    cannot load database
    39 Posts 3 Posters 51.0k Views 4 Watching
      Sounds like a power cycle is in order. Give it a good ol' hard reset. It's an old unit so I wouldn't rule out hardware failing. I've had a few V2's die on me, and one of the traits they shared before dying completely was the networking part of the system calling it a day.
      • J Offline
        Jay1089
        Just switching off the power for long time and switch it back on?
          MattFox @Jay1089
          @jay1089 Yep, count to 30 then fire it back up, perhaps monitor the LED's on the case - I assume here it's similar to a V2 with an aluminium cast case with 4 LEDs on the front.
          • J Offline
            Jay1089
            Yes four LED up front. One green and other blinks when network connected. Other two doesn't lit up at all
              Good, the blinking is the heartbeat for Mango, it should be starting then. Check your network again and let's see if the SSH is available.
              https://help.infiniteautomation.com/mangoes-connections?rq=v2
              • J Offline
                Jay1089
                Connection refused still after power cycle. In the LAN connection, The green LEd blinks whereas the orange stays lit all the time.
                  Sounds like something is causing an issue or error of some sort, I thought you meant 2 of the four leds, not the lan socket. .
                  Phil are the display ports on these old boards functioning? I know I had one on the old board, but never had a chance to check myself. It's just a last ditch idea I had.
                  Sorry that's all I've got...
                  • J Offline
                    Jay1089
                    Display port works. But the problem is it cant complete the boot. It is booting for so long
                    • J Offline
                      Jay1089
                      Somehow managed to revert back. Now webmin is working and back to the old issue. Database stuck at 40%. And in command shell, i cant execute bin/ma.sh start. it says permission denied.
                        Nice!
                        try
                        sudo /opt/mango/bin/ma.sh start
                        Let's see what you get!
                        • J Offline
                          Jay1089
                          MA_HOME is /opt/mango
                          /opt/mango/bin/ma-init.sh: line 29: unexpected EOF while looking for matching `"'
                          /opt/mango/bin/ma-init.sh: line 34: syntax error: unexpected end of file
                          /opt/mango/bin/ma.sh: line 28: /opt/mango/bin/ma-start.sh: Permission denied
                          • J Offline
                            Jay1089
                            INFO 2019-08-26 18:07:08,020 (com.serotonin.m2m2.Lifecycle.loadLic:411) - Checking license...
                            INFO 2019-08-26 18:07:08,479 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                            FATAL 2019-08-26 18:07:10,603 (com.serotonin.m2m2.db.DatabaseProxy.initialize:173) - Unable to connect to database of type H2
                            org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 93". Possible solution: use the recovery tool [90030-181]
                            at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
                            at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:630)
                            at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:695)
                            at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:727)
                            at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:737)
                            at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:39)
                            at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:63)
                            at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:244)
                            at com.serotonin.m2m2.db.DatabaseProxy.newDatabaseCheck(DatabaseProxy.java:187)
                            at com.serotonin.m2m2.db.DatabaseProxy.initialize(DatabaseProxy.java:103)
                            at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:542)
                            at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:246)
                            at com.serotonin.m2m2.Main.main(Main.java:104)
                            Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 93". Possible solution: use the recovery tool [90030-181]
                            at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
                            at org.h2.message.DbException.get(DbException.java:179)
                            at org.h2.message.DbException.get(DbException.java:155)
                            at org.h2.store.PageStore.getPage(PageStore.java:813)
                            at org.h2.index.PageDataIndex.getPage(PageDataIndex.java:233)
                            at org.h2.index.PageDataNode.freeRecursive(PageDataNode.java:272)
                            at org.h2.index.PageDataIndex.removeAllRows(PageDataIndex.java:397)
                            at org.h2.index.PageDataIndex.truncate(PageDataIndex.java:382)
                            at org.h2.store.PageStore.removeOldTempIndexes(PageStore.java:397)
                            at org.h2.store.PageStore.openExisting(PageStore.java:373)
                            at org.h2.store.PageStore.open(PageStore.java:288)
                            at org.h2.engine.Database.getPageStore(Database.java:2386)
                            at org.h2.engine.Database.open(Database.java:666)
                            at org.h2.engine.Database.openDatabase(Database.java:266)
                            at org.h2.engine.Database.<init>(Database.java:260)
                            at org.h2.engine.Engine.openSession(Engine.java:60)
                            at org.h2.engine.Engine.openSession(Engine.java:167)
                            at org.h2.engine.Engine.createSessionAndValidate(Engine.java:145)
                            at org.h2.engine.Engine.createSession(Engine.java:128)
                            at org.h2.engine.Engine.createSession(Engine.java:26)
                            at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:347)
                            at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:108)
                            at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:92)
                            at org.h2.Driver.connect(Driver.java:72)
                            at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:190)
                            at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:353)
                            at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:385)
                            at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.java:227)
                            at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:199)
                            at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
                            at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
                            ... 12 more
                            ERROR 2019-08-26 18:07:10,650 (com.serotonin.m2m2.Main.main:109) - Error during initialization
                            ... 12 more
                            /opt/mango/bin/ma-start.sh: line 83: /opt/mango/bin/ext-enabled/*.sh: No such file or directory
                              That still looks like the H2 database is corrupt and needs to be restored from a backup, as I linked in my first response.
                              I'm not sure why you'd have problems executing the shell scripts. Probably part of that has to do with running Mango 2.5 instead of at least 2.8, as i already mentioned. You can download the 2.8 core from https://store.infiniteautomation.com/core
                              You could still try moving your Mango/databases/ directory while Mango is not running, so that it starts on a new database. That would also get past the corruption in the H2 database.
                              • J Offline
                                Jay1089
                                Finally deleted the old databse. what is the default user id password for login?
                                • J Offline
                                  Jay1089
                                  Got the default password. and thanks Phil and Mattfox for supporting. I am bad in linux, but it was a good learning.
                                  • J Offline
                                    Jay1089
                                    I am unable to add new Data Sources. There is no drop down list and even the ADD button doesn't work. I had installed some modbus module and some other module. Is there any other modules need to be installed for the data sources to work properly?
                                    • J Offline
                                      Jay1089
                                      • J Offline
                                        Jay1089
                                        I am stuck here. Couldn't move forward. Installed all modules
                                          I responded in this thread: https://forum.infiniteautomation.com/topic/4425/data-sources-does-not-appear
                                          You do not need to make another thread, and certainly not if you're going to provide less information there than here.
