    Mango Enterprise Server Specs - what are you using?
    2 Posts 2 Posters 1.2k Views 2 Watching
    • W Offline
      Wingnut2.0
      Just curious what configurations others are using when specifying an Enterprise server for a Mango install?
      • Processors
      • Memory
      • Drive(s)
      • OS
      How many dataPoints does this configuration support?
      Are you using any Startup Extensions?
        Hi Wingnut2.0,
        A quite large enterprise server I've seen, the one described here, has a 45GB ext specified heap, 40 cores at 2.6 GHz. About 550000 total points across 30 or so persistent data sources, 300000 values/second, throttle incoming persistent threshhold set to 37500000. Also a very large NoSQL minimum batch size (so that it always hits the minimum small batch wait time, which is 60000ms on that system). This system has been cruising along for quite a while. The settings left us a fair amount of room to run large, complex reports or zip around the UI.
