    maJsonStore (JSON store)
    35 Posts 4 Posters 42.4k Views 4 Watching
      Evening Richard!
      Are your points numeric types or alphanumeric?
      I say keep it simple and just do
      <span ng-repeat="point in points[site.name]"><!-- Load -->
          <ma-get-point-value point-xid="{{ point.xid }}" point="output"></ma-get-point-value>
          <div ng-if="parseInt(output.value) > 1000">{{  parseFloat(output.value / 1000).toFixed(1) }}kW</div>
          <div ng-if="parseInt(output.value) <= 1000">{{ Number(output.value)}}W</div>
      </span><!-- end Load -->
      You don't have to use what I put int the div inner HTML. But as far as the ng-if is concerned at least you'd have a consistent read with your values.
      richard.mortimerR 1 Reply Last reply Reply Quote 0
      • richard.mortimerR Offline
        richard.mortimer @MattFox
        @mattfox said in maJsonStore (JSON store):
        Evening Richard!
        I believed they were simply numeric - but whern I add the parseInt(output.value) everything disappears (as in - neither ng-if statement is true), similarly the same with the Number and parseFloat functions ...
        If I do: <script>console.log(typeof {{output.value}});</script> I get:
        Cheers
        Richard
          I'll just have a quick look in the mango dash to see fi I can run some tests.
          As for typeof you want: note javascript generally has a numeric. doesn't have ints or floats like compiled languages.
          {{ typeof output.value }} //although i'm not confident if it will work...
            Nope, that didn't work ... :(
              Ok, I can't replicate it. Let's go back to how you had it.
              But make it this for your ng-ifs
              <div ng-if="output.value > 1000">{{ (output.value / 1000) | number:1 }}kW</div>
                  <div ng-if="output.value < 1001">{{ output.value | number:0 }}W</div></span><!-- end Load -->
              Just humour me please.
              EDIT: Could you also please give me a copy of the {{output}} for the problem one?
                richard.mortimer
                {{output}} is:
                   "id":2986,
                   "xid":"S2.DP_HOD-002_827990",
                   "name":"Customer Load - Active Power",
                   "enabled":true,
                   "deviceName":"H02 - B-30",
                   "readPermission":"RO, user",
                   "setPermission":"",
                   "pointFolderId":387,
                   "purgeOverride":false,
                   "unit":"W",
                   "useIntegralUnit":false,
                   "useRenderedUnit":false,
                   "pointLocator":{
                      "dataType":"NUMERIC",
                      "settable":false,
                      "modelType":"PL.PERSISTENT",
                      "relinquishable":false
                   "chartColour":"black",
                   "plotType":"SPLINE",
                   "loggingProperties":{
                      "loggingType":"ALL",
                      "tolerance":0,
                      "discardExtremeValues":false,
                      "cacheSize":1
                   "textRenderer":{
                      "useUnitAsSuffix":true,
                      "unit":"W",
                      "renderedUnit":"W",
                      "format":"####.##",
                      "suffix":"",
                      "type":"textRendererAnalog"
                   "chartRenderer":{
                      "timePeriod":{
                         "periods":1,
                         "type":"DAYS"
                      "type":"chartRendererImage"
                   "rollup":"NONE",
                   "simplifyType":"NONE",
                   "simplifyTolerance":10,
                   "simplifyTarget":5000,
                   "templateXid":null,
                   "dataSourceId":116,
                   "dataSourceXid":"DS_Central_T_E01",
                   "dataSourceName":"Central-T-E01",
                   "dataSourceTypeName":"PERSISTENT",
                   "tags":{
                      "SiteName":"S002",
                      "Display":"Customer Load"
                   "lastPayload":{
                      "xid":"SPS002.DP_HOD-002_827990",
                      "event":"UPDATE",
                      "value":{
                         "value":118,
                         "timestamp":1559717556655,
                         "annotation":null
                      "renderedValue":"118 W",
                      "convertedValue":118,
                      "enabled":true,
                      "attributes":{
                         "UNRELIABLE":false
                   "value":118,
                   "time":1559717556655,
                   "unreliable":false
                Richard
                  Sorry Richard, I'm not seeing anything sticking out here. The only thoughts I have is echoing out {{output}} inbetween both of the ng-if divs. Seeing how you're having two appear in one area makes me wonder if there's some sort of overlap or something stupid. Your values are definitely numeric.
