    How to Limit Data Sources options
    Scheduled Pinned Locked Moved Unsolved How-To
    11 Posts 5 Posters 4.9k Views 5 Watching
      Remove modules and restart mango. Just take caution as to which modules it is you want to remove.
        shubham
        Thanks for the reply,
        Can you guide us how to remove the modules.
          Ralf
          Select menu Administration/Modules
          Mark the module for deletion and restart Mango.
          As MattFox said: "Just take caution as to which modules it is you want to remove."
            Thanks Ralf!
              shubham
              Hi Ralf and Matt,
              From modules option i marked my Log4j Data source to delete and clicked on restart mango button.
              After that i am not able to access mango UI it seems like application stopped and not started.
              Shubham Rajvanshi
                Log4j is the logging system used by Datasources, it's not a datasource itself.
                Usually the modules show their dependencies. If not, go to store.infiniteautomation.com and look at download modules. They tell you what they need to work.
                Edit: Sorry I misread the note. Looks like something has not agreed. Check inside /opt/mango/logs/ma.log and see what the error is that's causing your mango instance not to load.
                  shubham
                  Hi Mat,
                  Below are the exception is coming in log file
                   namespace 'restV2DispatcherServlet-servlet'
                  WARN  2020-03-03T07:36:29,074 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                  java.nio.channels.ClosedChannelException: null
                  	at org.eclipse.jetty.websocket.common.io.FrameFlusher.enqueue(FrameFlusher.java:109) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:582) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.AbstractExtension.nextOutgoingFrame(AbstractExtension.java:155) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.PerMessageDeflateExtension.nextOutgoingFrame(PerMessageDeflateExtension.java:123) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension.access$1100(CompressExtension.java:44) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.compress(CompressExtension.java:591) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.deflate(CompressExtension.java:488) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.process(CompressExtension.java:468) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension.outgoingFrame(CompressExtension.java:244) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.ExtensionStack$Flusher.process(ExtensionStack.java:400) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.outgoingFrame(ExtensionStack.java:277) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.WebSocketSession.outgoingFrame(WebSocketSession.java:355) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.uncheckedSendFrame(WebSocketRemoteEndpoint.java:306) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.sendAsyncFrame(WebSocketRemoteEndpoint.java:240) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at org.eclipse.jetty.websocket.common.WebSocketRemoteEndpoint.sendStringByFuture(WebSocketRemoteEndpoint.java:403) ~[websocket-common-9.4.23.v20191118.jar:9.4.23.v20191118]
                  	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.MangoWebSocketHandler.sendStringMessageAsync(MangoWebSocketHandler.java:138) ~[?:?]
                  	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.MangoWebSocketHandler.sendMessage(MangoWebSocketHandler.java:99) ~[?:?]
                  	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.events.EventsWebSocketHandler.sendMessage(EventsWebSocketHandler.java:123) ~[?:?]
                  	at com.serotonin.m2m2.web.mvc.rest.v1.websockets.events.EventsWebSocketHandler$EventsWebSocketListener.returnToNormal(EventsWebSocketHandler.java:209) ~[?:?]
                  	at com.serotonin.m2m2.rt.event.UserEventMulticaster.returnToNormal(UserEventMulticaster.java:162) ~[mango-3.7.4.jar:?]
                  	at com.serotonin.m2m2.rt.EventManagerImpl$EventNotifyWorkItem.execute(EventManagerImpl.java:1121) ~[mango-3.7.4.jar:?]
                  	at com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl$WorkItemRunnable.run(BackgroundProcessingImpl.java:671) ~[mango-3.7.4.jar:?]
                  	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
                  	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
                  	at java.lang.Thread.run(Thread.java:830) [?:?]
                  WARN  2020-03-03T07:36:34,138 (com.infiniteautomation.mango.rest.v2.ServerRestV2Controller.postClientError:428) - Client error
                  [user=shubham, cause=Possibly unhandled rejection: {"code":"E_MISSING_MESSAGE","path":"dsEdit.egaugePoint"}, location=http://172.30.66.119:8080/ui/data-point-details/, userAgent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36, language=en-US, date=2020-03-03T13:07:25.701+05:30, timezone=Asia/Calcutta]
                  Error: E_MISSING_MESSAGE: Missing required message content `dsEdit.egaugePoint`.
                  	at r (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:61:427)
                  	at a (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:61:583)
                  	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:117:14615)
                  	at Function.t.messageFormatter.t.messageFormatter (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:117:14703)
                  	at Function.trSync (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:72:109051)
                  	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:72:108351)
                  	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:94777)
                  	at null (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:94915)
                  	at c.$digest (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:100341)
                  	at c.$apply (http://172.30.66.119:8080/ui/mangoUi~ngMango~ngMangoServices.js?v=eb9217569c6ceceefbda:78:102518)
                  WARN  2020-03-03T07:37:49,795 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                  WARN  2020-03-03T08:52:21,510 (org.eclipse.jetty.websocket.common.extensions.compress.CompressExtension$Flusher.failed:455) -
                  	at com.serotonin.m2m2.rt.EventManagerImpl$EventNotifyWorkItem.execute(EventManagerImpl.java:1132) ~[mango-3.7.4.jar:?]
                  Shubham
                    Hi shubhamthe log4J data source is not required to run mango. Those warnings are just websockets that have closed. This should not prevent you from logging in. What happens when you go to url: http://172.30.66.119:8080/ui/login ?
                      shubham
                      Hi Creig,
                      After that mango application become unreachable, login page also to coming.
                      below is the error also present in log file.
                        Please post you entire ma.log file.
