    SNMP Publisher / Agent
    4 Posts 3 Posters 3.4k Views 4 Watching
    • ricardoR Offline
      ricardo
      Can Mango publish data as a SNMP agent? Can Mango send SNMP traps as an Event Handler type?
      BR,
      Ricardo
      • CraigWebC Offline
        CraigWeb
        Hi @ricardo
        Mango only has 4 publishers: BACnet, Modbus, Mango PTCP and an HTTP publisher
        phildunlapP 1 Reply Last reply Reply Quote 0
          Hi Ricardo,
          No, Mango does not currently have an SNMP publisher.
          Yes, but it isn't really set up to make such a thing easy. I think we'd best to have a running SNMP data source and use some reflection, something like this, in a Set Point Event Handler,
          //untested
          var snmpDataSourceId = com.serotonin.m2m2.db.dao.DataPointDao.instance.getIdByXid("DS_XID_HERE");
          var snmpDataSourceRT = com.serotonin.m2m2.Common.runtimeManager.getRunningDataSource( snmpDataSourceId );
          if( snmpDataSourceRT !== null ) {
              var field = snmpDataSourceRT.getClass().getDeclearedField("snmp");
              field.setAccessible( true );
              var snmp = field.get( snmpDataSourceRT );
              //get the SNMP version information
              field = snmpDataSourceRT.getClass().getDeclearedField("writeVersion");
              var writeVersion = field.get( snmpDataSourceRT );
              //get the target to send it to
              var target = writeVersion.getTarget( "192.168.0.123", 162, 1, 5000 ); //host, port, retries, timeout
              //construct the PDU
              var pdu = writeVersion.createPDU();
              if( target.getVersion === org.snmp4j.mp.SnmpConstants.version1 ) {
                  pdu.setType( org.snmp4j.PDU.V1TRAP );
                  pdu.setEnterprise( new org.snmp4j.smi.OID( "1.1.1.1.1.1.1") ); //probably a clever way to get the OID from the event
                  pdu.setGenericTrap( org.snmp4j.PDUv1.ENTERPRISE_SPECIFIC );
                  pdu.setSpecificTrap( 1 ); //looks like this may need to cycle in value 1-5
                  pdu.setAgentAddress( new org.snmp4j.smi.IpAddress( "127.0.0.1" )); //Mango's IP on the network here
                  snmp.send( pdu, target );
              } else if ( target.getVersion === org.snmp4j.mp.SnmpConstants.version2c ) {
                  throw "not yet implemented!";
              } else if ( target.getVersion === org.snmp4j.mp.SnmpConstants.version3 ) {
              } else
                  throw "unknown snmp version!";
          } else {
              throw "Data source not found to send trap for event: " + event;
          return UNCHANGED; //don't set from the set point handler
          I would be somewhat surprised if this works, but it shouldn't be too far from the way to do it. I consulted this site for the V1 implementation, and there is also a v2c example: https://www.jitendrazaa.com/blog/java/snmp/generating-trap-in-snmp-using-snmp4j/
          So, possible, but will probably take some trial and error to figure out.
            phildunlap @CraigWeb
            @craigweb said in SNMP Publisher / Agent:
            Hi @ricardo
            Also Twilio and Pachube.