                  The next best idea Ive got is checking your console after doing a page load to see if any angular errors crop up..
                  Otherwise I'm gonna have to call on Jared or Phil to help here. Sorry I cannot be of any further assistance. Either that or I'm just simply half asleep and it's staring me in the face!
                    That's cool - I'm kinda glad it wasn't something glaringly obvious, and I appreciate your help!!
                    Getting a couple of errors, but I'm not sure they are related:
                    Cheers
                    Richard
                    • CraigWebC Offline
                      CraigWeb @richard.mortimer
                      @richard-mortimer Hi
                      I don't think you need to user parseInt etc as javascript will evaluate it as a number when there is a comparator.
                      I tested this out with this code and got the desirable outcome
                      <div class="ma-designer-root" id="ad15c8a3-1798-45ab-9771-535bb550b828" style="width: 1366px; height: 768px; position: relative;" ng-init="points=[
                          {xid:'DP_3414e074-39ae-4179-b3e7-0775e7cabc54'},
                          {xid:'DP_a7485f76-5c52-4c42-b49a-f17b3276a2f8'}]">
                      <span ng-repeat="point in points">
                          <div ng-if="output.value > 999">{{ (output.value / 1000) }}kW</div>
                          <div ng-if="output.value < 1000">{{ (output.value)}}W</div>
                      </div>
                      If you look at your screen shot where the 'error" happens , 1.4kW is from the previous ng-repeat itteration.
                      We can't see the rest of your code but by the looks of it, you have a table with nested repeats. I think you should refactor your code using ng-repeat-start and ng-repeat-end for all you nested repeats just to make sure the browser does not get confused.
                      Edit:
                      Another way to skin this cat would be to use a ternary expression.
                          <div>{{output.value >1000? output.value/1000:output.value}}{{output.value >1000?'kW':'W'}}</div>
                      </div>
                        @richard-mortimer I'm taking a guess at what is happening, but I'm pretty confident that this will fix it -
                        <span ng-repeat="point in points[site.name] track by point.xid"><!-- Load -->
                            <ma-get-point-value point="point"></ma-get-point-value>
                            <div ng-if="point.value > 1000">{{ (point.value / 1000) | number:1 }}kW</div>
                            <div ng-if="point.value <= 1000">{{ point.value | number:0 }}W</div>
                        Two things -
                        • Use track by in your ng-repeat expression so that Angular can correlate which points correspond to each span element when the points change.
                        • Just pass the point to the <ma-get-point-value> component instead of retrieving it by XID again
                        richard.mortimerR 1 Reply Last reply Reply Quote 1
                          richard.mortimer @Jared Wiltshire
                          @jared-wiltshire said in maJsonStore (JSON store):
                          Two things -
                          Thanks for that - I've made the changes and will keep an eye on it; unfortunately it only seems to happen at random times which makes it one of those "fun" bugs to iron out ... but I'm pretty confident that if you're pretty confident, it will probably be the right solution! :)
                          Cheers!!
                          Richard
                            richard.mortimer @CraigWeb
                            @craigweb said in maJsonStore (JSON store):
                            </div>
                            Sorry, I missed this reply - you are correct it's inside a larger loop, which iterates through each device - I'm going to try the ternary operator and see how that goes ...
                            Any idea how to put the number filter in there? The kW was to one decimal place, and the W was to 0 ...
                            Cheers
                            Richard
                            MattFoxM Jared WiltshireJ 2 Replies Last reply Reply Quote 0
                              MattFox @richard.mortimer
                              @richard-mortimer I believe when you did | number:1 and | number:0 was more than sufficient. alternatively just use point.value.toFixed(1) and point.value.toFixed() repectively
                                Jared Wiltshire @richard.mortimer
                                @richard-mortimer said in maJsonStore (JSON store):
                                You would need another ternary operator. IMO the way you had it in the first place is easier to read.
                                If you use this pattern often, consider adding an AngularJS filter to a user module. You could then use it just like
                                <span ng-bind="point.value | formatPower"></span>
                                  Thanks - the colon in the | number:1 was interfering with the ternary operator and getting it confused; so, while I could pipe it through, I couldn't modify the final number based on which direction it took - the point.value.toFixed(1) did the correct thing for me ...
                                  Cheers
                                  Richard
