    Can't find point view c4
    19 Posts 3 Posters 12.7k Views 1 Watching
    • S Offline
      sprokkie
      Sometime's i get this error message in a publicview
      Can't find point view c4 <---- C4 in capitals
      any ideas ?
      also the ??? tekst ??? question marks al still in the publicview
      I lookad at teh language file's and they are both there
      Language is set to english
      any ideas ?
        Can you provide a link to the public view?
        • S Offline
          sprokkie
          http://qsolar.dyndns.ws:8200/public_view.htm?viewId=1
            I don't get that error. The page works fine for me.
            BTW, you don't need to quote the entire message that you are responding to when it is immediately above your message.
            • S Offline
              sprokkie
              That what i said Sometime's
              And it looks like that mesage is only when i connect to the pc where mango is running. On the inside adress (172.16.100.226)
              The link i gave is working with an Iframe.
              Do you know the solution for the other problem.
              If you looked at the page you saw the ??? also
                What kind of machine is that running on? The charts take forever to render. How many samples are being plotted on your charts?
                I know where in the code the "can't find point view" message is displayed, but without being able to reproduce the problem, it is not possible to diagnose. Can you post an export of the view?
                Re the ???, i don't see any of those either. I've attached an updated jar file that will provide more information on the issue. Note that your current version of Mango may not work with this version, so make sure you save the old one just in case. You should now see "(99:xx)" before the last "???", where the "xx" is the language it is trying to look up. Post the entire message that you see - everything between the "???" delimiters - back here.
                Attachment: download link
                • S Offline
                  sprokkie
                  Its running on a Nagasaki MS2100.
                  I have 9 one wire device's attached to it.
                  The charts are really slow i know, it takes a lot of patients.
                  that is why i was looking for a way to publish it on internet without the a connection to the pc
                  the question marks are here
                  How do i use jar the file ?
                    300MHz CPU. Yeah, that would do it. Unfortunately, the host with the data is the host that will generate the content. To paraphrase Ron Schneider, you're going to need a bigger box.
                    Replace the existing seroUtils.jar file in WEB-INF/lib with the attached and restart.
                    • S Offline
                      sprokkie
                      I replaced the file
                      now i onlysee the logobuildingblocks
                      no temperature's and no tekst.
                      so i cannot see the language before the ??
                      the ms2100 performs wel for sunnydatacontrol and logtemp.
                      I thought mango was not that a heavy program for the ms2100
                      i use it because of the low powerconsumtion only 9W
                        Do you see any error messages in the console?
                        The Mango runtime is very light, but view generation not as much so. In particular the generation of charts - especially if you are plotting, say, thousands of point values - takes effort. Try removing the charts or restricting the number of values to plot.
                        • S Offline
                          sprokkie
                          i have no console.
                            When you start Mango you see a list of messages like the following:
                            Feb 19, 2010 9:01:57 PM org.apache.catalina.core.AprLifecycleListener init
                            INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not fou
                            nd on the java.library.path: C:\Program Files\Java\jdk1.6.0_14\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WIND
                            OWS;E:\Program Files\PHP\;E:\Program Files\PHP\ext;C:\Program Files\Java\jdk1.6.0_14\bin;C:\WINDOWS\system32;C:\WINDOWS;
                            C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\DMIX;C:\JavaApis\apache-ant-1.7.0\bin;C:\Program Files\Common Files\GTK\
                            2.0\bin;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\DivX Shared\;C:\WINDOWS\syst
                            em32\WindowsPowerShell\v1.0;C:\Program Files\QuickTime\QTSystem\
                            Feb 19, 2010 9:01:57 PM org.apache.coyote.http11.Http11Protocol init
                            INFO: Initializing Coyote HTTP/1.1 on http-8080
                            Feb 19, 2010 9:01:57 PM org.apache.catalina.startup.Catalina load
                            INFO: Initialization processed in 1910 ms
                            Feb 19, 2010 9:01:58 PM org.apache.catalina.core.StandardService start
                            INFO: Starting service Catalina
                            Feb 19, 2010 9:01:58 PM org.apache.catalina.core.StandardEngine start
                            INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
                            That's your console. Everyone has it.
                            • S Offline
                              sprokkie
                              When i start mango, i click the icon in the systray and then ckick start
                              The mango wil startup automaticaly in the background.
                              tomcat runs as a service.
                              ill gues there is some kind of logfile somewhere
                              tell me what log you need
                              • A Offline
                                Andras
                                Sprokkie,
                                I live in NL like you. My browser (like yours probably) has NL set as default language. If you change the default language to EN/US, the ???? will disappear and the proper text will appear in it's place (I tried it with your solar boiler site and it worked).
                                Luckily for you, I have made an NL I18n translation so you get NL text in your NL browser and you don't have to change the language settings. It will probably ship with the next version of Mango.
                                • S Offline
                                  sprokkie
                                  Hi Andres,
                                  can you send me the file ?
                                    I can confirm that it will indeed ship with the next version.
                                    • S Offline
                                      sprokkie
                                      That's great.
                                      • A Offline
                                        Andras
                                        You can get it here:
                                        http://www.tucsni.nl/mango/mango-i18n-nl.zip
