    How to Limit Data Sources options
    Scheduled Pinned Locked Moved Unsolved How-To
    11 Posts 5 Posters 4.4k Views 5 Watching
    • D Offline
      DineshTech
      How can we reduce the datasource types.
      We are referring this url:- http://172.30.66.119:8080/ui/administration/data-sources/
        Remove modules and restart mango. Just take caution as to which modules it is you want to remove.
        • S Offline
          shubham
          Thanks for the reply,
          Can you guide us how to remove the modules.
          • R Offline
            Ralf
            Select menu Administration/Modules
            Mark the module for deletion and restart Mango.
            As MattFox said: "Just take caution as to which modules it is you want to remove."
              Thanks Ralf!
              • S Offline
                shubham
                Hi Ralf and Matt,
                From modules option i marked my Log4j Data source to delete and clicked on restart mango button.
                After that i am not able to access mango UI it seems like application stopped and not started.
                Shubham Rajvanshi
                  Log4j is the logging system used by Datasources, it's not a datasource itself.
                  Usually the modules show their dependencies. If not, go to store.infiniteautomation.com and look at download modules. They tell you what they need to work.
                  Edit: Sorry I misread the note. Looks like something has not agreed. Check inside /opt/mango/logs/ma.log and see what the error is that's causing your mango instance not to load.
                  • S Offline
                    shubham
                    Hi Mat,
                    Below are the exception is coming in log file
                     namespace 'restV2DispatcherServlet-servlet'
                    WARN  2020-03-03T07:36:29,074 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                    java.nio.channels.ClosedChannelException: null
                    	at org.eclipse.jetty.websocket.common.io.FrameFlusher.enqueue(FrameFlusher.java:109) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:582) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.AbstractExtension.nextOutgoingFrame(AbstractExtension.java:155) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.PerMessageDeflateExtension.nextOutgoingFrame(PerMessageDeflateExtension.java:123) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension.access$1100(CompressExtension.java:44) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.compress(CompressExtension.java:591) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.deflate(CompressExtension.java:488) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.process(CompressExtension.java:468) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension.outgoingFrame(CompressExtension.java:244) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.ExtensionStack$Flusher.process(ExtensionStack.java:400) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.outgoingFrame(ExtensionStack.java:277) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.WebSocketSession.outgoingFrame(WebSocketSession.java:355) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.uncheckedSendFrame(WebSocketRemoteEndpoint.java:306) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.sendAsyncFrame(WebSocketRemoteEndpoint.java:240) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.sendStringByFuture(WebSocketRemoteEndpoint.java:403) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                    	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.MangoWebSocketHandler.sendStringMessageAsync(MangoWebSocketHandler.java:138) ~[?:?]
                    	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.MangoWebSocketHandler.sendMessage(MangoWebSocketHandler.java:99) ~[?:?]
                    	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.events.EventsWebSocketHandler.sendMessage(EventsWebSocketHandler.java:123) ~[?:?]
                    	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.events.EventsWebSocketHandler$EventsWebSocketListener.returnToNormal(EventsWebSocketHandler.java:209) ~[?:?]
                    	at com.serotonin.m2m2.rt.event.UserEventMulticaster.returnToNormal(UserEventMulticaster.java:162) ~[mango-3.7.4.jar:?]
                    	at com.serotonin.m2m2.rt.EventManagerImpl$EventNotifyWorkItem.execute(EventManagerImpl.java:1121) ~[mango-3.7.4.jar:?]
                    	at com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl$WorkItemRunnable.run(BackgroundProcessingImpl.java:671) ~[mango-3.7.4.jar:?]
                    	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
                    	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
                    	at java.lang.Thread.run(Thread.java:830) [?:?]
                    WARN  2020-03-03T07:36:34,138 (com.infiniteautomation.mango.rest.v2.ServerRestV2Controller.postClientError:428) - Client error
                    [user=shubham, cause=Possibly unhandled rejection: {"code":"E_MISSING_MESSAGE","path":"dsEdit.egaugePoint"}, location=http://172.30.66.119:8080/ui/data-point-details/, userAgent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36, language=en-US, date=2020-03-03T13:07:25.701+05:30, timezone=Asia/Calcutta]
                    Error: E_MISSING_MESSAGE: Missing required message content `dsEdit.egaugePoint`.
                    	at r (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:61:427)
                    	at a (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:61:583)
                    	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:117:14615)
                    	at Function.t.messageFormatter.t.messageFormatter (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:117:14703)
                    	at Function.trSync (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:72:109051)
                    	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:72:108351)
                    	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:94777)
                    	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:94915)
                    	at c.$digest (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:100341)
                    	at c.$apply (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:102518)
                    WARN  2020-03-03T07:37:49,795 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                    WARN  2020-03-03T08:52:21,510 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                    	at com.serotonin.m2m2.rt.EventManagerImpl$EventNotifyWorkItem.execute(EventManagerImpl.java:1132) ~[mango-3.7.4.jar:?]
                    Shubham
                    • CraigWebC Offline
                      CraigWeb
                      Hi shubhamthe log4J data source is not required to run mango. Those warnings are just websockets that have closed. This should not prevent you from logging in. What happens when you go to url: http://172.30.66.119:8080/ui/login ?
                      • S Offline
                        shubham
                        Hi Creig,
                        After that mango application become unreachable, login page also to coming.
                        below is the error also present in log file.
                        • CraigWebC Offline
                          CraigWeb
                          Please post you entire ma.log file.
