    Overriding Module's i18n Files
    6 Posts 3 Posters 1.7k Views 3 Watching
    • W Offline
      wfoster-syscor
      I'm using Mango 3.7.7 and I'm wondering if there is a way to override a module's i18n.properties files? For example the file:
      {MANGO}/web/modules/mangoUI/classes/i18n.properties
      I've tried placing the modified file in several different locations within the overrides folder, and also just concatenating it to my existing core i18n.properties override file.
      So far the only way I've gotten it to work is by replacing the actual file within the module, which will be overwritten during any updates.
      These are the paths I have tried:
      {MANGO}/overrides/web/modules/mangoUI/classes/
      {MANGO}/overrides/web/modules/mangoUI/properties/
      {MANGO}/overrides/properties/
      • CraigWebC Offline
        CraigWeb
        HI @wfoster-syscor
        {MANGO}/overrides/web/modules/mangoUI/classes/i18n.properties should work, can you confirm that you are restarting mango for it to take affect?
        • W Offline
          wfoster-syscor
          I can confirm that I am restarting Mango after copying the file. I tried using the {MANGO}/overrides/web/modules/mangoUI/classes/i18n.properties again to check and still no luck. I copied the original back to the main location and the modified file to that path and after restarting all of the default strings are back.
          I have several files within the {MANGO}/overrides/web/modules/mangoUI/web directory which are loaded and working fine, but it seems that the module's classes directory isn't using the overrides.
          • CraigWebC Offline
            CraigWeb
            ok thanks for confirming that, seems like there is something I'm not aware of. Hopefully, @Jared-Wiltshire can advise.
              @wfoster-syscor Just put your custom translations in overrides/classes/i18n_en.properties (for English). This way you can just put in the strings you want to override.
              • W Offline
                wfoster-syscor
                Great, thank you. Changing the name to include the _en and putting it into the overrides/classes directory worked perfectly.
