CPU part	: 0xc07
            CPU revision	: 3
            processor	: 4
            BogoMIPS	: 54.00
            CPU architecture: 7
            CPU variant	: 0x2
            CPU part	: 0xc0f
            CPU revision	: 3
            processor	: 5
            BogoMIPS	: 54.00
            CPU architecture: 7
            CPU variant	: 0x2
            CPU part	: 0xc0f
            CPU revision	: 3
            processor	: 6
            BogoMIPS	: 54.00
            CPU architecture: 7
            CPU variant	: 0x2
            CPU part	: 0xc0f
            CPU revision	: 3
            processor	: 7
            BogoMIPS	: 54.00
            CPU architecture: 7
            CPU variant	: 0x2
            CPU part	: 0xc0f
            CPU revision	: 3
            Hardware	: ODROID-XU3
            Revision	: 0100
            Serial		: 0000000000000000
            Memory: 4k page, physical 2038840k(173480k free), swap 0k(0k free)
            vm_info: Java HotSpot(TM) Server VM (25.181-b13) for linux-arm-vfp-hflt JRE (1.8.0_181-b13), built on Jul  7 2018 01:31:41 by "java_re" with gcc 4.7.2 20120910 (prerelease)
            time: Wed Aug 19 13:36:29 2020
            Any idea why is java crashing?
            Thanks.
