    cannot load database
    39 Posts 3 Posters 50.1k Views 4 Watching
      Jay1089
      Yes four LED up front. One green and other blinks when network connected. Other two doesn't lit up at all
        Good, the blinking is the heartbeat for Mango, it should be starting then. Check your network again and let's see if the SSH is available.
        https://help.infiniteautomation.com/mangoes-connections?rq=v2
          Jay1089
          Connection refused still after power cycle. In the LAN connection, The green LEd blinks whereas the orange stays lit all the time.
            Sounds like something is causing an issue or error of some sort, I thought you meant 2 of the four leds, not the lan socket. .
            Phil are the display ports on these old boards functioning? I know I had one on the old board, but never had a chance to check myself. It's just a last ditch idea I had.
            Sorry that's all I've got...
              Jay1089
              Display port works. But the problem is it cant complete the boot. It is booting for so long
                Jay1089
                Somehow managed to revert back. Now webmin is working and back to the old issue. Database stuck at 40%. And in command shell, i cant execute bin/ma.sh start. it says permission denied.
                  Nice!
                  try
                  sudo /opt/mango/bin/ma.sh start
                  Let's see what you get!
                    Jay1089
                    MA_HOME is /opt/mango
                    /opt/mango/bin/ma-init.sh: line 29: unexpected EOF while looking for matching `"'
                    /opt/mango/bin/ma-init.sh: line 34: syntax error: unexpected end of file
                    /opt/mango/bin/ma.sh: line 28: /opt/mango/bin/ma-start.sh: Permission denied
                      Jay1089
                      INFO 2019-08-26 18:07:08,020 (com.serotonin.m2m2.Lifecycle.loadLic:411) - Checking license...
                      INFO 2019-08-26 18:07:08,479 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
                      FATAL 2019-08-26 18:07:10,603 (com.serotonin.m2m2.db.DatabaseProxy.initialize:173) - Unable to connect to database of type H2
                      org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 93". Possible solution: use the recovery tool [90030-181]
                      at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
                      at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:630)
                      at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:695)
                      at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:727)
                      at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:737)
                      at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:39)
                      at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:63)
                      at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:244)
                      at com.serotonin.m2m2.db.DatabaseProxy.newDatabaseCheck(DatabaseProxy.java:187)
                      at com.serotonin.m2m2.db.DatabaseProxy.initialize(DatabaseProxy.java:103)
                      at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:542)
                      at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:246)
                      at com.serotonin.m2m2.Main.main(Main.java:104)
                      Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "index not found 93". Possible solution: use the recovery tool [90030-181]
                      at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
                      at org.h2.message.DbException.get(DbException.java:179)
                      at org.h2.message.DbException.get(DbException.java:155)
                      at org.h2.store.PageStore.getPage(PageStore.java:813)
                      at org.h2.index.PageDataIndex.getPage(PageDataIndex.java:233)
                      at org.h2.index.PageDataNode.freeRecursive(PageDataNode.java:272)
                      at org.h2.index.PageDataIndex.removeAllRows(PageDataIndex.java:397)
                      at org.h2.index.PageDataIndex.truncate(PageDataIndex.java:382)
                      at org.h2.store.PageStore.removeOldTempIndexes(PageStore.java:397)
                      at org.h2.store.PageStore.openExisting(PageStore.java:373)
                      at org.h2.store.PageStore.open(PageStore.java:288)
                      at org.h2.engine.Database.getPageStore(Database.java:2386)
                      at org.h2.engine.Database.open(Database.java:666)
                      at org.h2.engine.Database.openDatabase(Database.java:266)
                      at org.h2.engine.Database.<init>(Database.java:260)
                      at org.h2.engine.Engine.openSession(Engine.java:60)
                      at org.h2.engine.Engine.openSession(Engine.java:167)
                      at org.h2.engine.Engine.createSessionAndValidate(Engine.java:145)
                      at org.h2.engine.Engine.createSession(Engine.java:128)
                      at org.h2.engine.Engine.createSession(Engine.java:26)
                      at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:347)
                      at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:108)
                      at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:92)
                      at org.h2.Driver.connect(Driver.java:72)
                      at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:190)
                      at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:353)
                      at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:385)
                      at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.java:227)
                      at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:199)
                      at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
                      at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
                      ... 12 more
                      ERROR 2019-08-26 18:07:10,650 (com.serotonin.m2m2.Main.main:109) - Error during initialization
                      ... 12 more
                      /opt/mango/bin/ma-start.sh: line 83: /opt/mango/bin/ext-enabled/*.sh: No such file or directory
                        That still looks like the H2 database is corrupt and needs to be restored from a backup, as I linked in my first response.
                        I'm not sure why you'd have problems executing the shell scripts. Probably part of that has to do with running Mango 2.5 instead of at least 2.8, as i already mentioned. You can download the 2.8 core from https://store.infiniteautomation.com/core
                        You could still try moving your Mango/databases/ directory while Mango is not running, so that it starts on a new database. That would also get past the corruption in the H2 database.
                          Jay1089
                          Finally deleted the old databse. what is the default user id password for login?
                            Jay1089
                            Got the default password. and thanks Phil and Mattfox for supporting. I am bad in linux, but it was a good learning.
                              Jay1089
                              I am unable to add new Data Sources. There is no drop down list and even the ADD button doesn't work. I had installed some modbus module and some other module. Is there any other modules need to be installed for the data sources to work properly?
                                Jay1089
                                  Jay1089
                                  I am stuck here. Couldn't move forward. Installed all modules
                                    I responded in this thread: https://forum.infiniteautomation.com/topic/4425/data-sources-does-not-appear
                                    You do not need to make another thread, and certainly not if you're going to provide less information there than here.
