    Date/Time format
    7 Posts 3 Posters 2.1k Views 3 Watching
    • R Offline
      Robmalone
      Hi all,
      I am having some trouble parsing a date/time stamp from a http retriever data source. The regex appears to be working as it is getting the correct raw data but no mater what i put into the Time Format field I either get an error " 'Portlaoise Weather': Failed to parse time "2020-04-27T11:55:06" for Portlaoise Weather - Temperature" or if I only put yyyyMMdd in to the Time format field i get the wrong date of "2019-12-04" returned.
      What should I enter in the Time Format field to get 2020-04-27 11:55:06 for the data/timestamp above?
      Thanks.
      • CraigWebC Offline
        CraigWeb
        Hi Rob
        Did you try changing the time capture group to 1?
        • R Offline
          Robmalone
          Hi @CraigWeb. Yes I tried both 0 and 1 for the capture group.
          • CraigWebC Offline
            CraigWeb
            This should do the trick if your time regex is working.
            yyyy-MM-dd'T'hh:mm:ss
            • R Offline
              Robmalone
              Thanks @CraigWeb. Well don't i feel like an idiot! Not sure where I was going wrong, I thought that's how I had it but when I copied your format in and it worked first time. Thanks again.
              Edit: Just as a matter of interest - If it was unix time what would the format be?
                MattFox @Robmalone
                @robmalone (\d+) => digit plus all the following characters straight after that are the same assuming this is regex and not a timestamp format
                Just realised this is using the SimpleDateFormat Library. According to docs you can use epoch
                https://help.sumologic.com/03Send-Data/Sources/04Reference-Information-for-Sources/Timestamps%2C-Time-Zones%2C-Time-Ranges%2C-and-Date-Formats#Timestamp_conventions
                • R Offline
                  Robmalone
                  Thanks @MattFox
