    Mango REST API -- event detectors
    mangoapiapirest apievent-detectors
    7 Posts 3 Posters 4.0k Views 3 Watching
    • S Offline
      silvia
      Re: How do I create event detectors using the Mango API?
      Hi all,
      I see that event-detectors is now part of the API :)
      I'm trying to create multiple event detectors for the same multi-state data point; is that possible to do in one single step?
      At the moment I'm trying to do a single event detector using the POST method through the API and using this code (obtained via GET for another data point, and changing the xid, dataSourceId and dataPointId) -- it doesn't work, though, and I get an error 500 back.
                "xid":          "socket_2026-vacant",
                "name":         "Socket 2026 is vacant",
                "duration":       0,
                "durationType":     "SECONDS",
                "alarmLevel":       "INFORMATION",
                "supportedDataTypes": [
                    "MULTISTATE"
                "description":      "Socket 2026 is vacant",
                "alias":            "Socket 2026 is vacant",
                "eventType": {
                  "dataSourceId":     229,
                  "dataPointId":      400,
                  "duplicateHandling":  "IGNORE",
                  "typeName":        "DATA_POINT",
                  "rateLimited":      false
                "rtnApplicable":        true,
                "detectorSourceType":   "DATA_POINT",
                "validationMessages":   [],
                "detectorType":         "MULTISTATE_STATE"
      I want these event detectors to be created immediately after the data points are created, so I'm using response.data.id and response.data.dataSourceId to get this info.
      I would think that these two ids are enough to link the event detector with the data point? What am I doing wrong here? And can I create multiple event detectors at once?
      Thanks and sorry for so many questions ^^U
      Silvia
        @silvia Have you checked the response from the API in the developer tools? There should be an error message.
        I have used the API to create high/low limit event detectors posting something like this
            "xid": "",
            "name": "",
            "limit": 1500,
            "resetLimit": 0,
            "notHigher": false,
            "useResetLimit": false,
            "duration": 60,
            "alarmLevel": "WARNING",
                "NUMERIC"
            "alias": "",
            "sourceId": 123,
            "detectorType": "HIGH_LIMIT"
        Try removing the eventType property. Also try without an XID and name.
          Silvia,
          One option for doing large configuration additions/changes is to use the /rest/v2/json-emport endpoints. Data points have an array of event detectors (like in the regular import/export, though that may change and even detectors may move into their own array) and very large configurations can be submitted for import at once.
          • S Offline
            silvia
            @Jared-Wiltshire, @phildunlap, thanks for your answers. Because I'm trying to create 5 events for each data point, it'd rather do it in bulk importing the JSON.
            I can easily import using the 'Import' tab.
            However, if I try to do the same through the API (either using POST /v1/json-emport or /v1/json-emport/upload-file), I get error 202 - no content.
            These are the response headers:
              "Location": "http://192.168.100.254:8080/rest/v1/json-emport/import/IMPORT_e85e1010-ed81-46c3-bc02-2a24637e1065",
              "Date": "Wed, 15 Nov 2017 09:33:46 GMT",
              "Cache-Control": "no-cache, no-store, max-age=0, must-revalidate",
              "X-Content-Type-Options": "nosniff",
              "X-Frame-Options": "SAMEORIGIN",
              "Content-Length": "0",
              "X-Xss-Protection": "1; mode=block"
            I've also tried removing the outer object and the "dataPoints" array, so that the body only contains the data point object. Regarding the timezone, I'm setting it to either blank, '+00:00' or 'Europe/London', as another post suggested checking here for valid timezones: http://joda-time.sourceforge.net/timezones.html.
            Any new ideas please? Thanks :)
              Hi Silvia,
              I believe you've posted a response to a successful request. Because these imports could be very large, they could take a long time, and thus the response to the submission of an import is better fast, with a Location header you can GET for information on how the import task is progressing.
                As Phillip said HTTP 202 (Accecpted) is a successful response indicating that the import has started.
                • S Offline
                  silvia
                  You're both absolutely right, maybe I wasn't refreshing the page to see the newly created events, I can now... Thanks so much for all of your help! :)
