Navigation
    • Search
    [SOLVED] Accessing H2 Web-Console give's "IO Exception"
    User help
    2
    5
    1945
    • mircsicz
      mircsicz last edited by mircsicz
      Hi hi,
      I've found and read those Topic1, Topic2 and this article
      As I'm SSHing to the server I've created a Port-Forward within my SSH Settings so I can open localhost:8081 on my MacBook. So far it works as expected...
      But when I try to open the H2 WebConsole I see this error:
      IO Exception: "/root/test outside /srv/mango" [90028-196] 90028/90028 (Hilfe)
      which leave's me lost...
      EDIT:
      I'm not aware of a change in my setup, but now it work's...
      BUT: what are the default credentials?!?
      • phildunlap
        phildunlap last edited by phildunlap
        I am not familiar with that error. Are you using the Mango/bin/h2-web-console.sh script or your env.properties are set for the web console? I can confirm the h2-web-console script works through an SSH tunnel just fine.
        The credentials will be in your Mango/overrides/properties/env.properties file under db.username and db.password, they're probably "mango" / "mango" or "" / ""
        • mircsicz
          Hi Philip,
          don't know what caused the error, but logging in without credential's did the trick.
          So I've reset the admin passwd, but when I set it again I get this
          An error occurred while logging in - Internal Server Error
          Why is it giving me such a hard time :-(
          • phildunlap
            Hard to say. Did you check the Mango/logs/ma.log file for the error output? Perhaps you didn't quite get the password field right?
            • mircsicz
              I've moved this issue to it's own topic
              And BTW: I've pasted the log output in that new topic...
