    Unable to display value from Meta data point
    9 Posts 3 Posters 4.3k Views 3 Watching
    • B Offline
      BobDay
      I am using the below Meta Data Point for an ma-point-value source in a custom page, but get no value displayed. I have tried refactoring numerous times - but cannot get a value to display. Perhaps someone could shed some light on my confusion here? (the script has a numeric input and a string return).
      "dataPoints":[
      "xid":"DP_t1_msg",
      "name":"t1_msg",
      "enabled":true,
      "loggingType":"INTERVAL",
      "purgeType":"YEARS",
      "pointLocator":{
      "dataType":"ALPHANUMERIC",
      "updateEvent":"NONE",
      "contextUpdateEvent":"CONTEXT_CHANGE",
      "context":[
      "varName":"state_no",
      "dataPointXid":"DP_t1_state",
      "updateContext":true
      "logLevel":"NONE",
      "variableName":"val",
      "executionDelaySeconds":0,
      "logCount":5,
      "logSize":1.0,
      "script":"\nif (state_no < 0) {\n return "fault";\n} else {\n switch (state_no) {\n case 0: return "idle";\n case 1: return "filling";\n case 2: return "add mix";\n case 3: return "ready";\n case 4: return "processing";\n case 5: return "overfull";\n case 9: return "empty";\n default: return "fault";\n}}",
      "scriptPermissions":{
      "customPermissions":"",
      "dataPointReadPermissions":"superadmin",
      "dataPointSetPermissions":"superadmin",
      "dataSourcePermissions":"superadmin"
      "settable":false,
      "updateCronPattern":""
      "eventDetectors":[
      "plotType":"STEP",
      "rollup":"NONE",
      "unit":"",
      "simplifyType":"NONE",
      "chartColour":"",
      "chartRenderer":null,
      "dataSourceXid":"DS_tank_state",
      "defaultCacheSize":1,
      "deviceName":"tank_state",
      "discardExtremeValues":false,
      "intervalLoggingPeriod":1,
      "purgeOverride":false,
      "purgePeriod":1,
      "readPermission":"",
      "setPermission":"",
      "tags":{
      "textRenderer":{
      "type":"PLAIN",
      "useUnitAsSuffix":true,
      "unit":"",
      "renderedUnit":"",
      "suffix":""
      "tolerance":0.0
      • CraigWebC Offline
        CraigWeb
        Hi @bullitbd
        Your context variable is an object. Your IF statement and switch will need to use (state_no.value)
        • B Offline
          BobDay
          Hi @CraigWeb
          Thank you - Duh, sorry - thought I'd done that. So, using the .value property, script works as intended when running in the environment - it returns the proper string. However, it still doesn't show up in the directive:
          <td class="point-val"><ma-point-value id="60b670c1-2919-4ad8-a2b9-0da3a9365fee" enable-popup="hide" style="position: relative; height: 40px; color: rgb(255, 255, 255); width: 113px;" point-xid="DP_t1_msg" display-type="rendered" flash-on-change="true"></ma-point-value></td>.
          Using latest Chrome, MangoES, updated. No browser errors... Any further thoughts?
          Thank you for your time!
          • CraigWebC Offline
            CraigWeb
            Hi Bullitbd
            It didn't occur to me early but you might be better off making the original point (DP_t1_state) a multi state point and giving the point text rendering properties like the picture. I am not quite sure why the meta DP does not work with <ma-point-value>. I get the same problem.
              I was not able to reproduce. I imported your JSON and used that markup (without even putting it in a table) but was able to display the value.
              • B Offline
                BobDay
                Thanks @CraigWeb
                Good idea! Unfortunately, it only displays 0, even though that's a defined key. Also, doesn't appear to be a way to deal with < 0 keys. Arrg.
                • B Offline
                  BobDay
                  Thanks @phildunlap. I assume you mean my original Meta Point. I just did the same and got the same blank stare. I'm obviously missing something here... any thoughts?
                    The only thing that occurs to me is that the point may not have a value / not be enabled. Perhaps you could try an alphanumeric meta point simply returning a string on a cron pattern?
                    • B Offline
                      BobDay
                      well, problem was "raw" display setting (thank you @Jared-Wiltshire) among other things. Used range display on his and @CraigWeb's advice - works great.
                      Thanks, all!
